"BTIZ" wrote in message news:1ti3g.8790$Qz.8436@fed1read11... You "primed a few pumps", I take it this means throttle pumping (accelerator pumps?) on an already hot engine? I'd guess you did over prime and then flood the engine.. I am not sure of your engine but I presume it is also an IO-540? Always follow the POH or manufactures recommendations for your aircraft or configuration, the Aztruck may not have the same throttle body or injectors that you have. Quite! Pumping the throttle on a FI engine serves absolutely NO PURPOSE. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
Matt,
There's a little confusion in this thread. Jay's engine is a carbureted O-540, mine are IO-540's. You are correct, no need to "pump" the throttle of a FI engine, no accelerator pump. I also agree with the comment made about only pumping the throttle of a carbureted engine while cranking. Jim |
pumps?) on an already hot engine? I'd guess you did over prime and then flood the engine.. I am not sure of your engine but I presume it is also an IO-540? Nope. Pumped the primer a couple of times. (The little Coleman-lantern-style-thingie) The engine is a normally-aspirated O-540. I obviously flooded it, but I don't quite understand how this can be so, simply by starting with the mixture at idle/cut-off, rather than at full rich. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
My guess, and it's just a guess, is that you flooded the primed cylinders
while the remaining cylinders fired and operated normally, thus the roughness. As you advanced the mixture, the primed cylinders continued to be flooded but the non-primed cylinders operated normally, albeit at a possibly rich mixture. As you retarded the mixture, the primed cylinders were then able to completely burn the leaner mixture and clean themselves up. Jim "Jay Honeck" wrote in message oups.com... You "primed a few pumps", I take it this means throttle pumping (accelerator pumps?) on an already hot engine? I'd guess you did over prime and then flood the engine.. I am not sure of your engine but I presume it is also an IO-540? Nope. Pumped the primer a couple of times. (The little Coleman-lantern-style-thingie) The engine is a normally-aspirated O-540. I obviously flooded it, but I don't quite understand how this can be so, simply by starting with the mixture at idle/cut-off, rather than at full rich. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
Nope. Pumped the primer a couple of times. (The little Coleman-lantern-style-thingie) I never use the primer when the engine is even just warm. In fact, the O-540 on my Comanche cranks right up with no priming even after several days of sitting. I usually only need to prime on cold days, which isn't many in southern Georgia. If it hasn't flown for a couple of weeks and won't fire up after a few cranks then I might pump it once or twice. |
Starting the Continentals using the book procedures for big
Lycomings works fine. BTW, the procedure Jay mentions is used for Dukes and other big injected Lycs. My experience is that when hot, more than "throttle cracked" is good. Douches it out more easily if it floods Bill Hale |
On 25 Apr 2006 14:19:47 -0700, "
wrote: Starting the Continentals using the book procedures for big Lycomings works fine. BTW, the procedure Jay mentions is used for Dukes and other big injected Lycs. My experience is that when hot, more than "throttle cracked" is good. Douches it out more easily if it floods My O-540 experience is, if you're going to start it hot, shut it down with the mag switch and don't prime at all. Don |
Are Aztec engines Continentals or Lycomings?
Continentals sometimes have a fuel return line. I do not know if Lycomings do, also, but I have not seen one that does on any of the aircraft I have flown. |
we only use the manual primer on cold days.. less than 40F and never on a
warm engine I may have mistyped earlier when I referenced IO- vs O-, yes there is no throttle pump on the IO- BT "ktbr" wrote in message ... Jay Honeck wrote: Nope. Pumped the primer a couple of times. (The little Coleman-lantern-style-thingie) I never use the primer when the engine is even just warm. In fact, the O-540 on my Comanche cranks right up with no priming even after several days of sitting. I usually only need to prime on cold days, which isn't many in southern Georgia. If it hasn't flown for a couple of weeks and won't fire up after a few cranks then I might pump it once or twice. |
while the remaining cylinders fired and operated normally, thus the roughness. As you advanced the mixture, the primed cylinders continued to be flooded but the non-primed cylinders operated normally, albeit at a possibly rich mixture. As you retarded the mixture, the primed cylinders were then able to completely burn the leaner mixture and clean themselves up. This makes as much sense as anything -- thanks. I probably shouldn't have used the primer at all, but it was in that goofy, "in-between" length of time, where the engine wasn't really still "hot" -- but it wasn't really "cold" either. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
| Strange Vibrations | Al Gilson | Owning | 16 | May 13th 05 09:55 PM |
| Strange engine event | Paul Mennen | Owning | 33 | July 9th 04 04:42 AM |
| Strange one about the 296 | kage | Piloting | 0 | June 13th 04 02:42 AM |
| Strange lost-comm situation | Roy Smith | Instrument Flight Rules | 6 | May 4th 04 04:11 AM |
| Really strange going-on with radios | Roy Smith | General Aviation | 3 | March 15th 04 01:52 PM |
