For all you guys and gals building a homebuilt plane DO NOT use a auto
engine conversion or any other option that is not FAA certified, Ya see the feds and Lycoming have a lock on the market providing "quality and time tested powerplants". Let's see now. it all started a few years back when Lycoming had a brain fart and decided they knew more about crankshafts then god, so they redid them, with the FAA's blessing of course. Ya know the feds demand strict safety testing and "high" quality control over certified parts. Well, that batch of hundreds had several break and kill a few innocent souls, So they recalled them and redesigned the problem out of them and in the meantime kept hundrends of planes grounded for months while they " patched" the issue. They introduced a "New and Improved" crank that would cure all their issues. Well, those broke at a alarming rate and killed 14 innocent souls. All the while with the feds watching this all unfold. Lycoming then tried to sue the forging company that stamped out the cranks that THEY speced the design for. Well, that didn't fly either. So here comes round number three. Too bad they don't have the three strike rule in aviation.. http://www.lycoming.textron.com/supp...tins/SB569.pdf Ben www.haaspowerair.com ya, I am the bad guy trying to get ol Barnyard Blob to wake up. G |
![]() So here comes round number three. Too bad they don't have the three strike rule in aviation.. ----------------------------------------------------------------------------- I love it... "While there has been no failures..." But the 'early crankshaft retirement' is even more hilarious. Lycoming makes it sound as if they're sending kids to summer camp instead of commiting wilful murder by selling a product known to be defective. -R.S.Hoover |
("stol" wrote)
So here comes round number three. Too bad they don't have the three strike rule in aviation. http://www.lycoming.textron.com/support/publications/maintenancePublications/serviceBulletins/SB569.pdf Today's AvWeb lead story: http://www.avweb.com/eletter/archives/avflash/586-full.html#191678 Lycoming Woes Continue: 5100 Crankshafts To Be "Retired" (From the link) "In previous recalls totaling some 2400 crankshafts, Lycoming has paid for the engine work to various degrees, even reimbursing owners for hangar expenses and loss of use in the 2003 recalls. Not this time. Owners affected by the crank retirement will get a discount deal on the replacement crankshaft -- $2000 for the shaft, plus a box full of free parts such as gears, bearings, piston ring sets, connecting rod bolts and nuts and seals. But they're on their own for engine assembly, repair and reinstallation, which field overhaul shops tell us will add another $4000 to $5000 to the job if the crank is replaced proactively or before the engine reaches routine TBO. Further, owners will have to ship the retired crankshaft back to Lycoming to obtain the discount price, also at their own expense. The $2000 offer applies to crankshafts for any engine and is substantially below list price for a new part, especially for six-cylinder engines." "Lycoming says it will ramp up production of replacement crankshafts but as in previous recalls, priority will go to government operators and Part 121 and Part 135 operators, with private owners last. What's not known is if this recall withdraws all of the potentially defective crankshafts from the market. (We queried Lycoming about this but haven't received a reply yet.) The crankshafts in question were manufactured between March of 1997 and March of 2002." Montblack |
You must have a lot of patience, a barrel full?, to get that one to see the light. Certaninly more patience than I cam muster! |
![]() "Montblack" wrote in message ... ("stol" wrote) So here comes round number three. Too bad they don't have the three strike rule in aviation. http://www.lycoming.textron.com/supp...ncePublication s/serviceBulletins/SB569.pdf Today's AvWeb lead story: http://www.avweb.com/eletter/archives/avflash/586-full.html#191678 Lycoming Woes Continue: 5100 Crankshafts To Be "Retired" But the mandatory service bulletin leaves out O-320's and O-235's. One wonders if Teledyne is getting its alloys from the same source. I doubt it. And where are the reports of deaths or personal injury caused by the bad cranks? Do we have a cite from a Lycophobe? |
Is there something that indicates that:
1) Uncertified cranks from uncertified manufacturers are a more reliable product 2) If there was a problem with an uncertified crank from an uncertified manufacturer, the manufacturer would notify owners of the potential problem. Otherwise, I don't see this as a certified vs non-certified issue. KB |
![]() Is there something that indicates that: 1) Uncertified cranks from uncertified manufacturers are a more reliable product The point is not that Ben Haas forged 4340 steel crank for his Ford conversion is a better product (it is, but that's not the point) - the point is that the Lyc product is not magic, perfect, and made by elves in the black forest, as the price and some of the folks here would have us believe. Let a few Corvair cranks break after 40 years, and it's no longer a viable motor, but Lyc gets a pass when they have (far worse) trouble?? P.T. Barnum had it right! 2) If there was a problem with an uncertified crank from an uncertified manufacturer, the manufacturer would notify owners of the potential problem. Otherwise, I don't see this as a certified vs non-certified issue. KB |
jls wrote:
"Montblack" wrote in message ... ("stol" wrote) So here comes round number three. Too bad they don't have the three strike rule in aviation. http://www.lycoming.textron.com/supp...ncePublication s/serviceBulletins/SB569.pdf Today's AvWeb lead story: http://www.avweb.com/eletter/archives/avflash/586-full.html#191678 Lycoming Woes Continue: 5100 Crankshafts To Be "Retired" But the mandatory service bulletin leaves out O-320's and O-235's. One wonders if Teledyne is getting its alloys from the same source. I doubt it. Just guessing here, but aren't the O-235 adn O-320 cranks solid rather than hollow (for constant speed props)? |
Bottom line is that if you use an auto engine made in the millions you
can research the failure rate, particularly if you pick an engine used in motorsports run to destruction you can see where they fail first. I would pay a premium, a big premium, to be able to fly a small block Chevy in terms of a bigger airframe than you otherwise would, just for that huge knowledge base. |
RapidRonnie wrote:
Bottom line is that if you use an auto engine made in the millions you can research the failure rate, particularly if you pick an engine used in motorsports run to destruction you can see where they fail first. I would pay a premium, a big premium, to be able to fly a small block Chevy in terms of a bigger airframe than you otherwise would, just for that huge knowledge base. Gently disagree, Ron. The reason is that the prop loads are far different from anything you'll see on the race track. Apples and oranges again... Richard |
It sure makes a difference to own your own plane!! | Marco Rispoli | Piloting | 9 | June 29th 04 11:15 PM |
Rental policy | Robert | Piloting | 83 | May 13th 04 05:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
