When was the last time you used your ADF?
Old June 7th 06, 03:35 AM posted to rec.aviation.ifr
Default When was the last time you used your ADF?
Hello all,
I'm just curious as to when the last time was that you used your ADF
for actual navigation? Are NDBs common in the US? It seems as though
every little airport has an ILS!
-dr
Old June 7th 06, 04:12 AM posted to rec.aviation.ifr
wrote in message oups.com...
Hello all,
-dr
Last Saturday.
And the Sunday before that.
And on most of my cross-country flights, generally.
But ~90% of my ADF usage is supplementary to other navigation.
The needle swing when passing an LOM is supplementary, to me.
So also, is using the ADF to be ready for a clearance direct to the airport,
while being radar vectored and expecting a visual approach.
(The latter is exactly how I used my ADF last Saturday.)
Old June 7th 06, 04:52 AM posted to rec.aviation.ifr
"Nathan Young" wrote in message
I use it almost every flight for AM radio, not so much for instrument
flying, although two of my more frequently used airports (CMI -
Champaign, and RFD - Rockford) have LOMs on the ILS, so I occasionally
actually use one for navigation.
I often use LOMs on ILS approaches too. Seeing that the CDI and ADF lean in
opposite directions is an easy way to double-check that you're being
properly vectored for the approach.
--Gary
Old June 7th 06, 05:28 AM posted to rec.aviation.ifr
The ADF works great with AM broadcast for VFR long range
direct. Before the days of LORAN and GPS, tracking to some
50,000 Watt clear channel radio was the accepted method.
Even works for practicing all those techniques that are
never used in the real ATC world of IFR, such as time and
distance, bearing change, etc.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Gary Drescher" wrote in message
message
for instrument
(CMI -
I occasionally
CDI and ADF lean in
you're being
| --Gary
Old June 7th 06, 08:26 AM posted to rec.aviation.ifr
I wasn't sure, so I checked my plane. It doesn't seem to have an ADF.
I used to use them occasionally for listening to ball game scores. I
guess that need hasn't arisen since I've had my plane.
Old June 7th 06, 02:57 PM posted to rec.aviation.ifr
I've been flying instruments for over 10 years. I've never flown a single
NDB approach in anger (i.e. other than in training or to pass a checkride)
in all that time. Of course, that reflects the kind of flying I do;
somebody based at a field with only an NDB approch would obviously have a
different story to tell. We pulled all the ADFs out of our club planes a
bunch of years ago.
I used to use it a lot on X/C trips (VFR or IFR), to tune in NDBs near my
route as a double-check on my navigation.
Before we had GPS, I found tuning in the LOM to be a useful situational
awareness aid on an ILS (if the CDI and ADF needles are pointed in opposite
directions while intercepting the localizer, you're going to intercept
outside the LOM, which is a good thing).
But all that's in the past. At this point, I can't imagine doing any
serious IFR flying without a GPS, and once you've got a GPS, there's just
absolutely no need for an ADF anymore (except for those very rare
exceptions of fields which only have an NDB approach and no GPS overlay,
and even then I'm not sure I'd be able to resist the urge to cheat).
Old June 7th 06, 03:24 PM posted to rec.aviation.ifr
.... and the occasional field where the ATIS/AWOS is on the NDB frequency.
Instruement checkride...for real this time (long) Jack Allison Piloting 28 February 28th 06 04:26 AM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Gyrocopter Speed Mark Rotorcraft 36 August 17th 05 12:28 AM
American nazi pond scum, version two bushite kills bushite Naval Aviation 0 December 21st 04 11:46 PM
