The thread on aluminum trailer painting prompted this question. I've
seen a number of Blanik L-13s in the "original" factory finish of bare aluminum with blue trim stripes. The aluminum is always dull and mottled. Closer inspection suggests that the material is not the typical 2024 surface finish and/or is not Alclad. Has anyone been able to polish one successfully (successful meaning bright and shiny and stayed that way for some time)? Erik Mann LS8-18 (P3) |
Papa3 wrote:
The thread on aluminum trailer painting prompted this question. I've seen a number of Blanik L-13s in the "original" factory finish of bare aluminum with blue trim stripes. The aluminum is always dull and mottled. Closer inspection suggests that the material is not the typical 2024 surface finish and/or is not Alclad. Has anyone been able to polish one successfully (successful meaning bright and shiny and stayed that way for some time)? Erik Mann LS8-18 (P3) A shiny L13 would be an abnormality, and would be rejected by the thermals. They have to look like hell to fly properly ;-) Seriously - their skins appear to be made of different compounds, and have an almost random finish. The internal parts are also made of different grades and hardness of material, not directly comparable to western compounds. (At least the parts we have had to fabricate were hard to match) I would expect that the corrosion protection would be impaired by polishing. Does anyone know whether this is so? The only decent looking one I have seen is painted over the aluminium. -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above. |
Papa3 wrote:
The thread on aluminum trailer painting prompted this question. I've seen a number of Blanik L-13s in the "original" factory finish of bare aluminum with blue trim stripes. The aluminum is always dull and mottled. Closer inspection suggests that the material is not the typical 2024 surface finish and/or is not Alclad. Has anyone been able to polish one successfully (successful meaning bright and shiny and stayed that way for some time)? Erik Mann LS8-18 (P3) Each year we take ours to an open weekend to give pleasure flights. We give it a good wipe over with oil which makes it shine beautifully. Lasts for weeks afterwards. |
On 20 Apr 2006 07:44:24 -0700, "Papa3" wrote:
The thread on aluminum trailer painting prompted this question. I've seen a number of Blanik L-13s in the "original" factory finish of bare aluminum with blue trim stripes. The aluminum is always dull and mottled. Closer inspection suggests that the material is not the typical 2024 surface finish and/or is not Alclad. Has anyone been able to polish one successfully (successful meaning bright and shiny and stayed that way for some time)? Erik Mann LS8-18 (P3) I used 3M Brand Super Duty Rubbing Compound Part # 05954 on my L-13 and L-23. I used an inexpensive electric buffer. After buffing the residue needs to be wiped off with a damp cloth. Worked well and shined up nicely. I did not try to remove scratches with it, just took out the dullness of the finish. BTW, there is no silicone in the product, so no problems if you choose to paint it later. It is available at any good auto paint supply store. |
For a GREAT polish on aircraft aluminum try Nuvite. Go to their
website for info-- www.perfectpolish.com. You will need a good electric buffer and some tome--but the results are unbelieveable. Skip Guimond |
Skip (or others),
I saw this product used on a Beech 18 years ago with great results. But IIRC that was on AlClad 2024 aluminum skins. Does anyone have hands-on experience with Nuvite on a Blanyuk? I guess we could just do a small test on the underside of one wing, but I'd love to hear if anyone else has done the work for me... Erik |
![]() "Papa3" wrote in message ups.com... Skip (or others), I saw this product used on a Beech 18 years ago with great results. But IIRC that was on AlClad 2024 aluminum skins. Does anyone have hands-on experience with Nuvite on a Blanyuk? I guess we could just do a small test on the underside of one wing, but I'd love to hear if anyone else has done the work for me... I wonder what was used on this bird? http://www.soaridaho.com/Schreder/HP-14/N14LH/N14LH.htm Erik |
Wayne Paul wrote:
I wonder what was used on this bird? http://www.soaridaho.com/Schreder/HP-14/N14LH/N14LH.htm I know Todd, I'll ask him. It does take considerable work to keep it that way, it doesn't look quite that shiny lately... Marc |
Careful - If I understand correctly, the L-13s have a clear
finish; its certainly not bare aluminum. If you polish that finish off... Best to ring Vitek for his suggestions prior messing with this ! Perhaps you can post those here ? See ya, Dave |
If you do, you will have to keep at it
![]() Scott Many years polishing a Cessna 140... Papa3 wrote: The thread on aluminum trailer painting prompted this question. I've seen a number of Blanik L-13s in the "original" factory finish of bare aluminum with blue trim stripes. The aluminum is always dull and mottled. Closer inspection suggests that the material is not the typical 2024 surface finish and/or is not Alclad. Has anyone been able to polish one successfully (successful meaning bright and shiny and stayed that way for some time)? Erik Mann LS8-18 (P3) |
Blanik tire problem | Greg Arnold | Soaring | 5 | September 30th 05 06:02 PM |
Blanik L-13 for sale. | JC Cunningham | Soaring | 0 | May 25th 04 01:03 PM |
Is a Blanik L-33 rugged enough for a club? | Val | Soaring | 0 | May 14th 04 02:23 AM |
Is a Blanik L-33 rugged enough for a club? | jeff rothman | Soaring | 19 | May 13th 04 06:17 AM |
Blanik L-23 | Duane Eisenbeiss | Soaring | 8 | April 27th 04 05:53 AM |
