#71
I don't care what you believe. Maybe I just wanted a heated
discussion to start, or maybe there is another reason. Factors to consider... CG range approved Actual operational CG condition of the airfoils pilot technique Let see what this logic shows... aircraft is slowed to near stalling speed by the application of back pressure on the elevator which increases the down force on the aircraft tail cone which levers the nose upward by dynamically shifting the CG to a point behind the CP which is the moment arm of the tail times the force produced by the tail in an algebraic balance with the arm of the CG and CP. If the tail does not stall, to some degree, what tail down force ceases to exist to maintain the nose up attitude? If the wing is stalled does the lift not decrease and thus the CP force decrease? Would that not reduce the moment needed to rotate the nose downward to regain flying speed reduce the angle of attack)? FAR 23 has design limits for control degradation, the rudder must be able to yaw the aircraft at a speed less than lift-off speed, the elevator must be able to apply forces and even the ailerons have limits. But when the aircraft is stalled, out of ground effect, what force or forces change that cause the nose to pitch downward? The wing is producing less lift which means that the moment produced by wing lift also decreases, reducing the nose down force. The tail was supplying the force needed to establish the attitude and what would cause THAT forced to be reduced if it is not at least a stall (partial or complete) of the elevator? If the aircraft is held in a stalled condition, with the elevator full back and the aircraft has a stall break, the nose drops and then the nose pitches back up and the stall break happens again and again in a cycle, the pilot keeping the elevator full back and the wings level with rudder and some aileron if the ailerons still function, what change in forces on the aircraft is causing the cycle? Did the wing regain lift or did the tail regain down-force? -- James H. Macklin ATP,CFI,A&P "Matt Whiting" wrote in message ... | Jim Macklin wrote: | No, do I need a credible reference? | | Only if you want us to believe you as what you are saying goes against | everything most of us have seen published in the literature. | | Matt |
#72
Jim Macklin wrote:
I don't care what you believe. Confirms my suspicion. You don't care about being correct either so no need for further discussion. Ignorance is bliss. Matt |
#73
"Jim Macklin" wrote in message
news:Z6vmg.49402$ZW3.30156@dukeread04... "Matt Whiting" wrote: Jim Macklin wrote: No, do I need a credible reference? Only if you want us to believe you as what you are saying goes against everything most of us have seen published in the literature. I don't care what you believe. You're a CFI, so we care what your students are led to believe. Maybe I just wanted a heated discussion to start, Uh, sure Jim. But there's been little heated discussion. Several of us have just been patiently explaining to you an elementary aspect of aviation. If the tail does not stall, to some degree, what tail down force ceases to exist to maintain the nose up attitude? That's a perfectly reasonable question, and it's been answered for you at least five times in this thread. (Hint: search for "relative wind".) Each time, you've simply *ignored* the answer without even *trying* to point out any flaw in it. Your approach to discussing aviation is the same as your approach to discussing politics. In both domains, you're willing to engage in debate *as long as it just rehashes material that's already familiar to you*. But as soon as anyone raises an objection that you hadn't previously considered, you just ignore it and retreat to familiar ground, repeating the claims that the objection already defeated, making no attempt to refute the objection. Unfortunately, that approach completely defeats the purpose of rational discourse, because it renders your beliefs incorrigible. Perversely, you're left with the illusion that you've sustained your position; but the reality is that you merely went through the motions of rational discourse until just before the point where a meaningful exchange of ideas would begin. --Gary |
#74
Gary Drescher wrote:
That's a perfectly reasonable question, and it's been answered for you at least five times in this thread. (Hint: search for "relative wind".) Each time, you've simply *ignored* the answer without even *trying* to point out any flaw in it. It is pretty clear that he doesn't want to know the correct answer. Yes, it is sad that he's a CFI and propogating these OWTs to his students. It is even scarier than the system let him get to the ATP level with this erroneous thinking. Maybe I'll try to get a note to Barnaby Wainfan and see if he'll address it in one of his future columns. I know he's dicussed stalls before, but I'm not sure from this perspective of level of detail. Matt |
#75
"Jim Macklin" wrote:
I don't care what you believe. Maybe I just wanted a heated discussion to start This is called being a troll, and is generally not something which most people appreciate. aircraft is slowed to near stalling speed by the application of back pressure on the elevator which increases the down force on the aircraft tail cone which levers the nose upward by dynamically shifting the CG to a point behind the CP which is the moment arm of the tail times the force produced by the tail in an algebraic balance with the arm of the CG and CP. This is gibberish. The CG doesn't shift unless stuff moves around in the airplane. A study of shifting loads (such as fuel sloshing around in half-full tanks) would be a fascinating but very complicated endeavor, and not particularly germane to this discussion. If the tail does not stall, to some degree, what tail down force ceases to exist to maintain the nose up attitude? OK, I explained this once, but I'll do it again, slowly, and more carefully. Let's invent a hypothetical airplane where the main wing stalls at an alpha (angle of attack, AOA) of 18 degrees, which happens to be a fairly typical number for the kinds of wings most of us fly. Let's also imagine that it's got a symmetric one-piece stabilator (such as found on an Archer), which also stalls at 18 degrees (positive or negative). Vso for this plane is 60 kts (that's a pretty high value, but it makes the math easier Now, let's put the plane at the edge of stall in a typical power-off stall demonstration. The main wing AOA is 17.9 degrees. The yoke is almost all the way back, and the stabilator is set at an AOA of -15 degrees. Power is at idle, true airspeed is 50 kts, and you're maintaining altitude. Now, pull back on the yoke just a bit more. The AOA increases to 18.1 degrees, and the main wing is now stalled. The wing is now producing less lift than the airplane weighs, so it starts to accelerate downward. After a short time, it's in a 100 fpm descent, but we're still holding the same pitch attitude. If you work the math, 60 KTAS and 100 fpm down works out to a glide slope of just about -1 degree, which means the relative wind is now coming from 1 degree below the horizontal. Since the pitch angle hasn't changed, the AOA of both the main wing and the tail will change by this same 1 degree. For the main wing, that means the AOA has been driven from 18.1 degrees to 19.1 degrees; further into stall, and further reducing the amount of lift being generated (increasing drag too, but that's a secondary issue). Now, here's the interesting part. The tail has gone from -15 to -14. It's moved further away from stall. But, it too, is producing less (downward) lift because the AOA is reduced. Less downforce from the tail means the nose will start to drop. No tail stall, just reduced downwards lift from the tail due to decreased tail AOA caused by the downward motion of the aircraft. That's it, I'm done. If you really want to be a troll, enjoy yourself. If the wing is stalled does the lift not decrease and thus the CP force decrease? Would that not reduce the moment needed to rotate the nose downward to regain flying speed reduce the angle of attack)? FAR 23 has design limits for control degradation, the rudder must be able to yaw the aircraft at a speed less than lift-off speed, the elevator must be able to apply forces and even the ailerons have limits. But when the aircraft is stalled, out of ground effect, what force or forces change that cause the nose to pitch downward? The wing is producing less lift which means that the moment produced by wing lift also decreases, reducing the nose down force. The tail was supplying the force needed to establish the attitude and what would cause THAT forced to be reduced if it is not at least a stall (partial or complete) of the elevator? If the aircraft is held in a stalled condition, with the elevator full back and the aircraft has a stall break, the nose drops and then the nose pitches back up and the stall break happens again and again in a cycle, the pilot keeping the elevator full back and the wings level with rudder and some aileron if the ailerons still function, what change in forces on the aircraft is causing the cycle? Did the wing regain lift or did the tail regain down-force? |
#76
Roy Smith wrote: Power is at idle, true airspeed is 50 kts, and you're maintaining altitude. Typo there, I meant to write "60". |
#77
Matt Whiting wrote: It is pretty clear that he doesn't want to know the correct answer. Yes, it is sad that he's a CFI and propogating these OWTs to his students. It is even scarier than the system let him get to the ATP level with this erroneous thinking. Getting your ATP only requires a few things: 1) Logging 1500 PIC hours. Anybody with enough time, money, and tenacity can do that. 2) Passing a written test. Same comment as above. 3) Passing a flight test. This is a little harder, because it actually requires some skill as a pilot, but I've known some very scary pilots who have ATPs, so I gotta asuume it's not that tough. I'm not impressed by people with ATPs, since having a clue is neither a necessary nor sufficient condition for getting one. |
#79
"T o d d P a t t i s t" wrote in message
... Even for the wing, if the CP is behind the CG, and if the aircraft has any downward motion (which it will have as the wing loses lift), then drag pushes up at the CP which rotates the aircraft around the CG towards a nose down attitude. Oops, that's right. Thanks for the correction. --Gary |
#80
wrote in
oups.com: Hi Marty, I think we are talking different 885s here. As far as I remember the 885 is the light airframe with the 145 hp O-300. The 235 has the heavy airframe, I believe. Well, does not matter really. My 880 had the RR O-200, max speed about 90kts. The only disadvantage of the Rallye I can think of is the difficulty to get spare parts(never mind the costs, yikkes). We used the 880 as a two-seater with a lot of luggage room. The both of us plus full fuel and then we had 100# left for baggage, and thats a lot if you have to carry it from and to the plane over several 100 yards. Having a sore back from hauling baggage is no more, I have a C150 now. Cheers, Kees. Hi Kees - Oooops. My mistake. I misread your model number as 895 and equated that to the Rallye 235E, as the previous model, the MS-894 (aka Minerva) was the Franklin 220hp powered Rallye. Sometimes I think MS & SOCATA had more model numbers & names than they had aircraft. Yes, the 235 has the heavy airframe, which includes 2 hardpoints on each wing. I found some pictures on the web a few years ago showing 235's outfitted as light fighters by a few Latin American countries. The only one I could find today is about half-way down at http://www.probertencyclopaedia.com/IRB.HTM I am convinced SOCATA uses the aircraft's service ceiling as the floor for parts prices. --- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 06:23 PM |
| Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 05:05 AM |
| military men "dumb, stupid animals to be used" Kissinger | B2431 | Military Aviation | 3 | April 26th 04 06:46 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
