#61
("Blanche Cohen" wrote)
I picked up a bunch of those 3 ft. long foam tubes in the pool area at Target for $0.99 each, cut slit in them. Didn't go with the streamers since the tubes are fluorescent colored. A bit hard to miss. Noodles. IIRC, someone on the rec.newsgroup(s) was in the business of making those - don't remember their name. Montblack |
#62
On Sun, 9 Apr 2006 09:06:54 -0700, "RST Engineering"
wrote: Instead of aluminum, use PVC water pipe. It's lighter yet and can be worked with simple tools. Jim And you glue the edges or run a bolt thru both diameters? maybe a 1/2" above ground level? - Mike |
| Have you created anything "home-made" for your plane? (or a low cost alternative?) | Andy | Piloting | 69 | April 29th 06 04:25 PM |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 03:39 AM |
| Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 04:36 AM |
| Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 01:17 AM |
