High Efficiency APU
Old May 23rd 06, 03:46 AM posted to rec.aviation.homebuilt
Default High Efficiency APU
Hello,
I'm looking for a high efficiency Aux Power Unit. I'm actually
building a electric car, and want some way to recharge besides plugging
in. I'd like to go with a microturbine/turbine for both space and
efficiency concerns. I'm looking for anything over 30 kW of power,
with efficiency being my main concern. Gas stations havent started
stocking Jet-A, so I guess you can add that to the list of
requirements.
I'll probably be using my own alternator/generator, a secondary 40kW
unit, but I couldnt complain too much if the unit came with one.
Any sort of links at all would be really useful. You guys are really
the only domain I know of that might be able to help with something
like this. Even links to other good message boards would be great. I
really appreciate it!
Thanks mates,
McCoy.
Old May 23rd 06, 05:19 AM posted to rec.aviation.homebuilt
Assuming that your interest in some kind of fuel efficiency why not
consider one of the small Wankels? They can be had in the power range
you are looking for and are far more fuel efficient than a turbine.
Weight and size is not that much different either.
http://www.rotary-xr40.com/rotary3.htm
There are also Wankel powered aircraft APU's available, but the price
is steep.
Leon McAtee
Old May 23rd 06, 06:07 AM posted to rec.aviation.homebuilt
Unfortunately, neither Wankel or small turbines are very efficient.
Best bet currently is a diesel, but they are not especially light.
tom
Old May 23rd 06, 04:33 PM posted to rec.aviation.homebuilt
"fake mccoy" wrote in message
Hello,
requirements.
Thanks mates,
McCoy.
At 30 KW, the Capstone turbine would fit your bill.
Only one moving part, can be set up for diesel or natural gas.
Pricey, though.
http://www.microturbine.com/
Tim Ward
Old May 23rd 06, 09:38 PM posted to rec.aviation.homebuilt
Capstone hides their fuel specific pretty well, but you can tease it
out. .57 lb/hp/hr. Very good for a small turbine with a single stage
compressor - but even an awful 4 stroke piston engine should be about
..45. A serious stratified charge engine can get down around .33. I
think the record is about .25.
The Capstone uses some very clever air bearings, but they won't stand
up to any gyroscopic force. Put them in an airplane and try to turn,
you'll crash the bearings.
Old May 23rd 06, 11:06 PM posted to rec.aviation.homebuilt
The OP does explicitly say that this is for use to recharge an electric
vehicle instead of plugging into the mains, so that won't be an issue.
However, if I was making an electric vehicle with an APU, I'd certainly
want it to be able to run 'direct', too.
Even the best batteries only put out what, 75% of the charge put into
them.
Running direct means that you can in principle get 25% better mileage
out of the same amount of fuel, save some wear and tear on the
batteries, and not have to stop so often.
Old May 24th 06, 02:59 AM posted to rec.aviation.homebuilt
"Ian Stirling" wrote in message
them.
Lead-acid puts out about 75%, Lithium can go as high as 95%.
Capstone has already installed them in buses, so ground vehicle apps aren't
ground-breaking.
Old May 24th 06, 01:19 PM posted to rec.aviation.homebuilt
snip
them.
Well - there will be some losses in the converter - even if it's a
couple of percent either way, that's close to 10% power loss.
I diddn't know that lithium was that high.
ground-breaking.
Unless it's an electric earthmover
(I have seen one, but it was marketed for use by 5-8 year olds)
Winter mechanical vario reading high Alan Meyer Soaring 13 April 13th 06 03:38 AM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Viagra and the Mile High Club Cub Driver Piloting 17 May 28th 04 10:22 PM
AIM-54 Phoenix missile Sujay Vijayendra Military Aviation 89 November 3rd 03 10:47 PM
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS MT. DIABLO HIGH SCHOOL PHOTOS Home Built 1 October 13th 03 04:35 AM
