#21
Also level the plane as it would fly though the air.Only my $0.02.
LJ Richard Lamb wrote: Lou wrote: I'll agree with the automotive engine with PSRU being heavier, but are you sure about your other statement "the lighter the better"? I'm currently looking at an engine that is 100lbs lighter than the one recommended for my plane. Although cutting 100lbs from the total weight is a dream come true, it brings up the question of weight and balance. I can move the engine forward to make up the difference in balance, but I don't know how far or how to find out. Lou Googling this group for weight and balance yields 25 pages... So I picked up one of mine here (Dec 10, 2002) and included Brian's note at the bottom... (Unfortunately, there was no link attached, so here is the text). There is a lot of smoke and mirror magic around weight and balance because so many people understand it so poorly. At the heart of all of it, though, is a rotational force about a reference point. the rotational force is called a MOMENT, and the reference point is called the DATUM. Sometimes the datum is located at the tip of the spinner. Sometimes it's located at the main gear axles. Sometimes its located at the leading edge of the wing. It doesn't particularly matter where it is located, as long as you use the same location to work the problem. You'll often see the term STATION. This is the distance from the datum to a particular place on the aircraft. Say, for instance, the instrument panel? The station numbers change according to where the datum is placed. But the instrument panel stays in the same physical location. It's all an offset from a zero point. One reason to place the datum at the tip of the spinner is because all the station numbers are positive. No negative distances to confuse things. One reason to place the datum at the axles is because the datum is station zero.zero. Multiply the weight on the wheel times zero (the ARM is zero at the datum) and the moments for that wheel come out to zero. Makes the arithmetic a little easier? And, the reason to place the datum at the leading edge of the wing it because that's where we are going to wind up anyway. The results of our CG calculations will finally boil down to a point some given distance aft of the leading edge. CG range is often refereed to in terms of a percentage of the wing chord. Say 25% would be the forward CG limit, maybe 33% would be the aft limit. So our end number actually refers to a distance aft of the leading edge. The actual numbers will be different, depending on where the datum is located, but they all (hopefully) come out at the same place on the airplane. First rule: weight x distance = moments pounds x inches = pound inches (!) So, moments / inches = pounds and moments / pounds = inches Practical example: A bowling ball, held at the chest, has a certain weight. Held at arms length, it has exactly the same weight! But due to the longer distance (called ARM) it has a much higher moment. \ THAT's what feels so heavy. That rotational force. So, to solve your little weight and balance question. The only distance from anything. that matters, is the distance from the CG of the instrument to the DATUM specified for that aircraft. If you have a "before" weight and balance already done, multiply the weight of the instrument times the distance from the datum given in the "before" problem. Then add that moment to the airplane's moment, and the instrument weight to the airplane's weight. Divide the new moments by the new weight and you get the new CG location. Does that help? Or do you maybe feel like I sometimes do after some of your answers??? From: Brian Anderson - view profile Date: Tues, Dec 10 2002 12:22 am Jim, EE's are the brightest of the lot - - - they can measure and calculate things you can't even see. The revised CG calculation is straightforward, but you need to calculate the original moment first, i.e. the total weight [W] x the arm from the datum [D]. Add to this the additional moment for the instrument, i.e. 8 lbs x the distance of the instrument CG from the datum [d]. The resulting moment is [W*D] + [8*d]. Divide this by the new total weight [W+8], and the result is the new CG location from the datum. Hence, new CG location = [[W x D] + [8 x d]]/[W+8] I know even an elderly EE can follow that. After all, I is one too. Brian |
"Chris Wells" wrote in message
... How are "normal" airplane engines tuned to run at a lower rpm? What changes would have to be made to an automotive engine to shift the power band down accordingly? Longer stroke. -- Geoff the sea hawk at wow way d0t com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
![]() "Peter Dohm" wrote However, you will also be changing the area and arm relationships of the side view of the aircraft (there is a name for this which I cannot recall) and the size of the verticall fin will need to be increased if you are to retain the same yaw stability. Then, because of the increased area of the vertical stabilizer, a larger rudder would be needed to retain the original crosswind landing capability. In addition, due to the increased planform area forward of the CG, a larger horizontal stabilizer may well be required to prevent any sort of deep stall or flat spin tendency. Finally, just as a larger vertival stabilizer requires a larger rudder, a larger horizontal stabilizer will very likely require a larger elevator. To put it another way: Engineering is the science of compromise, and an airplane is a series of compromises flying in close formation. It should not change all that much, I'll bet. If you look at that heavy engine moving a few inches, and the increased cowl area in front of aerodynamic center pressure, then look at that long, long arm back to the fin and rudder, it should only take about a third of the area the engine added to make it all work out. Increase the fin/rudder height a couple inches, or add a small dorsal fin, and all will be well in the world. :- Reminder: all usenet advice is worth what you pay for the advise. To the OP; what are you using that is 100 lbs lighter, and what was the original? That is a nice weight savings! -- Jim in NC |
#24
![]() "Chris Wells" wrote in message ... I'm well aware of the purpose of the PSRU, I'd like to know if it's feasible to convert an automobile (or other) engine to run at an RPM low enough so that a PSRU wouldn't be necessary. I'm thinking a custom camshaft would be needed, and different ignition timing, what else? -- Chris Wells Changing a cam has *some* impact, but it doesn't change the amount of fuel/air mixture the engine can burn on each combustion stroke, which is what really determines the output of an engine. That's why small engines have to spin fast to develop, say 200 hp, while larger engines can run considerably slower. Changing the timing? Well, the slower an engine turns, the more the timing must be retarded to prevent knocking. Most engines (auto or aviation) have their ignition timing set to produce the most power possible while leaving a margin against knock or pre-ignition. So changing the timing may not be practical, nor is it likely to turn a pig's ear into a silk purse. The bottom line is that unless you're willing to turn a relatively large, heavy engine slowly and with a disappointing power/wt ratio, there really isn't a good way to take an automobile engine, bolt it onto an airplane, and go flying. Auto engines are designed for what they do, as are airplane engines. Same thing for horses and camels. You won't win the Kentucky Derby with a camel, but neither is a thoroughbred going to survive long in the desert... KB |
#25
feasible to convert an automobile (or other) engine to run at an RPM low enough so that a PSRU wouldn't be necessary. I'm thinking a custom camshaft would be needed, and different ignition timing, what else? You need much longer stroke, which would mean a crank with longer throws which won't fit in the crankcase anymore, and a longer cylinder to accomodate the longer piston travel, which you're not going to get, either. Take a look inside any auto engine crankcase sometime, and see how close all that stuff is running; there's not much extra room. Chevy took the 283 and made the subsequent 305/307/327/350/400 engines out of it by boring larger diameter cylinders (which required just a bit more casting thickness) and a crank with a tiny bit more throw, which they managed to squeeze into the case. See http://www.aces.edu/~gparmer/sbc.html The Chev 350 V8 has a bore of 4" and a stroke of 3.48, while my old Gypsy Major, a four-banger that had about the same displacement, had a 4 5/8" bore and 6 1/2" stroke. Big torque. Redlined about 2650 rpm. Modern aircraft engines like the O-320 are more oversquare like the auto engines, but still have longer strokes of about 4". The car engine's crank, as someone else pointed out, won't take prop thrust loads well, and certainly can't handle the gyroscopic loads the prop places on it. Even the direct-drive conversions usually have some sort of extension and bearings to take those loads; those that don't, like many of the VW and Subaru conversions, have had crankshafts break in flight. Special forged cranks are required, but the bearings in the case are still too light. Try picking up a Lycoming 0-320 sometime: 280 lbs or so. Then try picking up the Chev 327, almost the same displacement, and see what it weighs: 575 lbs. Then pile on the radiator and some water, too. Your airplane has to lift all that. Dan |
#26
engine moving a few inches, and the increased cowl area in front of aerodynamic center pressure, then look at that long, long arm back to the fin and rudder, it should only take about a third of the area the engine added to make it all work out. Increase the fin/rudder height a couple inches, or add a small dorsal fin, and all will be well in the world. :- It will change it some. My Jodel came out considerably heavier than designed, mostly to the use of birch instead of the mahogany specified in the original French drawings, fabric over all ply surfaces to meet Canadian requirements, a tailwheel insterad of a skid, and so on. Since most of the added weight is behind the CG, it was tailheavy and the engine had to go 11" further forward. The longer nose side area results in a little less directional stability with the same tail, and I won't spin it because I don't know just what the effect of the extra weight in the tail (and the longer nose arm to balance it) might do to the spin; it might flatten into an unrecoverable situation. Sure does an awesome slip, though. Dan |
#27
![]() ORVAL FAIRAIRN wrote: In article , Chris Wells wrote: How are "normal" airplane engines tuned to run at a lower rpm? What changes would have to be made to an automotive engine to shift the power band down accordingly? You are entering an engineering thicket when you decide to convert automobile engines to aeronautical use. One item nobody has yet mentioned is the matter of thrust bearings. An automobile engine is designed to deliver its power through a clutch, to a gearbox, with relatively low axial forces imparted to the crankshaft. A direct-drive aircraft engine, however, delivers its power to a propeller, which pulls (or pushes) axially on the crankshaft. If you took an automobile engine and hung a prop on the end of the crank, you amy or may not have enough thrust bearing to take the loads. A properly-designed PSRU will have a thrust bearing to take those loads. Some PSRUs, however, may impart side loads to the power end of the crank and result in wear and fatigue issues. There is an axiom for homebuilders: If you want to develop engines, convert automobile engines; if you wish to fly, use aircraft engines. Well put.. Converting an auto engine for aircraft use is not for the novice to try. As Orval says. If ya want to fly now,, install a Lyc/Cont/Rotax. My Zenith 801 is coming up on 100 hours and so far it hasn't killed me yet. In fact I am headed out first thing in the mornin in my auto engine powered toy to Idaho for breakfast to take advantage of this good thick cold air. It's -6f now and headed to -20 by morning. That always helps when one is based at 6600 MSl... Ben Jackson Hole Wy www.haaspowerair.com |
#29
On Fri, 10 Feb 2006 16:28:10 GMT, Alan Baker
wrote: In article .com, wrote: But when we DO use 'horsepower' we must be careful to never use it in isolation, always identifing the rotational speed at which that 'horsepower' is being produced. Absolutely and utterly wrong. It is *torque* which must always be associated with the rotational speed at which it is being produced. Read that first sentence again. He's not wrong; he just didn't specify "torque" for those who don't know the relationship between it and RPM and HP. When you say "absolutely and utterly" it should be used only where it applies. Clearly, that's not here. But that's my point. He is absolutely and utterly wrong, when he says that you need to know the rotational speed before you know all you need to know when you know the horsepower. With horsepower, you can use gearing to get any rotational speed you want; the horsepower remains constant. Torque changes with gearing. Yes, you CAN use gearing, at the expense of complexity.And efficiency. Much better to design the engine to produce the power you need at the speed you need it. However, sometimes you trade efficiency and durability for weight - and a geared 1.2 liter 80 hp engine running at 6000 RPM can weigh significantly less than a direct drive 2.7 liter engine providing the same power at 2800 rpm. (well, about 40 lbs less, anyway) |
#30
![]() Alan Baker wrote: ...that's my point. He is absolutely and utterly wrong, when he says that you need to know the rotational speed before you know all you need to know when you know the horsepower. With horsepower, you can use gearing to get any rotational speed you want; the horsepower remains constant. Torque changes with gearing. Fantastic! I've been trying to solve the following problem, and clearly you know how to do it. Please help: I have a 40 horsepower motor but no idea what the rotational speed is. What gearing should I use? Thanks in advance. Daniel |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
automotive parts on airplane engines | Wallace Berry | Home Built | 15 | September 28th 03 02:55 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
