#41
Thanks again, everyone, for the info/discussion.
My mechanic came out this afternoon and took the battery and battery box out of the airplane. There was some liquid on top of the battery and inside the box, and a fair amount had drained out of the drain tube. He removed the battery from the box, checked the levels and wiped it off, washed the battery box with baking soda and water, dried it, and took it with him to repaint the bottom inside. He also took the battery to charge it on the bench and check it tomorrow. He said when you remove water from an overfilled cell, you are also removing acid and changing that balance which can also cause the overheating and boiling over. He concurred with the person here that said the proper way to service the battery is to remove it from the airplane, especially if it is in the cockpit (like mine) vs. in the engine compartment. He also agreed with the person that suggested that since my battery is in such an inaccessible spot and I'm not a mechanic, a sealed battery would be a good choice. Thanks again for the discussion, everyone. Personally, I don't care if I have to replace it more frequently, I'd rather have the sealed variety that doesn't involve all this! I am, however, still curious about the trickle charger. Is it advantageous to have this plugged in between flights if you fly at least once/week or is it actually detrimental to the life of the battery? |
#42
Nope, the acid in the electrolyte has to be replaced if you
drain. The water is what breaks down during the charge/discharge cycle, so you only add water to a working battery. The act of draining the sludge would move the sludge into the spaces between the plates, destroying the battery. Just buy a new one and re-cycle the old one, they will melt it down and make bullets, wheel weights and more batteries. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Jose" wrote in message m... | But all batteries wear out because lead flakes off the | plates and collects in the bottom of a standard lead/acid | battery [that's why the plates do not extend all the way to | the bottom of the case, the space is there to collect lead | sludge. When the sludge touches the plates they short out | and the cell is dead.] | | Would it make sense to periodically drain the sludge and refill with | fresh water? | | Jose | -- | Money: what you need when you run out of brains. | for Email, make the obvious change in the address. |
#43
![]() "Jim Macklin" wrote Of course NiCad batteries used in KingAirs and jets cost as much as a small car. Anyone ever seen a cutaway or the real insides of one of those big Nicads used in Jets? I sure would like to see how they are made. -- Jim in NC |
#44
Each cell is a metal case with terminals. They are slide
into the larger case and connected with bus bars to complete the circuit. http://www.saftbatteries.com/020-MS_..._advantage.asp http://www.saftbatteries.com/020-MS_...cteur=Aircraft -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Morgans" wrote in message ... | | "Jim Macklin" wrote | | Of course NiCad batteries used in KingAirs and | jets cost as much as a small car. | | Anyone ever seen a cutaway or the real insides of one of those big Nicads | used in Jets? I sure would like to see how they are made. | -- | Jim in NC | | |
#45
![]() Blueskies You can also get from your wife if she uses it for her steam iron (like she should) ![]() Been doing that for years. Big John `````````````````````````````````````````````````` ``````` On Mon, 23 Jan 2006 22:03:02 GMT, ".Blueskies." wrote: "Jim Macklin" wrote in message news:lSaBf.69242$QW2.68282@dukeread08... Bottled water is filtered tap water and often is enhanced with "minerals for taste" or spring water which also has minerals. Distilled water has been BOILED and the steam condensed, it is as pure as chemically possible. Less than a dollar a gallon. A gallon will keep the battery in your car and plane filled for about 25 years. Use a basting syringe to add distilled water, an ounce at a time, six cells. If the electrolyte level is low in all cells that means that it is working evenly, but if just one or two cells are low, there is likely to be a problem developing. You can also get distilled water from the de-humidifier.... |
#47
![]() wrote I am, however, still curious about the trickle charger. Is it advantageous to have this plugged in between flights if you fly at least once/week or is it actually detrimental to the life of the battery? Depends on the type of battery. Recombinant, Jim has said hates that. Lead acid would rather be full than sit around discharged. Gel cells (lead) hate to sit around fully or partially discharged. The key to any trickle charger is the cut off voltage, too. If one is set too high, then it is always bad. A correct cut off, and IMHO, you can't hurt lead acid. Real world, is probably flying it once a week or even twice will not require anything, if your charging system is working correctly. -- Jim in NC |
#48
![]() Peter Duniho wrote: "Newps" wrote in message ... Well sure, that's essentially what bottled water is anyways. Distilled is hardly the same as filtered (which is actually what bottled water typically is). Most bottled water is dead water. You couldn't find a mineral in there to save your life. |
#49
It is your battery, use what ever water you want. But most
bottled water has minerals added so there is a flavor, some waters now have flavors. Only distilled water is pure, deionized water is OK too, but that is harder to find on the store shelves. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Newps" wrote in message . .. | | | Peter Duniho wrote: | "Newps" wrote in message | ... | | Well sure, that's essentially what bottled water is anyways. | | | Distilled is hardly the same as filtered (which is actually what bottled | water typically is). | | Most bottled water is dead water. You couldn't find a mineral in there | to save your life. |
#50
. .. Most bottled water is dead water. You couldn't find a mineral in there to save your life. So? Even if more than half the bottled waters out there have had every molecule of minerals filtered out (and I doubt that's true), that doesn't make the water distilled. |
Crash In The Nolichucky | W P Dixon | Piloting | 2 | June 22nd 05 04:16 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
The Best Airplane | Veeduber | Home Built | 1 | February 13th 04 05:43 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
