Registration question
Old January 25th 06, 12:28 AM posted to rec.aviation.owning
Default Registration question
I'm reading the FAA CD for a Tcraft.
I see in '90 that it sustained substantial damage, was deregistered as
'totally distroyed', then sold.
Apparently someone resurrected it, because it was sold several years
later using the same N number and it's currently flying in Florida.
The CD (BTW) doesn't show any of what must have been major major work
performing this resurrection (my only reference is the CD; I haven't
seen the logs yet)
There doesn't seem to be the audit trail I'd like; I see a stream of
ownership, but although there is a document saying 'please deregister
this aircraft' there is nothing saying 'pick me back up'.
Should I be concerned? - Mike
Old January 25th 06, 01:24 AM posted to rec.aviation.owning
I would be very concerned... it appears as if the aircraft may be flying
with an expired / unregistered n-number. Also, if someone put it back
together, they did not re-register or realize it was deregistered.
BT
"Michael Horowitz" wrote in message
seen the logs yet)
Old January 25th 06, 01:43 AM posted to rec.aviation.owning
Best way to check is with a title search? - Mike
On Tue, 24 Jan 2006 16:24:53 -0800, "BTIZ"
BT
seen the logs yet)
Old January 25th 06, 02:43 AM posted to rec.aviation.owning
seen the logs yet)
Check the FAA registration database at:
http://registry.faa.gov/aircraftinquiry/defimg.asp
If it shows up there, it is registered. It is not uncommon for an
aircraft to be declared destroyed, "unregistered", and then reregistered
to "clean the slate" as it were after banks fail to clear liens and the
like. In many cases, the aircraft was not even damaged; it's just a
paperwork shortcut around bureacracy.
Good luck,
Rip
Old January 25th 06, 04:56 AM posted to rec.aviation.owning
It's a Taylorcraft. It was wrecked and somebody built a new one. With
a tube and fabric airplane this is normal. All you need out of the
wreck is the data plate. Everything else can be bought new.
seen the logs yet)
Old January 25th 06, 06:11 AM posted to rec.aviation.owning
true... but the documentation needs to keep up with the airframe..
same SerNum, Same N# and FAA records said it was a total
nothing in his "CD" that shows any work done to resurrect the aircraft.
There was the same problem with a CAP L-23.
Damaged in a wind storm in Texas, taken to a military Depot in Amarillo and
left there.
Registration turned in to FAA as "damaged beyond repair".
Then it gets resurrected, parts rebuilt, and starts flying, without a valid
certificate of airworthiness, it was recorded in the FAA records as
destroyed aircraft, and the N number was "cancelled", luckily it was not
reissued to another aircraft. It took nearly a year for the CAP lawyers to
figure it out and get everything back in proper record with the FAA before
the CAP could legally fly it again.
BT
"Newps" wrote in message
It's a Taylorcraft. It was wrecked and somebody built a new one. With a
tube and fabric airplane this is normal. All you need out of the wreck is
seen the logs yet)
Old January 25th 06, 01:31 PM posted to rec.aviation.owning
Do I understand you correctly that if he has a valid airwortiness
certificate we're good to go?
What makes it a valid certification? He could be waving the old one
(pre reserection) for all I know - Mike
Old January 25th 06, 04:50 PM posted to rec.aviation.owning
You think the Feds records are in order? What planet are you on?
Send a letter to FAA Oklahoma and ask some direct questions.
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 05:51 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 06:07 AM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 07:05 PM
