Our club has a Grob 103 Twin Astir which will require the elevator control
horn to be replaced per the recent AD. We're looking for a shop to do both the mechanical work and the composite work. We've found a couple of shops in northern California, but are looking for someone closer to home just to make the transport easier. Can anyone direct us to some repair companies in southern California or Arizona? Thanks. Roger |
Roger Worden wrote:
Our club has a Grob 103 Twin Astir which will require the elevator control horn to be replaced per the recent AD. We're looking for a shop to do both the mechanical work and the composite work. We've found a couple of shops in northern California, but are looking for someone closer to home just to make the transport easier. Can anyone direct us to some repair companies in southern California or Arizona? Thanks. Roger None in So Cal so far as I know. |
There's a guy named Robie Grove at Gillespie Field (near San Diego)
who sometimes does composite/mechanical work on gliders. |
There are currently no shops in Arizona - folks from the Phoenix area
usually end up going to our nearest outfit in New Mexico. Sorry! Mike |
Caracole doesn't do composite repairs and the shop at California City that
did is gone. Bill Prokes (Tile, Signs and Graphics in Tempe, AZ, (480) 967-6029) does first-class work but is also far away. Most repair work from Cal City goes to Williams or Minden. Ray Warshaw 1LK wrote in message ups.com... wrote: There's a guy named Robie Grove at Gillespie Field (near San Diego) who sometimes does composite/mechanical work on gliders. Also, have you tried Caracole and Crystal? they have a mechanic there... but I don't know about an A.I. Mike Malis |
Raphael Warshaw wrote:
Most repair work from Cal City goes to Williams or Minden. Who is doing composite work at Minden these days? Marc |
Marc Ramsey wrote:
Raphael Warshaw wrote: Most repair work from Cal City goes to Williams or Minden. Who is doing composite work at Minden these days? By the way, there is another composite repair shop in Northern California, Yankee Composites in Lakeport, CA: http://www.yankeecomposites.com/ Marc |
If you don't have glass work there's a good chance that Jeremy at Turf
Soaring can do it. He's the A&P who does the glider maintenance for the commercial operation there. You may want to give Turf a call. -ted/2NO |
I believe glass work is required to bond the replacement control arm into
the elevator BT wrote in message oups.com... If you don't have glass work there's a good chance that Jeremy at Turf Soaring can do it. He's the A&P who does the glider maintenance for the commercial operation there. You may want to give Turf a call. -ted/2NO |
| Thread Tools | |
| Display Modes | |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| Calibrate? Repair? Adjust? | RST Engineering | Owning | 3 | April 4th 05 02:41 PM |
| Running a repair shop | Greg Esres | Owning | 15 | May 24th 04 06:06 PM |
| Canopy crack repair | Pete Brown | Soaring | 0 | May 18th 04 04:09 AM |
| Anyone in France or Germany, nearest repair shop to Limoges Bellegarde,contact info | goneill | Soaring | 1 | October 28th 03 05:03 PM |
