I am learning to fly a Blanik L-23 and my instructor is telling me to
"fly it on" with no flare. 1) I am commercial/instrument rated with somewhere north of 1000 ASEL and a few ASES landings in my logbook. I am _programmed_ to flare. :-) To not flare is very hard for me. 2) The Blanik AFM refers to flaring on landing. 3) The instructor is very concerned about the fragility of the tail wheel, so possibly this is the reason for his technique. So ... to flare or not? When solo, I mean. BTW, this is pretty neat stuff. I wish my first few hours of training had been in a glider. Certainly I would have learned to use the rudder much sooner! |
![]() This is one of those areas, such as hard vs. soft tow release, square vs. cut corner pattern, side slip vs. crab, how to remove slack in tow line, etc. where every instructor is likely to have a different opinion on what is the right way to do it. Best to just follow your intructors orders, then do what you want after you get your ticket. Mitty wrote: I am learning to fly a Blanik L-23 and my instructor is telling me to "fly it on" with no flare. 1) I am commercial/instrument rated with somewhere north of 1000 ASEL and a few ASES landings in my logbook. I am _programmed_ to flare. :-) To not flare is very hard for me. 2) The Blanik AFM refers to flaring on landing. 3) The instructor is very concerned about the fragility of the tail wheel, so possibly this is the reason for his technique. So ... to flare or not? When solo, I mean. BTW, this is pretty neat stuff. I wish my first few hours of training had been in a glider. Certainly I would have learned to use the rudder much sooner! |
Maybe his interpretation of "no flare" just means level off, then
settle onto the runway. Maybe. Oh, yeah this IS great stuff. Pure mainlining. Have fun, start shopping! Mitty wrote: I am learning to fly a Blanik L-23 and my instructor is telling me to "fly it on" with no flare. 1) I am commercial/instrument rated with somewhere north of 1000 ASEL and a few ASES landings in my logbook. I am _programmed_ to flare. :-) To not flare is very hard for me. 2) The Blanik AFM refers to flaring on landing. 3) The instructor is very concerned about the fragility of the tail wheel, so possibly this is the reason for his technique. So ... to flare or not? When solo, I mean. BTW, this is pretty neat stuff. I wish my first few hours of training had been in a glider. Certainly I would have learned to use the rudder much sooner! |
"Mitty" wrote in message
... I am learning to fly a Blanik L-23 and my instructor is telling me to "fly it on" with no flare. 1) I am commercial/instrument rated with somewhere north of 1000 ASEL and a few ASES landings in my logbook. I am _programmed_ to flare. :-) To not flare is very hard for me. 2) The Blanik AFM refers to flaring on landing. 3) The instructor is very concerned about the fragility of the tail wheel, so possibly this is the reason for his technique. So ... to flare or not? When solo, I mean. BTW, this is pretty neat stuff. I wish my first few hours of training had been in a glider. Certainly I would have learned to use the rudder much sooner! Could he be concerned that you will do a tailwheel first landing if you attempt a more tricycle gear type "full stall" landing (I assume that is what you are used to doing)? Perhaps he is shooting for something like a "wheel landing" where you touch down above the stall speed on the mains of a taildragger? That still involves a flare - but not as much, and not holding off until you get close to the stall speed - just level it off and set it down. I assume that you still pretty much slow the descent rate down before touchdown? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
![]() Mitty wrote: I am learning to fly a Blanik L-23 and my instructor is telling me to "fly it on" with no flare. 1) I am commercial/instrument rated with somewhere north of 1000 ASEL and a few ASES landings in my logbook. I am _programmed_ to flare. :-) To not flare is very hard for me. 2) The Blanik AFM refers to flaring on landing. 3) The instructor is very concerned about the fragility of the tail wheel, so possibly this is the reason for his technique. So ... to flare or not? When solo, I mean. BTW, this is pretty neat stuff. I wish my first few hours of training had been in a glider. Certainly I would have learned to use the rudder much sooner! The main answer is 3. The rubber 'donuts' in the tail wheel fail from rough contact and banging by overbraking on the main gear putting the glider on its nose. The little ground contact bubble under the nose is likely scraped also. If the donuts fail, the resulting collapse may damage the surround which is relatively expensive. The donuts should be inspected daily and after each tail slam. The instructor is postponing the inevitable. In general, two-pointing your landing is preferred and low energy landings when landing out on XC flights are highly desirable. Soaring is the domain of the seeker. Words mostly fail to convey the experience to the uninitiated. If you keep seeking, you'll explore places and see sights most uncommon. Welcome aboard. Frank Whiteley |
... I am learning to fly a Blanik L-23 and my instructor is telling me to "fly it on" with no flare. 1) I am commercial/instrument rated with somewhere north of 1000 ASEL and a few ASES landings in my logbook. I am _programmed_ to flare. :-) To not flare is very hard for me. 2) The Blanik AFM refers to flaring on landing. 3) The instructor is very concerned about the fragility of the tail wheel, so possibly this is the reason for his technique. So ... to flare or not? When solo, I mean. BTW, this is pretty neat stuff. I wish my first few hours of training had been in a glider. Certainly I would have learned to use the rudder much sooner! Almost every aircraft will have its own "best" runway contact attitude. The L-23 works best with a "wheel" landing in which the fragile tailwheel doesn't touch down until the glider has slowed its rollout considerably. Your instructor has the right idea. In the case of most gliders and the L-23 in particular, 'flare' means to simply arrest the decent so the glider is skimming along just above the runway in level flight while losing airspeed. As airspeed is lost, the nose must be raised (AOA increased) to maintain height a few inches above the runway surface. The runway contact attitude (and the touchdown airspeed) is determined by how much the nose is raised before the wheel is allowed to touch the runway surface. In the case of the L-23, this isn't much. To get a picture of this attitude, strap in and have someone lift the tailwheel a few inches above the runway. Don't raise the nose more than this before allowing the main wheel to touch down. Bill Daniels |
![]() Mitty wrote: I am learning to fly a Blanik L-23 and my instructor is telling me to "fly it on" with no flare. Listen to the instructor. 1) I am commercial/instrument rated with somewhere north of 1000 ASEL and a few ASES landings in my logbook. I am _programmed_ to flare. :-) To not flare is very hard for me. Well learn a new technique...Its easy and fun. The normal landing is similar to a wheel landing in a conventional (tail wheel) airplane. 2) The Blanik AFM refers to flaring on landing. Yes but read further on and remember that sometimes Czech, Chinese, or Japanese translations miss some of the meaning. The manual goes on to say that you should touch down on the main gear first and then let the tail wheel come down (gently.) The easy way to do that is to just ease back enough to stop the sink just before you touch down. Then, once its down, hold the stick full back, especially if you think you will need to use the wheel brake. 3) The instructor is very concerned about the fragility of the tail wheel, so possibly this is the reason for his technique. Yes. The old Blanik L-13s were worse but you still need to try be easy on the tail wheel. So ... to flare or not? When solo, I mean. No need to flare at all, just arrest the sink rate and touch down on the main wheel. The exception would be if you have to get into a short field in which case you will need a minimum airspeed (energy) touch down and landing so you can get stopped. In that case, the tail wheel may touch down first. But that's the exception. -- Peter D. Brown http://home.gci.net/~pdb/ http://groups.yahoo.com/group/akmtnsoaring/ |
Just a thought...............I noticed your remark about wishing you
had learnt to use a rudder before? Di you by chance learn on a hang-glider. A "flare" in a hg is NOT the same thing when the terminology is applyied to gliders. You don't want to raise the nose to get airspeed down and then "stall" it on...like you would in a hangie. Cheers Mark |
Mitty,
I just got done looking through the Pilots Notes for the L-13, looking for a 'wheel landing' recommendation. I couldn't find it, but I feel it's in there some where. I can tell you the POH for L-33 specifically states to 'land on the main wheel before the tail wheel'. I think in general, Let products are designed for 'wheel landing'. I can tell you from experience, if you flair an L-13 or an L-33 close to the ground, you are very likely to strike the the tail boom on the ground, very hard, way before the main wheel. Sincerely, David Walsh Mitty wrote: I am learning to fly a Blanik L-23 and my instructor is telling me to "fly it on" with no flare. 1) I am commercial/instrument rated with somewhere north of 1000 ASEL and a few ASES landings in my logbook. I am _programmed_ to flare. :-) To not flare is very hard for me. 2) The Blanik AFM refers to flaring on landing. 3) The instructor is very concerned about the fragility of the tail wheel, so possibly this is the reason for his technique. So ... to flare or not? When solo, I mean. BTW, this is pretty neat stuff. I wish my first few hours of training had been in a glider. Certainly I would have learned to use the rudder much sooner! |
Hi,
I have ripped two tailwheels off of Blanik's over the years. It is a weakness of the design as you normaly should be able to do a nice "two point" low energy landing with a flare to the landing attitude. The POH operational procedure ammends this practice to do a "wheel landing" This is a common landing for tail wheel airplanes, and if you get a chance to fly a Cub or similar tailwheel airplane you will get the idea. The Blanik is a great trainer in many ways. There is an improved tailwheel on the new L-23's that is fixed and does not caster. The AF Academy has them in this configuration. With the improved normal tailwheel. I think normal low energy landings could be taught. Be gentel with the tailwheel and don't push it backward over rough ground. See Saftey Advisory 01-1 at http://www.soaringsafety.org/prevention/advisory.html Jeff Banks |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
