Time to replace the KNS-80
Old June 1st 06, 01:56 AM posted to rec.aviation.owning
Default Time to replace the KNS-80
Well it looks like it's about time to replace the old KNS-80 RNAV.
That thing has had a lot of use, it's getting old, and it's been in
the shop a number of times.
Currently the frequency selector appears to need cleaning, but I'm not
sure how long it has left.
So, I'm looking into a certified GPS that will fill the hole left by
the KNS-80. It's also going to need to drive the GS/Localizer head.
Not being current on GPSs I see what appear to be a number that would
probably work.
Any socially acceptable suggestions?
www.rogerhalstead.com
Old June 1st 06, 03:33 AM posted to rec.aviation.owning
probably work.
I presume you want to use it for RNAV approaches.
A used Garmin 430 is probably your best bet. There are cheaper IFR GPS's
available, but they require external annunciators that are costly to install
and they don't include VOR/LOC or the nice COM radio built into the 430.
You are going to have to buy a CDI for the GPS anyway, so you might as well
get one with a glide slope and hook it to the 430.
If you look around, you might find a GPS-only Garmin 400 for less money.
Dan
C172RG at BFM
Old June 1st 06, 05:24 AM posted to rec.aviation.owning
You might consider picking up a used KNS-80. I have seen many for sale
on eBay -
some yellow tagged. You can probably get a nice one for $500 - $750. I
bought one
to replace my old unit - which was not economically repairable - and
have been happy with it.
David Johnson
Old June 1st 06, 06:12 AM posted to rec.aviation.owning
Without question, a Garmin 430. I recently saw an avionics shop ad for
$7900, installed, including the required GI-106A.
Best,
Karl
"Roger" wrote in message
probably work.
Old June 1st 06, 05:06 PM posted to rec.aviation.owning
Roger, I imagine that your KNS-80 is currently coupled to a Bendix/King
KI-206 VOR/ILS indicator/resolver. If so, I think it is true that the
Garmin 430 will drive this indicator, without the need for replacing the
indicator.
DL
"karl gruber" wrote in message
Best,
Karl
probably work.
Old June 3rd 06, 06:08 AM posted to rec.aviation.owning
On Thu, 01 Jun 2006 15:06:53 GMT, "DL"
indicator.
Yes, it is.
I also have the S-Tec 50 coupled to the KNS-80 and would hope it's
possible to do that with the 430 or what ever I end up using.
I keep thinking that they will be replacing the 430 with something
newer and more flexible, or just different. It has been out long
enough for something else to be coming along.
Thanks all,
DL
Best,
Karl
probably work.
Old June 3rd 06, 01:33 PM posted to rec.aviation.owning
On Wed, 31 May 2006 19:56:17 -0400, Roger
probably work.
The GNS480 is currently WAAS enabled under TSO146. It also has airways in
the database that you can conveniently use for entering flight plans,
unlike the 430 or 530.
Since it is under TSO146, there are some other advantages vs. the TSO129
(non-WAAS units). These are mentioned in the AIM.
Old June 3rd 06, 10:03 PM posted to rec.aviation.owning
I agree. If I were to install a certified IFR GPS right now, it would
be the 480. Having vertical guidance on GPS approaches is pretty neat
and its the only one that will do it.
Old June 4th 06, 11:49 AM posted to rec.aviation.owning
Yes, that is really a neat feature, even on the LNAV approaches.
Unfortunately, living about as far east as one can get and still be in the
US, it's not been available at my local airport (KEPM) since they started
fu^H^H moving satellite 122 to the west. I can't receive the WAAS bird
well enough for an acceptable VPL below about 1500'MSL. (I did have it for
a few months, before they started to move it).
Hopefully, the planned satellite launch in October will take place, and
restore a satisfactory signal here.
And it's not the military. From what I've read, this particular WAAS
signal comes from a privately leased satellite, and the owners decided to
move it west.
Old June 5th 06, 02:55 PM posted to rec.aviation.owning
Nobody knows what "they" are doing or planning to do, but you can replace yours
with a GNS480. Way ahead of the 430 IMO.
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 08:04 PM
Safety pilot - logging cross-country S Herman Instrument Flight Rules 42 December 15th 05 08:27 PM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 01:18 AM
Retroactive correction of logbook errors Marty Ross Piloting 10 July 31st 03 07:44 AM
