Robert M. Gary wrote:
I'm curious how important it really is to punch in 1200 as soon as the controller instructs squawk 1200 as you approach for landing at an uncontrolled field. Aviate, navigate, communicate. Your squawk code comes under communicate. It shouldn't be a big deal to reset the code to 1200, but certainly, if you're busy with other tasks, that's pretty low on the priority list. Most of the time, when the controller turns you loose, you're about to drop below radar coverage anyway, so it's a moot point. |
NW_PILOT wrote:
If you don't go 1200 for some time and they really want you to they will tell you so! How will ATC tell you since presumably, ATC also turned you over to another frequency along with the transponder code change? -- Peter |
Not important at all.
Robert M. Gary wrote: I'm curious how important it really is to punch in 1200 as soon as the controller instructs squawk 1200 as you approach for landing at an uncontrolled field. I've always blown it off and just landed with my original code. My thinking is 1) Of the things I need to do to configure for landing, watch for traffic, get the plane slowed down, etc this is way, way down on my important to-do list 2) What the heck can ATC care anyway, are they going to reuse that code in the next 2 minutes 3) If something did happen to me, maybe they'd have a better radar track if I'm still on the old code?? Im just curious from controllers how important is this change in code before landing. -Robert, CFI |
![]() Stubby wrote: Suppose you have to do a missed approach or just go around. What does the controller want to see you as? You "own" the runway until you terminate the code, Ah, what? The code has nothing to do regarding VFR/IFR. A controller does not gain the ability to use VFR separation standards on an IFR aircraft because he told him to squawk VFR, such as going into an uncontrolled field. |
![]() Gary Drescher wrote: "Stubby" wrote in message news ![]() Suppose you have to do a missed approach or just go around. What does the controller want to see you as? You "own" the runway until you terminate the code, so maybe the issue is when can the controller have another plane start an approach. I think Robert was talking about VFR flight following, not an IFR approach. If it were an IFR approach, you'd only be instructed to squawk 1200 if you'd cancelled IFR--but in that case, you're now VFR and you no longer "own" the runway (and if you have to go missed, you're still just VFR; if you re-enter the clouds, you're VFR in IMC). You never owned it in the first place. A third scenario is when you are practicing IFR approaches while VFR to an uncontrolled field. This just came up at our place. One of the major college flight schools is based at an airport 12 miles SW of here. They always do their last practice approach into that airport. Since our facility over 15 years ago put out a letter to airmen stating that we would provide separation services to VFR aircraft on practice approaches we are required to provide that service, traffic permitting, all the way to the airport. We used to just terminate you and tell you to squawk VFR about 5-6 miles from the airport. We can still do that but are on the hook for separation until you tell us you have completed your approach. If you don't report the completion we can take our best guess as to when you got to the missed approach point as that is when separation would end anyways. Only then can we allow a second aircraft to start the approach. Our other option is to tell you that the approach is approved, maintain VFR, no separation provided. |
"Robert M. Gary" wrote in message
oups.com... I'm curious how important it really is to punch in 1200 as soon as the controller instructs squawk 1200 as you approach for landing at an uncontrolled field. As others have said, if changing the transponder code is at all a problem with respect to the safety of the flight, don't do it. It may or may not cause problems for ATC. More likely not, but even if it does, that's their problem. They should have given you the transponder code change earlier, when you aren't so busy with your landing prep (I can only imagine changing the code being a problem on short final...otherwise, there's plenty of "downtime" during the traffic pattern and approach to do it). Pete |
IIRC flying IFR into an uncontrolled field is a one-in & one-out deal.
In essence you "own" the airspace (not the runway) until you've landed & cancelled with ATC or flown somewhere else. Only then can ATC bring in another aircraft for an approach (assuming IMC conditions exist). I think a parallel to a controlled field would be the local controller sterilizing the airspace of any special VFRs aircraft when IAPs are in effect. Steven P. McNicoll wrote: Being IFR or VFR has nothing to do with "owning" the runway. |
Kingfish wrote:
IIRC flying IFR into an uncontrolled field is a one-in & one-out deal. Is the one-in, one-out deal a function of having a tower, or of radar coverage? HPN becomes uncontrolled when the tower closes at 10:00 PM, but there's radar coverage right down to the ground (NY Approach has a radar sensor on the field). Does HPN become one-in, one-out when the tower closes? I come in late at night once in a while, but not often enough to notice how the IFR works. In essence you "own" the airspace (not the runway) until you've landed & cancelled with ATC or flown somewhere else. The landing has nothing to do with it. The essential event is cancelling IFR. You can cancel before you land, which releases the airspace. On the other hand, if you land and don't cancel, ATC will continue to protect the airspace until you do cancel (although, I imagine there must be some timeout). I had an experience a few years back on an IFR training flight into BDR (Bridgeport, CT). We were holding at the FAF and I could see the aircraft in front of us (a commuter flight) had already landed and taxied off the runway. But they hadn't canceled yet, so ATC couldn't clear us for the approach yet. It worked out fine, since my student needed the holding practice :-) Only then can ATC bring in another aircraft for an approach (assuming IMC conditions exist). IMC has nothing to do with it. In the BDR example above, it was severe clear, but if we wanted an approach clearance, we had to wait until the airspace was released by the flight in front of us cancelling. |
![]() "Kingfish" wrote in message ps.com... IIRC flying IFR into an uncontrolled field is a one-in & one-out deal. In essence you "own" the airspace (not the runway) until you've landed & cancelled with ATC or flown somewhere else. Only then can ATC bring in another aircraft for an approach (assuming IMC conditions exist). I think a parallel to a controlled field would be the local controller sterilizing the airspace of any special VFRs aircraft when IAPs are in effect. The surface area does not need to be "sterilized" of SVFR aircraft, they just need to be separated from IFR or other SVFR aircraft. |
![]() "Peter Duniho" wrote in message ... That said, I'm not entirely sure about the whole "one-in, one-out" thing...as far as I know, ATC protects the airspace for whatever operations and time has been approved. Usually that means a single landing, until the pilot cancels IFR, or a departure, until the pilot is in radar contact. But in reality, I suspect it means whatever ATC needs it to mean at the moment. There is no "one in, one out rule". Separation must be provided, of course, so if an IAP is needed a previous aircraft must cancel IFR before a following aircraft can be cleared for the approach. But if visual approaches are being made visual separation can be used and multiple aircraft can have approach clearances. |
Which Military Service is best? | ArtKramr | Military Aviation | 33 | September 19th 04 04:12 PM |
Air Force Chief Sounds Off as Service Birthday Approaches | Otis Willie | Military Aviation | 0 | September 18th 04 03:54 AM |
GWB and the Air Guard | JD | Military Aviation | 77 | March 17th 04 10:52 AM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Service Bulletins, Service Letters, Service Spares Letters | O. Sami Saydjari | Owning | 5 | December 26th 03 05:36 AM |
