Source for Pegase 101A instrument panel
Old April 27th 06, 07:26 PM posted to rec.aviation.soaring
Default Source for Pegase 101A instrument panel
To All:
Any idea where can I buy here in the U.S. a blank instrument panel for
Pegase 101A?
Thanks,
Jacek Kobiesa
Washington State
Old April 27th 06, 08:34 PM posted to rec.aviation.soaring
Mail order here
http://www.svsp.co.uk/Shop%20Website...e_sheeting.htm ?
To All:
Pegase 101A?
Thanks,
Jacek Kobiesa
Washington State
Old April 27th 06, 10:31 PM posted to rec.aviation.soaring
Try Schleichers...the fuselage is identical to an ASW19
At 19:36 27 April 2006, Simon Waddell wrote:
Mail order here
roups.com...
To All:
Pegase 101A?
Thanks,
Jacek Kobiesa
Washington State
Old April 28th 06, 12:45 AM posted to rec.aviation.soaring
- Actually, it's a fuselage of ASW20 with a new, french designed wing.
Old April 28th 06, 08:33 PM posted to rec.aviation.soaring
Pegasus panels are normally pretty straight forward (except for the brown
color ) and can be easily made from scratch since they have no flanges or
odd curved surfaces like the Schleicher panels had......I have made many,
for many different glider types.....I prefer to use Phenolic sheet material
(essentially this can be any kind of material from paper to Kevlar set in
resins under extreme pressure......easy to machine, cut, drill and can be a
variety of colors or easily painted.....there are several sources for this
material.I use McMaster Carr.......buy by the sheet in many sizes and
thickness.....1/8"thick 24" 24" square should give your Pegasus 2 panels
(the first one that you screw up and a second one that is perfect! )
tim
Wings & Wheels
www.wingsandwheels.com
To All:
Pegase 101A?
Thanks,
Jacek Kobiesa
Washington State
Definition of simulated instrument conditions bsalai Instrument Flight Rules 14 February 4th 06 11:33 PM
Instrument panel labelling options John Galban Home Built 12 November 18th 04 10:42 PM
CNC or Laser cut instrument panel Bill Daniels Home Built 18 October 16th 04 12:06 PM
Aluminum instrument panel finish? Richard Riley Home Built 31 February 4th 04 02:09 AM
CAD outline of Rans S6S instrument panel? Rob Turk Home Built 2 October 21st 03 09:27 PM
