To All:
About a month ago I posted a message having to do with aircraft crash survival in which I touched on the ability to make a fire, and the features found in a good survival knife. The post produced the usual comments some of which were rather surprising and may be of interest to some of you. MATCHES The ability to make fire is fundamental to survival and, all else being equal (never a safe bet :-) the handiest way to do so is to simply strike a match. But based on the comments I received not everyone is aware that matches come in two basic flavors and a variety of sizes. The two basic types of match are those which may be scratched anywhere versus the 'safety' type which can on be struck on an abrasive pad treated with red phosphorus. The 'strike-anywhere' type are preferred since there's no need to provide for the special striking-surface. The surprise came from hearing some folks insist that the 'strike-anywhere' type of match was not available, at least to them. I assume they are the victim of some do-gooder regulation which allows only the sale of 'safety-type' matches in their locale. The splint or wooden portion of a standard kitchen match is 2-3/8" long (ie, about 60mm). This length is a NECESSITY when lighting certain lanterns and some gas-fired appliances. By comparison, a standard 'box-match' has a splint only 1-3/4" long (45mm). I was surprised to learn that some people thought any WOODEN match was a 'kitchen' match and referred to them as such. A couple of these folks mentioned carrying 'kitchen' matches in a 35mm film canister; clearly impossible since such canisters are only about 1-3/4" deep. Another surprise had to do with water-proofing a wooden match. Everyone who mentioned water-proofing said that simply dipping the head of the match into melted paraffin would do the trick. And they're right. But no one mentioned the need to REMOVE the wax before trying to strike the thing, causing me to suspect they were simply repeating something they'd heard. The paraffin makes an excellent water barrier but it's also a very good lubricant. Since ignition of the match depends upon FRICTION, if you don't remove the wax (or at least, most of it) you'll simply scrub the head off the match without ever causing it to light. MATCH SAFES Several people mentioned their preferred method of storing matches. I've already mentioned the 35mm film canister, which is perfectly suitable for the small, box-type matches. Others mentioned commercially available match-safes, cigar tubes and even a specially made jobbie a fellow turned from a bar of aluminum. Personally, I've found a regular pill bottle from the local pharmacy makes an excellent container for kitchen matches, water-proofed or not. A couple of cotton balls keeps the matches from rattling around and a few turns of duct-tape will keep the pill bottle from cracking should it get banged around. In fact, since we're forced to ride the plane down, you might consider taping a pill-bottle of matches to some protected portion of the airframe. IN DEFENSE OF THE BFK As with ability to make fire, when it comes to survival the need for a knife -- for the ability to cut things, beginning with your own safety harness -- is fundamental. Experience has shown that a pocket-knife that is HABITUALLY carried is more practical than a special-purpose 'survival knife' that is not. The key issue here is not the type of knife nor its size but the fact you always have it with you. Two people insisted their Rambo-esque knives were a necessity since they might be needed to chop their way out of the downed aircraft. In that case I think the wiser course is to permanently install such a device in your cockpit and thereafter consider it as part of the airplane rather than part of your survival kit. ---------------------------------------------------------------------------- General Aviation attracts a lot of wingless vultures eager to make a buck by preying upon the unwary. One method of doing so is to sell junk disguised as kits of 'survival' gear. But when the problem of post-crash survival is examined realistically it doesn't take a rocket scientist to see that the average home-builder is liable to be better prepared at lower cost (and less weight) by simply applying a bit of common sense to the problem. -R.S.Hoover |
wrote)
The 'strike-anywhere' type are preferred since there's no need to provide for the special striking-surface. As kids, we would wait for a calm dark night to go out into the street with our "farmer matches" and a straw. We'd "shoot" the matches out the straw, up into the still night air, then wait to see where they landed. Hours of fun. Pops would come out, shoot up a few himself, say, "neat - make sure you watch out for cars," and return inside ...leaving us kids alone outside, to play with matches. :-) Several people mentioned their preferred method of storing matches. I've already mentioned the 35mm film canister, which is perfectly suitable for the small, box-type matches. ONE suggestion for camping is obvious (only "after" the first - oops. g) Don't pack all your matches in ONE container. Two or three containers: You'll be tripping over them all week. One container: You'll misplace it - guaranteed! (BTDT) Montblack |
"Montblack" wrote As kids, we would wait for a calm dark night to go out into the street with our "farmer matches" and a straw. We'd "shoot" the matches out the straw, up into the still night air, then wait to see where they landed. Hours of fun. Pops would come out, shoot up a few himself, say, "neat - make sure you watch out for cars," and return inside ...leaving us kids alone outside, to play with matches. :-) We found that if you wrapped aluminum foil over the tip, (broke off most of the wood first) then shaped the aluminum over the back a little like a rocket nozzle, you could shoot them a good distance. Just need heat on the tip to get it started. -- Jim in NC |
ps.com... To All: excellent post veedub, but I would add a thought or two. one should learn how to make a fire without matches. in a crashed vehicle you have all sorts of materials that "should" be able to make the sparks necessary to get a light. even if your battery croaks a permanent magnet motor and a filament from a light bulb can torch up some tinder. even if the battery fails it still might have enough juice to produce light up a flight chart scraped up for tinder. or a Fresnel lens, although only good during daylight hours. regardless of the equipment, one needs the skill. how many of you can make a fire with only one match? how many of you can make up tinder? as for the knife, you hit it on the head veedub, chuck one in the plane and forget it. all my vehicles have pocket knives. usually in the glove compartment. a survival knife isn't worth it. anecdote. the first season my dad went deer hunting he bought a 6 inch long hunting knife, a fairly good one. after getting his first kill he realized he did not know how to field dress a deer. luckily along came a man who was more knowledgeable than my dad and offered to dress it for him. the gent took out a tiny pocket knife and preceded to dress the deer, while my dad felt a little sheepish with his 6 inch knife on his belt. still has that 6 inch knife, good for splitting pelvises, but a two inch blade is a bit better for field dressing. |
who cares? wrote: What about carrying one of those disposable cigarrette lighters that you can buy at walmart for less than a dollar? ------------------------------------------------------------------------------ While there's no reason NOT to include disposable flint or piezo lighters in your survival kit, in practice you will find the larger, hotter flame provided by a kitchen match to be more practical when it comes to starting a fire using whatever tinder is locally available. -R.S.Hoover |
ps.com... To All: About a month ago I posted a message having to do with aircraft crash survival in which I touched on the ability to make a fire, and the features found in a good survival knife. The post produced the usual comments some of which were rather surprising and may be of interest to some of you. MATCHES The splint or wooden portion of a standard kitchen match is 2-3/8" long (ie, about 60mm). This length is a NECESSITY when lighting certain lanterns and some gas-fired appliances. By comparison, a standard 'box-match' has a splint only 1-3/4" long (45mm). I was surprised to learn that some people thought any WOODEN match was a 'kitchen' match and referred to them as such. A couple of these folks mentioned carrying 'kitchen' matches in a 35mm film canister; clearly impossible since such canisters are only about 1-3/4" deep. Picking one little nit here, if you don't have something that needs the length, once you snap off the excess wood, 2-3/8" matches fit just fine in a 1-3/4" canister. General Aviation attracts a lot of wingless vultures eager to make a buck by preying upon the unwary. One method of doing so is to sell junk disguised as kits of 'survival' gear. But when the problem of post-crash survival is examined realistically it doesn't take a rocket scientist to see that the average home-builder is liable to be better prepared at lower cost (and less weight) by simply applying a bit of common sense to the problem. Took a trip across Canada/Alaska in a C120, so of course we took "survival gear". Talking to a "local" he suggested some snare wire - really handy stuff - easy to catch rabbits and such for food he sez. Sure. Easy if you have a clue as to what to do with it... I'm 99.9% sure that I'd never make it work on my own. On the other hand, safety wire is a good thing to have along for 101 uses. Duct tape wrapped around the handle of one of your wrenches is handy too. A little practice close to home so you know what to do with the stuff (and if it works) makes a lot of sense, eh? Anyhow, keep up the good work. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
On Thu, 8 Jun 2006 15:19:44 -0400, "Morgans" wrote:
"Montblack" wrote As kids, we would wait for a calm dark night to go out into the street with our "farmer matches" and a straw. We'd "shoot" the matches out the straw, up into the still night air, then wait to see where they landed. Hours of fun. Pops would come out, shoot up a few himself, say, "neat - make sure you watch out for cars," and return inside ...leaving us kids alone outside, to play with matches. :-) We found that if you wrapped aluminum foil over the tip, (broke off most of the wood first) then shaped the aluminum over the back a little like a rocket nozzle, you could shoot them a good distance. Just need heat on the tip to get it started. We used to disassemble a wooden clothespin, turn the two pieces of wood back-to-back, and slip the steel spring over them with one "arm" inside. You could then cock the spring and slip a farmer match between the jaws. The coil spring was a natural trigger, and when you pulled it, the contrivance simultaneously launched the match while igniting it. Used to ride our bicycles in dogfights shooting at each other.... Ron Wanttaja |
My wife (who, in a previous life, did things like take two-week back
country canoe trips with her High Adventure Explorers post in Texas, with responsibility for food and material planning for twelve 18-year olds, ie, she can look out for herself) encouraged me to write: We were car camping once in a rental car and wanted to start a camp stove. We had very carefully packed matches. Turned out there are two different kinds of even Ohio Blue Tips, safety- and non. Laura had packed safety in a match safe. No strike-strip. We fussed over the notion for several minutes that we had a car with a full gas tank and a lot of readily available energy in its battery, and we couldn't figure out how to light a safe fire. What to do? I extracted a bulb from the brake light and crushed the glass envelope. I instructed Laura to get in the car and step on the brake pedal when told to do so. I held a match on the hot filament, lit the match, lit a candle from the match, etc. We had a nice dinner. We stopped at a hardware store on the way to the car drop-off point to get a new bulb. We considered presenting the receipt to the rental company: "We found that the bulb needed to be replaced..." Keep track of match type. David wrote: The two basic types of match are those which may be scratched anywhere versus the 'safety' type which can on be struck on an abrasive pad treated with red phosphorus. The 'strike-anywhere' type are preferred since there's no need to provide for the special striking-surface. The surprise came from hearing some folks insist that the 'strike-anywhere' type of match was not available, at least to them. I assume they are the victim of some do-gooder regulation which allows only the sale of 'safety-type' matches in their locale. |
| Survival | [email protected] | Home Built | 1 | May 12th 06 06:58 PM |
| Fuel contamination and other basic survival instincts | Greg Farris | Piloting | 17 | July 14th 05 11:45 PM |
| Whidbey Island Survival School | JD | Naval Aviation | 11 | January 16th 05 08:10 PM |
| US Air Force survival gun? | Bruce W.1 | Military Aviation | 99 | April 26th 04 11:31 PM |
| Survival Gear | EDR | Owning | 22 | February 15th 04 04:43 AM |
