I am a new airplane owner (since May). My mechanic replaced my battery
last June. No choices, I figured he bought the one it needed. Just serviced it (added water). It's in a REALLY awkward spot to get at and see inside the cells -- on the floor under the instrument panel of a plane with no doors (climb in over the sides). I understand if the water level is not just right, it will boil over and then needs to be cleaned with baking soda and water. I've heard since that the battery should be removed when servicing. Today I heard you can buy a dry battery, that there is controversy about which lasts longer, but that maybe since mine is so difficult to access, the dry type would be a better choice. Thoughts/Opinions? |
I use a recombinant gas (RG) battery in my aerobatic plane, since acid
leakage could be catastrophic. They won't leak at all, and there's nothing to check. The down side is that they need replacement every two or three years as compared to a regular lead acid battery. |
My thought is this should be posted under "owning" not piloting.
"150flivver" wrote:
My thought is this should be posted under "owning" not piloting. Sorry if it's a problem here. I just figured if we can discuss hotels and restaurants, airplane batteries shouldn't bother anyone. |
"150flivver" wrote in message oups.com... My thought is this should be posted under "owning" not piloting. Compared to all of the other stuff that gets posted, it's close enough. After all, someone has to pilot that plane, with the battery acid leaking on their feet! ;-) -- Jim in NC |
and restaurants, airplane batteries shouldn't bother anyone. Hotels and restaurants have nothing to do with aviation, so they are fine in an aviation newsgroup. OTOH, aircraft batteries have to be OT in an aviation newsgroup or the penguin would explode. Jose-- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
... Sorry if it's a problem here. I just figured if we can discuss hotels and restaurants, airplane batteries shouldn't bother anyone. I'll echo the recommendation for posting in r.a.owning. Not because there's a problem posting your post here, but because you are likely to get better answers there. That said, I'll also echo "Viperdoc"'s recommendation for an RG battery. I think that might be what you mean by "dry". They are sealed, ensuring no leaks (barring some failure of the battery, of course). They aren't exactly "dry"...but close enough for your purposes, I think. Pete |
"Viperdoc" wrote in message
news ![]() The down side is that they need replacement every two or three years as compared to a regular lead acid battery. Hell, that sounds *exactly* like a regular lead acid battery... |
There are options, such as gell-cell. The problem with the
battery having low acid (liquid) level is that the cell plates must be submerged in liquid electrolyte in order to work. If the plates become exposed to air and dry out they will become useless. Overcharging will over-heat the battery and boil away the electrolyte, so installing a voltmeter so you can monitor that you don't charge above the design limits (12 volt uses 14.5-14.75 as top of the green) and 24 volt uses 26-28 volts as top, will do a lot to allowing the monitoring of the battery and charging system. BTW, aircraft mechanics have to get into all kinds of small and cramped spaces on a daily basis. Aircraft designers just assume that their girl friends are dating mechanics and are trying to get even. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. wrote in message ... |I am a new airplane owner (since May). My mechanic replaced my battery | last June. No choices, I figured he bought the one it needed. | | Just serviced it (added water). It's in a REALLY awkward spot to get at | and see inside the cells -- on the floor under the instrument panel of a | plane with no doors (climb in over the sides). I understand if the water | level is not just right, it will boil over and then needs to be cleaned | with baking soda and water. I've heard since that the battery should be | removed when servicing. Today I heard you can buy a dry battery, that | there is controversy about which lasts longer, but that maybe since mine | is so difficult to access, the dry type would be a better choice. | | Thoughts/Opinions? |
Xmnushal8y opined
"150flivver" wrote: My thought is this should be posted under "owning" not piloting. Sorry if it's a problem here. I just figured if we can discuss hotels and restaurants, airplane batteries shouldn't bother anyone. Clearly, discussing airplane batteries is out in this news group. How ever, it is perfectly permissible to talk about batteries for hotel emergency lighting. -ash Cthulhu in 2005! Why wait for nature? |
| Thread Tools | |
| Display Modes | |
| Crash In The Nolichucky | W P Dixon | Piloting | 2 | June 22nd 05 05:16 PM |
| Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 06:14 AM |
| Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 05:05 AM |
| The Best Airplane | Veeduber | Home Built | 1 | February 13th 04 06:43 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 3rd 04 12:41 AM |
