#21
On Sun, 5 Feb 2006 12:28:18 -0500, Capt. Geoffrey Thorpe wrote:
Wow, that's news to me - I flew a Beech Sport for a while. The only problem I has with landings was that I had a hard time getting the hang of the flap thingies (I was too used to slipping in with no flaps in a Cessna 120). Don't recall any problem with bouncing once I got it to the runway. Perhaps I just didn't know that it was supposed to be hard? Or perhaps, the reputation exceeds the reality. I *think* the porpoising tendencies started with the Sundowner / Sierra series? More weight in front with 180HP vs the sport 150HP would be my hypothesis. Allen |
Hello to all. I am new to this board and have my own aircraft
maintenance business. I work on mostly Pipers but also a Sierra that may be for sale soon. I think you would find that the 180 Comanche is a fine plane but you need to have it maintained by someone who understands the landing gear system. So many of the old ones have been bellied in at one time in their past. The Sierra does have a roomy cabin and a short CG range. I had to change the landing gear doughnuts on this model and it's not a job I want to do again any time soon. First of all, you have to rent a special tool from Beech and they want a $2000.00 deposit before they will send it to you. I think it cost about $200.00 to use it plus the shipping charges both ways. If you don't change the doughnuts ($900.00 worth) when they are sagging, you might find the gear don't fit in the wheel wells they way they are supposed to. The gear may or may not extend all the way when you leave the ground, and one or the other will hit the up lock bracket and stay there, instead of snapping into place. I changed every oring on the hydraulic system cylinders (at owners request) and found the retract cycle went from over 30 seconds to 14 seconds. Someone had put an oring in the left cylinder that was too skinny to fill a groove on the piston. I once did a prebuy on a Sundowner and found intergranular corrosion on the left spar in two places. Aft side, lower web, near the tip and just outboard of the fuel tank area. Beech has an approved repair kit for this so you know it has been seen before. Also, don't buy one of these planes with a fuel stain under the wings. Leaks can be hard to fix in the wet wing fuel tanks. Finally, show me a plane where they had to hang a ball of lead ballast on it and I'll show you an AD note. This goes for other brands too. |
#24
A Sundowner is the easiest and most stable plane you will likely ever fly.
There is one thing that really makes it a delight. When you are landing, dial in 75 kts on final using the trim. The trim will maintain the airspeed. Use the throttle for altitude. When you are in ground effect, slow up and pull back slowly until the runway disappears, and hold the yoke back in your lap. If you use full flaps, you can stop in a few hundred feet. Thr thing about porpoising is related to landing too fast, and then letting the nose slam down while you are peering out over the nose looking for the runway. It's not the plane's fault, it still thinks it's flying. One nice thing that is rarely discussed is that it is almost immune to crosswinds. It's big and heavy, and doesn't get blown around much. The demonstrated cross wind is not that high, but I think it can be landed safely with a considerably greater crosswind. You won't break many speed records, and headwinds can be frustrating. I think if Beech put a bigger engine in the Sundowner, like they did with the earlier Super Musketeers, they could sell them today. "A Lieberman" wrote in message ... On Sun, 5 Feb 2006 12:28:18 -0500, Capt. Geoffrey Thorpe wrote: Wow, that's news to me - I flew a Beech Sport for a while. The only problem I has with landings was that I had a hard time getting the hang of the flap thingies (I was too used to slipping in with no flaps in a Cessna 120). Don't recall any problem with bouncing once I got it to the runway. Perhaps I just didn't know that it was supposed to be hard? Or perhaps, the reputation exceeds the reality. I *think* the porpoising tendencies started with the Sundowner / Sierra series? More weight in front with 180HP vs the sport 150HP would be my hypothesis. Allen |
#25
On Tue, 7 Feb 2006 16:44:40 -0500, LWG wrote:
A Sundowner is the easiest and most stable plane you will likely ever fly. There is one thing that really makes it a delight. When you are landing, dial in 75 kts on final using the trim. The trim will maintain the airspeed. Use the throttle for altitude. When you are in ground effect, slow up and pull back slowly until the runway disappears, and hold the yoke back in your lap. If you use full flaps, you can stop in a few hundred feet. Add in the droop wing tips I have on my plane, and it is stable as a table. Only thing above I do differently is fly final at 68 knots unless I am doing an ILS, which I go at 90 knots down to the middle marker. One nice thing that is rarely discussed is that it is almost immune to crosswinds. It's big and heavy, and doesn't get blown around much. The demonstrated cross wind is not that high, but I think it can be landed safely with a considerably greater crosswind. Its funny you mentioned this as I posted my experiences on rec.aviation.student on going out in direct Xwinds of greater then 15 knots. I was extremely pleased how the plane handled, and here I thought it was me *big smile*. You won't break many speed records, and headwinds can be frustrating. I think if Beech put a bigger engine in the Sundowner, like they did with the earlier Super Musketeers, they could sell them today. You mean that the Super M's had more then 180HP? Allen |
#26
On 5-Feb-2006, "Doug" wrote:
You will be paying a big price for retract, in initial cost, maintenance and insurance. Extra speed for 1 to 2 hour trips doesn't amount to much. If you fly over 100 hrs/year the savings in fuel costs with RG compared to a FG with similar performance will more than offset the added costs for maintenance and insurance. -- -Elliott Drucker |
#27
#28
#29
John Theune wrote:
: I'd really like to see some number to support your conclusion. By my : estimates 100 hrs * 11 gals per hour = 1100 gal per year. RG decreases : fuel need by 5% or 55 gal * $3.50 = 192.50 per year in fuel savings. : From the numbers throw about by my aircraft owning buddies the delta in : ownership costs for a retract are much more then that. : Assumptions in above: Fuel burn is about the same for 180HP engines in : Comanche 180 and 172s with 180HP engine. Increased speed reduces need : for fuel by 5% by higher speed in cruise, climb fuel burn is the same. : Big YMMV is added ![]() Not to be too argumentative, but 5% might not be the right number. A quick example: http://www.risingup.com/planespecs/i...plane432.shtml http://www.risingup.com/planespecs/i...plane427.shtml That's a PA-28-180 vs. a PA-28-180R. Cruise of 119 kts vs. 141 kts. That's 18% improvement in speed. Others are similar around 15%. So, multiply your fuel savings by a factor of 3 and you get $600/year. That's starting to sound more in line with the additional costs of a gear swing every year, some more lube, and a replacement part averaging every 5 or so. Just food for thought. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
| Comanche accident averted last evening | [email protected] | Piloting | 23 | April 13th 05 11:02 AM |
| REAL BUDGET BUSTER | Cribsheet | Piloting | 2 | December 18th 04 11:02 PM |
| Commanche alternatives? | John Cook | Military Aviation | 99 | March 24th 04 04:22 AM |
| Commanche alternatives? | Kevin Brooks | Naval Aviation | 23 | March 24th 04 04:22 AM |
| RAH-66 Comanche helicopter could face budget cuts in 2005 | Larry Dighera | Military Aviation | 0 | November 19th 03 03:18 PM |
