Panel Planner
Old March 6th 06, 08:36 PM posted to rec.aviation.homebuilt
Default Panel Planner
Now that Panel Planner is a pay-for-use website, is there any other
type "freebie" service out there? I'm having withdrawal symptoms.
Neal
Old March 7th 06, 12:52 PM posted to rec.aviation.homebuilt
Neal
Whatcha doin with these things, Neal?
If they have to be photo real, well, sats...
But CAD lets you draw almost anything ya want.
http://home.earthlink.net/~tp-1/pan019b.jpg
I got creative one day and made CAD drawings of various instruments,
face and side, from actual ones I had as well as some generics. Side
views are important since space behind the panel can get strange fast. I
also made drawings of AN hardware (lot less tedious than it sounds since
in most cases all I had to do was scale 'em) all of which makes life
easier. I recommend anyone doing this also do mounting trays. One nice
thing about CAD is you can mirror the panel to plan wiring and plumbing.
For those of you who haven't used CAD everything I have described is
simple to learn to do and can save you headaches in the long run unless
you enjoy redoing a part. Nice thing about instruments is the come in
standard cases so you can easily make generic drawings if you don't have
the actual instrument in hand. Just copy the cases and name them as
required.
The only hard part is dimensioning your drawing. It's easy to run
over your dimension lines to the point of being a total mess. If
necessary make copies of the drawing each with a different set of
dimensions. Example: 1 for switches, another for engine instruments etc.
Dan, U.S. Air Force, retired
Old March 7th 06, 04:53 PM posted to rec.aviation.homebuilt
Neal
required.
The only hard part is dimensioning your drawing. It's easy to run over
your dimension lines to the point of being a total mess. If necessary
make copies of the drawing each with a different set of dimensions.
On the dimensioning part, most CAD systems have multiple "layers" that
can be turned on or off as desired.
By placing the dimension on a different layer, the drawing can be read
easily - or not - as the case may be.
I don't always dimension everything on all drawings.
One dimension somewhere - often a single line 12 inches long - is plenty
because everything on that page is drawn to the same scale.
That 12 inch long line allows easy flopping between inches and feet.
With Design CAD, this is accomplished with the Units command.
Two points are are selected and the distance between them is specified.
This sets the "units" for the entire drawing.
For construction prints, however, complete dimensioning is more important
and more of an art form to make them legible.
Like Dan said...
Old March 7th 06, 07:10 PM posted to rec.aviation.homebuilt
Richard Lamb wrote:
Neal
I also made drawings of AN hardware (lot less tedious than it sounds
since in most cases all I had to do was scale 'em) all of which makes
life easier. I recommend anyone doing this also do mounting trays. One
nice thing about CAD is you can mirror the panel to plan wiring and
plumbing.
unless you enjoy redoing a part. Nice thing about instruments is the
come in standard cases so you can easily make generic drawings if you
don't have the actual instrument in hand. Just copy the cases and name
them as required.
Like Dan said...
When I first started college drafting my instructor told us proper
dimensioning was going to be the hardest part to learn. He wasn't
kidding. He taught us a few tricks to keep things tidy that apparently a
lot of people never learned. The abbreviation "TYP" is too infrequently
used. My theory is if I can't look at the drawing a year later and be
able to instantly understand it I did something wrong.
Old March 8th 06, 12:48 AM posted to rec.aviation.homebuilt
I feel the same way about program code!
Why not a hinged panel? Jay Honeck Owning 22 March 8th 05 12:15 AM
Trying to find the Boeing 737-300 Photo Real Panel for FS98(antique;-) Heiko Brandstaedter Simulators 0 October 7th 04 03:42 PM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 04:52 PM
Air Force Academy Review Panel Releases Report Otis Willie Military Aviation 0 September 19th 03 04:45 AM
Air Force Museum forms review panel Otis Willie Military Aviation 2 August 29th 03 05:41 PM
