No, that is one possible reason with a filling, but surgery
and extractions can heal over leaving an abscess and that could be a very painful problem. When my wisdom teeth were removed, the roots actually penetrated the sinus cavities. For several weeks I could have salt water run through from my mouth to my nose by dipping my head. This was not a problem flying, it was even more venting. But I would want to have a flight test before I was the only pilot on the plane. Gas would be reabsorbed if enough time passed, but if there was any gas it would expand during a climb faster than it would be absorbed, think the bends. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "RomeoMike" wrote in message ... |I think you are thinking of trapped gas after fillings are put in teeth. | In this case the air can't be readily reabsorbed and might expand at | altitude. After an extraction, any "gas" (air) would be reabsorbed | through the surrounding soft tissues and/or bone. | | Jim Macklin wrote: | | trapped gas pockets. |
An abscess is one thing, trapped air another. You were referring to the
latter in your first post. Any trapped air from an extraction is going to be long gone by the time one is fit to fly after multiple extractions requiring the use of post op pain meds and a recuperation period. Situation not similar to the bends at all. No gas is coming out of solution. Jim Macklin wrote: No, that is one possible reason with a filling, but surgery and extractions can heal over leaving an abscess and that could be a very painful problem. When my wisdom teeth were removed, the roots actually penetrated the sinus cavities. For several weeks I could have salt water run through from my mouth to my nose by dipping my head. This was not a problem flying, it was even more venting. But I would want to have a flight test before I was the only pilot on the plane. Gas would be reabsorbed if enough time passed, but if there was any gas it would expand during a climb faster than it would be absorbed, think the bends. |
OK, you're right, no possible way tissue can heal over and
create a pocket, trapping air/gas in the jaw. All pilots should plan on taking their wife and kids [husband or significant other too] on their first flight as soon as they feel good a week after the surgery. No need to a "test flight" to check for any pain in flight. The bends is gas in solution coming out of the tissue/blood faster than it can be exhaled. Of course, bacteria in a closed pocket might be producing gas at a rate that is absorbed and exhaled , but that evolved gas would expand with altitude. But you're right, no possible reason to make a comparison. -- James H. Macklin ATP,CFI,A&P "RomeoMike" wrote in message ... | An abscess is one thing, trapped air another. You were referring to the | latter in your first post. Any trapped air from an extraction is going | to be long gone by the time one is fit to fly after multiple extractions | requiring the use of post op pain meds and a recuperation period. | Situation not similar to the bends at all. No gas is coming out of solution. | | Jim Macklin wrote: | No, that is one possible reason with a filling, but surgery | and extractions can heal over leaving an abscess and that | could be a very painful problem. When my wisdom teeth were | removed, the roots actually penetrated the sinus cavities. | For several weeks I could have salt water run through from | my mouth to my nose by dipping my head. This was not a | problem flying, it was even more venting. But I would want | to have a flight test before I was the only pilot on the | plane. | | Gas would be reabsorbed if enough time passed, but if there | was any gas it would expand during a climb faster than it | would be absorbed, think the bends. | | |
![]() Jim Macklin wrote: OK, you're right, no possible way tissue can heal over and create a pocket, trapping air/gas in the jaw. I know you're trying to be facetious but that is correct...by the time that wound is healed any gas is gone, not that there really would have been much gas in there anyway because that hole gets filled in by clotted blood and fibrin and starts to organize before the gum is healed shut. Any gas got absorbed. The body just doesn't allow an empty air-filled space to persist with rare exception. The bends is gas in solution coming out of the tissue/blood faster than it can be exhaled. Certainly not the situation in this scenario. Of course, bacteria in a closed pocket might be producing gas at a rate that is absorbed and exhaled , but that evolved gas would expand with altitude. But you're right, no possible reason to make a comparison. Most infections are not gas producing. The ones that are cause life threatening illness. You'll be too sick to even think about flying. Probably if you even have a non-gas-producing infection in a closed pocket (called an abscess) you will not feel like flying. You would likely be in pain. |
Correct. My body is some strange sort of science experiment. God only gave
me 3 wisdom teath. Im opting to do all at once because as stated in a latter post if I did one or two on the first trip, I probably wouldnt return for the remaining. -- John Huthmaker PPL-SEL P-28-161 http://www.cogentnetworking.com "Grumman-581" wrote in message ... "NW_PILOT" wrote in message ... Try having 2 removed then 2 weeks later having another 2 removed with just local no gas! He's only got 3 to remove, not 4... |
At least you don't have six fingers or a tail!
Be sure to get some nice head shots, for Halloween picture postcards. Ice helps with the swelling and you will need the pain killers for 2 or 3 days if the teeth are in solid and require some major work. But it is not as bad as it was years ago. Modern dentistry is almost painless, as long as you can't hear the damn drill. "John Huthmaker" wrote in message link.net... | Correct. My body is some strange sort of science experiment. God only gave | me 3 wisdom teath. Im opting to do all at once because as stated in a | latter post if I did one or two on the first trip, I probably wouldnt return | for the remaining. | | -- | John Huthmaker | PPL-SEL P-28-161 | | http://www.cogentnetworking.com | "Grumman-581" wrote in message | ... | "NW_PILOT" wrote in message | ... | Try having 2 removed then 2 weeks later having another 2 removed with | just | local no gas! | | He's only got 3 to remove, not 4... | | | | |
("John Huthmaker" wrote)
Correct. My body is some strange sort of science experiment. God only gave me 3 wisdom teath. Im opting to do all at once because as stated in a latter post if I did one or two on the first trip, I probably wouldnt return for the remaining. Dentist said, these days he doesn't see many 46 year olds with all of their wisdom teeth. I've still got mine ...x(4). Montblack "Is it safe?" :-o |
Montblack wrote:
Dentist said, these days he doesn't see many 46 year olds with all of their wisdom teeth. I've still got mine ...x(4). As do I at 52. I was told by a dentist back when I was 17 to have mine removed... could have had it paid for by CHAMPUS. But did I? Nooooooo..... Now God only knows what it'd cost. I'm still resisting the urge. -- Mortimer Schnerd, RN VE |
I was at work the next day
"Jim Macklin" wrote in message news:YYLWf.2427$t22.1519@dukeread08... If you do it half the first time, you probably won't do the second half. "NW_PILOT" wrote in message ... | Try having 2 removed then 2 weeks later having another 2 removed with just | local no gas! | | | "John Huthmaker" wrote in message | link.net... | So this coming Tuesday I get to enjoy having 3 wisdom teath extracted (For | some reason I never grew a fourth one). Yes-I cant wait! So do I have to | put this on my next medical application as "Surgeries"? I will be going | to | see an oral surgeon to have him cut out one that has never come through | the | gums, and I will be put under (a first for me). Of course I have no plans | to do any flying for the 5-7 days I expect to be laid up medicated. I | know | it is nothing that I could be denied a medical for considering that most | people have their wisdom teath removed, but realistically do I need to put | it on my next medical application? | | -- | John Huthmaker | PPL-SEL P-28-161 | | http://www.cogentnetworking.com | | | | |
I used to do some work with the local oral surgery training program. One
day, I went into their office and they had no patients in the waiting area. The two chief residents got a curious look and then pulled me into the chair and yanked all four of mine. Afterwards, they called my wife and told her I was headed home and to take care of me. The very next day, I took them all to lunch and ate with them, no problem. It was easy. Total cost, lunch and a 1/2 gal of whiskey! "Mortimer Schnerd, RN" wrote in message ... Montblack wrote: Dentist said, these days he doesn't see many 46 year olds with all of their wisdom teeth. I've still got mine ...x(4). As do I at 52. I was told by a dentist back when I was 17 to have mine removed... could have had it paid for by CHAMPUS. But did I? Nooooooo..... Now God only knows what it'd cost. I'm still resisting the urge. -- Mortimer Schnerd, RN VE |
CFI without commercial? | Jay Honeck | Piloting | 75 | December 8th 10 04:17 PM |
Student Pilot Who Gets 5 Months for Lying on His Application for Medical | [email protected] | Home Built | 2 | June 30th 05 03:00 AM |
Sport Pilot cuts off special issuance at the knees | Juan~--~Jimenez | Home Built | 40 | August 10th 04 01:19 PM |
Question Medical | Captain Wubba | Piloting | 5 | June 11th 04 05:12 AM |
Question on medical and kidney stones | nospam | Piloting | 13 | November 8th 03 07:10 AM |
