Learning from an owner annual
Old May 16th 06, 04:20 AM posted to rec.aviation.piloting,rec.aviation.owning
Default Learning from an owner annual
I don't mind setting it up and writing it, but I'd prefer it not be a subset of the RST webpage (i.e.
www.rstengineering.com/ownerannual or something like that). How can we do this on the cheap, whether it be a
standalone or a subset of some other website?
Maybe Jay's folks could sponsor it?
I think you mean "Javier's folks"! (As in, two levels up in this
thread.)
Jav kindly provides server space for our webpage(s)...and it sounds
like he's about to start doing something for A&Ps and IAs, too...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #62
Old May 16th 06, 04:24 AM posted to rec.aviation.piloting,rec.aviation.owning
So next year do the bulk of the annual on the 31st of March and screw in the
last nutplate on the 1st of April, when the signing takes place. Following
year 30th of April and the 1st of May. Now your annual is due in May. Or
June. Or July. Whatever fires your rocket.
We had actually started down that road, and realized that we were
moving our annual dangerously close to the sancrosanct Oshkosh Month of
July. We also didn't want to lose and of our precious warm weather
flying to an extended annual inspection.
The thought of missing OSH because of something stupid like waiting for
a part has caused us to actually move the annual UP a month this year,
just to get it safely back into the bad flying weather of March.
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #63
Old May 16th 06, 04:53 AM posted to rec.aviation.piloting,rec.aviation.owning
("Jay Honeck" wrote)
The thought of missing OSH because of something stupid like waiting for a
part has caused us to actually move the annual UP a month this year, just
One word: Courtesy van!
Mont Black
http://pg.photos.yahoo.com/ph/landof10klakes/detail?.dir=/7012re2&.dnm=877ere2.jpg&.src=ph
  #64
Old May 16th 06, 05:18 AM posted to rec.aviation.piloting,rec.aviation.owning
Setup a progressive schedule, do the annual in small steps
every month. Write your own manual and have the FAA approve
it.
§ 91.409 Inspections.
(d) Progressive inspection. Each registered owner or
operator of an aircraft desiring to use a progressive
inspection program must submit a written request to the FAA
Flight Standards district office having jurisdiction over
the area in which the applicant is located, and shall
provide-
(1) A certificated mechanic holding an inspection
authorization, a certificated airframe repair station, or
the manufacturer of the aircraft to supervise or conduct the
progressive inspection;
(2) A current inspection procedures manual available and
readily understandable to pilot and maintenance personnel
containing, in detail-
(i) An explanation of the progressive inspection, including
the continuity of inspection responsibility, the making of
reports, and the keeping of records and technical reference
material;
(ii) An inspection schedule, specifying the intervals in
hours or days when routine and detailed inspections will be
performed and including instructions for exceeding an
inspection interval by not more than 10 hours while en route
and for changing an inspection interval because of service
experience;
(iii) Sample routine and detailed inspection forms and
instructions for their use; and
(iv) Sample reports and records and instructions for their
use;
(3) Enough housing and equipment for necessary disassembly
and proper inspection of the aircraft; and
(4) Appropriate current technical information for the
aircraft.
The frequency and detail of the progressive inspection shall
provide for the complete inspection of the aircraft within
each 12 calendar months and be consistent with the
manufacturer's recommendations, field service experience,
and the kind of operation in which the aircraft is engaged.
The progressive inspection schedule must ensure that the
aircraft, at all times, will be airworthy and will conform
to all applicable FAA aircraft specifications, type
certificate data sheets, airworthiness directives, and other
approved data. If the progressive inspection is
discontinued, the owner or operator shall immediately notify
the local FAA Flight Standards district office, in writing,
of the discontinuance. After the discontinuance, the first
annual inspection under §91.409(a)(1) is due within 12
calendar months after the last complete inspection of the
aircraft under the progressive inspection. The 100-hour
inspection under §91.409(b) is due within 100 hours after
that complete inspection. A complete inspection of the
aircraft, for the purpose of determining when the annual and
100-hour inspections are due, requires a detailed inspection
of the aircraft and all its components in accordance with
the progressive inspection. A routine inspection of the
aircraft and a detailed inspection of several components is
not considered to be a complete inspection.
The FAA has "boiler plate" outlines, it isn't as hard as it
sounds.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Jay Honeck" wrote in message
is due in May. Or
we were
Oshkosh Month of
warm weather
like waiting for
month this year,
March.
| Jay Honeck
| Iowa City, IA
| Pathfinder N56993
  #65
Old May 16th 06, 12:15 PM posted to rec.aviation.piloting,rec.aviation.owning
I can host it at aviating.com, gratis.
I'll email you about it and maybe we can get started.
-jav
of the RST webpage (i.e. www.rstengineering.com/ownerannual or something
like that). How can we do this on the cheap, whether it be a standalone or
"Javier" wrote in message
Do you s'pose a website dedicated to names & contact info for IAs that
will do owner assisted annuals would be a good thing? Maybe with a
little info about the mech like price structure, do it in your own
hangar, etc?
That'd be superrific!
How can I help get this online?
-jav
  #66
Old May 16th 06, 12:18 PM posted to rec.aviation.piloting,rec.aviation.owning
Montblack wrote:
(".Blueskies." wrote)
Jay needs to consider (somehow) separating that enormously popular video
page of his ...from the Inn's $$$ making page.
"The server is down" (whatever the message is) --- more than once in a
while these days.
Yes, it was, but it's now fixed (famous last words).
It all resulted from an ATA device driver that didn't like the
combination of ATA controller and disk drive that was newly installed on
Friday 5/5.
Ironically, the new drive was graciously donated by Jay, since the
aviation videos section was taking so much disk space!
-jav
  #67
Old May 16th 06, 01:08 PM posted to rec.aviation.piloting,rec.aviation.owning
We drove into OSH from 1984 through 1998. Nothing against it, but it's
just not the same as flying and camping in the middle of 12,000 other
aircraft campers.
THAT is OSH, to me, now. The airshows and stuff are still fun, but the
North 40 is what grass-roots aviation is all about. So, we try to
make sure that Atlas is in tip-top shape every July, for that long, 90
minute flight back to Wittman Field...
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #68
Old May 16th 06, 04:29 PM posted to rec.aviation.piloting,rec.aviation.owning
("Javier" wrote)
High Anxiety (1977) Directed-Written-Starring ...Mel Brooks
[Attempting to lift a heavy suitcase]
Brophy: "I got it. I got it. I got it."
[thump]
Brophy: "I ain't got it." g
Jav - Thanks for doing the heavy lifting. Much appreciated by the
rec.aviation group, I can assure you!
Montblack :-)
[Credits and title music end as Thorndyke exits the airport]
Dr. Richard H. Thorndyke: "What a dramatic airport."
  #69
Old May 16th 06, 05:03 PM posted to rec.aviation.piloting,rec.aviation.owning
Montblack wrote:
("Javier" wrote)
[thump]
Yes. Multiple times. One of my all time favorite movies.
You're just saying that.
Anyway, it's my little contribution to the betterment of general
aviation, and in fact, the world whole.
-jav
  #70
Old May 16th 06, 05:10 PM posted to rec.aviation.piloting,rec.aviation.owning
I've found the 13 month annual to be way over-rated. The problem is
your annual eventually ends up in the best flying times of year. I've
been doing 11 month annuals trying to move it back into winter.
-Robert
2006 Annual -- My 8th Owner Assisted -- Update Jay Honeck Owning 14 March 27th 06 07:11 PM
molding plexiglas websites? [email protected] Owning 44 February 17th 05 09:33 PM
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
Which aircraft certification is required for R&D? Netgeek Home Built 5 November 23rd 04 05:59 AM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
