Differences between automotive & airplane engines
Old February 14th 06, 04:42 AM posted to rec.aviation.homebuilt
Default Differences between automotive & airplane engines
In article k.net,
Richard Lamb wrote:
I'm rather curious, considering the current fuel situation,
What would a healthy dose of alcohol do the the BSFC and power
output?
I'm a little familiar with some of the handling and corrosion
issues from a friend that races quarter midgets.
Richard
Alcohol contains only some 79% of the energy of gasoline.
  #72
Old February 14th 06, 04:10 PM posted to rec.aviation.homebuilt
"Orval Fairbairn" wrote in message
news
In article k.net,
output?
Richard
Racers use alcohol for a lot of reasons, but mainly that water can put out
the fires when they happen. The corrosion issues for race cars are easier
to deal with because the life of a race car is short. A 3 or 4 year old
race car is seldom still run at most of the higher levels. Lower levels
they tend to last longer, but you won't see many 50 year old race cars
running (though with vintage racing thats changing too) An airplane has to
be designed to last.
  #73
Old February 14th 06, 08:21 PM posted to rec.aviation.homebuilt
On Tue, 14 Feb 2006 16:10:15 GMT, "mark"
news
In article k.net,
output?
Richard
But alky also has a significantly higher octane rating.
*** Free account sponsored by SecureIX.com ***
*** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com ***
  #74
Old February 14th 06, 10:04 PM posted to rec.aviation.homebuilt
clare at snyder.on.ca wrote in message
snip-------
The higher octane rating (~115 - 130) allows a higher compression ratio
and/or higher boost pressure. If the alky is allowed to fully evaporate in
the intake (as opposed to direct injection) you get a cooler, denser intake
charge. To get the most out of ethanol, the engine has to be designed for
it from the beginning. If this is done, my understanding is that the BSFC
is about the same as with gasoline.
Bush II is hot for cellulose (Sawgrass) to ethanol as a fuel source. Why
stop there? If you are bioengineering the bugs to do that, why not
bioengineer them to produce Iso Octane instead? Iso Octane is a perfect
motor fuel if made available in commercial quantities - no engine mods
needed
Bill Daniels
  #75
Old February 15th 06, 01:09 AM posted to rec.aviation.homebuilt
snip-------
needed
Bill Daniels
Damn good point! I'm sure that somewhere, a smart bioscientist will see
the obvious!
  #76
Old February 15th 06, 01:55 AM posted to rec.aviation.homebuilt
news
snip-------
in
intake
for
BSFC
Why
needed
Bill Daniels
the obvious!
I certainly hope that you're right. One of the especially good things about
purely petroleum based products is that they are not especially
hydroscopic--and that they are easily separated from water with nothing more
than a very fine mesh strainer. I don't know of any easy way to accomplish
that with any of the flammable alcohols. And any re-refining of ethanol,
whether by distillation or fractional freezing, undoubtedly requires a
special license--at least in the U.S.
  #78
Old February 15th 06, 03:59 AM posted to rec.aviation.homebuilt
Bill,
Having built and tuned alcohol drag boat engines that WERE designed and
built to run alcohol, I've never seen this. Our alcohol fuel lines and pump
volumes were typically twice the area. That is, if a 3/8 line would
normally be used, we'd go to 1/2" line.
Alcohol (at least Methanol, which is what we ran) is actually a little bit
heavier than gasoline by about 10% at around 6.75#, and the specific gravity
of pure methanol is .81 while normal regular gasoline is .72. (Yes, we
jetted the pill in the Hilborns by chart initially based on density altitude
and specific gravity of the alcohol. I can probably find the conversion
charts somewhere if I looked hard enough.)
Anyway, higher volume and higher density does not equal the same or lower
BSFC. While Alcohol has a higher octane, it has a significantly lower BTU
content and that's what makes the heat that makes the engine run.
John Stricker
"Bill Daniels" bildan@comcast-dot-net wrote in message
To get the most out of ethanol, the engine has to be designed for it from
the beginning. If this is done, my understanding is that the BSFC is
Bill Daniels
  #79
Old February 15th 06, 02:33 PM posted to rec.aviation.homebuilt
Roger that.
-R.S.Hoover
  #80
Old February 15th 06, 03:43 PM
Chris Wells Chris Wells is offline
Senior Member
First recorded activity by AviationBanter: Oct 2005
Ok, I've been scolded for using the word "automotive" and then I was scolded for using "automobile". It would seem to me that in this context, "automobile" would be correct, but can someone give me a final ruling?
BTW, this has been a very informative thread. This is exactly what I read message boards for.
Newbie Qs on stalls and spins Ramapriya Piloting 72 November 23rd 04 04:05 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
automotive parts on airplane engines Wallace Berry Home Built 15 September 28th 03 02:55 AM
