Folks - 43-13-1B says an inner sleeve can be up to 1/16th inch smaller
	in diameter than the ID of the original tubing. When you slip the inner tube inside the original tube 1/16th turns into a lot of slop. Do you make any attempt to center the inner tube in the original tubing? If so, how? - Mike  |
On Wed, 07 Jun 2006 16:00:05 -0400, Michael Horowitz
	wrote: Folks - 43-13-1B says an inner sleeve can be up to 1/16th inch smaller in diameter than the ID of the original tubing. When you slip the inner tube inside the original tube 1/16th turns into a lot of slop. Do you make any attempt to center the inner tube in the original tubing? If so, how? - Mike Simplest method is to slit the tube and expand it to fit snuggly, or better slit a tube that is too large to fit (like a piece of the tube being sleeved) and squeeze it down to fit. Then drill both ends being joined in 2 or 3 places, evenly around the tube, and rosette weld as well as welding the butt, which can also be scarfed to make a stronger weld. -- Posted via a free Usenet account from http://www.teranews.com  |
On Wed, 07 Jun 2006 17:28:01 -0400, clare at snyder.on.ca wrote:
	On Wed, 07 Jun 2006 16:00:05 -0400, Michael Horowitz wrote: Folks - 43-13-1B says an inner sleeve can be up to 1/16th inch smaller in diameter than the ID of the original tubing. When you slip the inner tube inside the original tube 1/16th turns into a lot of slop. Do you make any attempt to center the inner tube in the original tubing? If so, how? - Mike Simplest method is to slit the tube and expand it to fit snuggly, or better slit a tube that is too large to fit (like a piece of the tube being sleeved) and squeeze it down to fit. Then drill both ends being joined in 2 or 3 places, evenly around the tube, and rosette weld as well as welding the butt, which can also be scarfed to make a stronger weld. Outstanding! That would solve my problem! Hate to sound ungrateful but could you point to a reference that allows this. Please don't take offence, but I'm going to have to describe what I've done to my supervisory A&P and then to someone with an IA - Mike  |
On Wed, 07 Jun 2006 20:25:38 -0400, Michael Horowitz
	wrote: On Wed, 07 Jun 2006 17:28:01 -0400, clare at snyder.on.ca wrote: On Wed, 07 Jun 2006 16:00:05 -0400, Michael Horowitz wrote: Folks - 43-13-1B says an inner sleeve can be up to 1/16th inch smaller in diameter than the ID of the original tubing. When you slip the inner tube inside the original tube 1/16th turns into a lot of slop. Do you make any attempt to center the inner tube in the original tubing? If so, how? - Mike Simplest method is to slit the tube and expand it to fit snuggly, or better slit a tube that is too large to fit (like a piece of the tube being sleeved) and squeeze it down to fit. Then drill both ends being joined in 2 or 3 places, evenly around the tube, and rosette weld as well as welding the butt, which can also be scarfed to make a stronger weld. Outstanding! That would solve my problem! Hate to sound ungrateful but could you point to a reference that allows this. Please don't take offence, but I'm going to have to describe what I've done to my supervisory A&P and then to someone with an IA - Mike I think it is called out in AC134. It is also in an old tome called Airplane and Engine Maintenance for the Airplane Mechanic, by Brimm and Boggess published in 1936 on page 201, reference figure IV. For rosette welds, only the OUTER tube is drilled. A scarfed or fishmouthed joint is called for in this refference rather than a straight butt joint. If you want the job to be easier to inspect, keep a sufficient gap between the ends that it is possible for the inspector to tell you have good penetration into the sleave. If you do this you will also want to weld the slit in the sleave. A simpler, but messier looking repair is using the sleave on the OUTSIDE of the tube.. -- Posted via a free Usenet account from http://www.teranews.com  |
			 clare wrote: On Wed, 07 Jun 2006 20:25:38 -0400, Michael Horowitz wrote: On Wed, 07 Jun 2006 17:28:01 -0400, clare at snyder.on.ca wrote: On Wed, 07 Jun 2006 16:00:05 -0400, Michael Horowitz wrote: Folks - 43-13-1B says an inner sleeve can be up to 1/16th inch smaller in diameter than the ID of the original tubing. When you slip the inner tube inside the original tube 1/16th turns into a lot of slop. Do you make any attempt to center the inner tube in the original tubing? If so, how? - Mike Simplest method is to slit the tube and expand it to fit snuggly, or better slit a tube that is too large to fit (like a piece of the tube being sleeved) and squeeze it down to fit. Then drill both ends being joined in 2 or 3 places, evenly around the tube, and rosette weld as well as welding the butt, which can also be scarfed to make a stronger weld. Outstanding! That would solve my problem! Hate to sound ungrateful but could you point to a reference that allows this. Please don't take offence, but I'm going to have to describe what I've done to my supervisory A&P and then to someone with an IA - Mike I think it is called out in AC134. It is also in an old tome called Airplane and Engine Maintenance for the Airplane Mechanic, by Brimm and Boggess published in 1936 on page 201, reference figure IV. For rosette welds, only the OUTER tube is drilled. A scarfed or fishmouthed joint is called for in this refference rather than a straight butt joint. If you want the job to be easier to inspect, keep a sufficient gap between the ends that it is possible for the inspector to tell you have good penetration into the sleave. If you do this you will also want to weld the slit in the sleave. A simpler, but messier looking repair is using the sleave on the OUTSIDE of the tube.. -- Did you mean AC 43-13-1B? Rewelding a piece of tubing is discussed when doing an external splice to streamlined tubing for sure, but I'm not sure splitting and rewelding an _inner_ sleeve is discussed. For a variety of reasons this should be a smooth repair - Mike  |
FYI - I talked with an IA on the splitting of tube to reduce its
	diameter. He said nothing doing on a certificated aircraft. - Mike On Wed, 07 Jun 2006 22:32:10 -0400, clare at snyder.on.ca wrote: On Wed, 07 Jun 2006 20:25:38 -0400, Michael Horowitz wrote: On Wed, 07 Jun 2006 17:28:01 -0400, clare at snyder.on.ca wrote: On Wed, 07 Jun 2006 16:00:05 -0400, Michael Horowitz wrote: Folks - 43-13-1B says an inner sleeve can be up to 1/16th inch smaller in diameter than the ID of the original tubing. When you slip the inner tube inside the original tube 1/16th turns into a lot of slop. Do you make any attempt to center the inner tube in the original tubing? If so, how? - Mike Simplest method is to slit the tube and expand it to fit snuggly, or better slit a tube that is too large to fit (like a piece of the tube being sleeved) and squeeze it down to fit. Then drill both ends being joined in 2 or 3 places, evenly around the tube, and rosette weld as well as welding the butt, which can also be scarfed to make a stronger weld. Outstanding! That would solve my problem! Hate to sound ungrateful but could you point to a reference that allows this. Please don't take offence, but I'm going to have to describe what I've done to my supervisory A&P and then to someone with an IA - Mike I think it is called out in AC134. It is also in an old tome called Airplane and Engine Maintenance for the Airplane Mechanic, by Brimm and Boggess published in 1936 on page 201, reference figure IV. For rosette welds, only the OUTER tube is drilled. A scarfed or fishmouthed joint is called for in this refference rather than a straight butt joint. If you want the job to be easier to inspect, keep a sufficient gap between the ends that it is possible for the inspector to tell you have good penetration into the sleave. If you do this you will also want to weld the slit in the sleave. A simpler, but messier looking repair is using the sleave on the OUTSIDE of the tube..  |
On Sat, 10 Jun 2006 19:52:06 -0400, Michael Horowitz
	wrote: FYI - I talked with an IA on the splitting of tube to reduce its diameter. He said nothing doing on a certificated aircraft. - Mike splitting the original tube I can understand, but splitting the insert tube, especially if it is welded up again. huh? the trouble in repair work is that if the guy has little appreciation of structural engineering and the actual forces the part will see in service quite often you will see a lapse into a position of comfort that may only be held because it has never been tested. very frustrating. maybe try a grab bag of tube scraps from Aircraft Spruce to see whether you get a useable piece. Stealth Pilot  |
			 Structural tube sizes are usually 5/8" or larger, which are available in 0.120" wall thickness. Buy 0.120" wall in the same diameter as the tube you're splicing, chuck it in the lathe, turn it to the desired slip fit OD. Dan Horton  |
| Welding question - | Michael Horowitz | Restoration | 11 | September 7th 06 04:52 PM |
| Aluminum welding | Ernest Christley | Home Built | 5 | April 24th 06 12:47 PM |
| Thorp T18 Plans question | Stealth Pilot | Home Built | 8 | January 7th 05 07:11 AM |
| VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 06:03 AM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
