A dumb doubt on stalls
Old June 22nd 06, 08:02 PM posted to rec.aviation.piloting
Default A dumb doubt on stalls
Sorry, I've been attempting to emulate the mental processes
of a Democrat.
"Gary Drescher" wrote in message
| "Jim Macklin" wrote
in message
| news:Z6vmg.49402$ZW3.30156@dukeread04...
| "Matt Whiting" wrote:
| Jim Macklin wrote:
| No, do I need a credible reference?
| Only if you want us to believe you as what you are
saying goes against
| everything most of us have seen published in the
literature.
| I don't care what you believe.
| You're a CFI, so we care what your students are led to
believe.
| Maybe I just wanted a heated discussion to start,
| Uh, sure Jim. But there's been little heated discussion.
Several of us have
| just been patiently explaining to you an elementary aspect
of aviation.
| If the tail does not stall, to some degree, what tail
down
| force ceases to exist to maintain the nose up attitude?
| That's a perfectly reasonable question, and it's been
answered for you at
| least five times in this thread. (Hint: search for
"relative wind".) Each
| time, you've simply *ignored* the answer without even
*trying* to point out
| any flaw in it.
| Your approach to discussing aviation is the same as your
approach to
| discussing politics. In both domains, you're willing to
engage in debate *as
| long as it just rehashes material that's already familiar
to you*. But as
| soon as anyone raises an objection that you hadn't
previously considered,
| you just ignore it and retreat to familiar ground,
repeating the claims that
| the objection already defeated, making no attempt to
refute the objection.
| Unfortunately, that approach completely defeats the
purpose of rational
| discourse, because it renders your beliefs incorrigible.
Perversely, you're
| left with the illusion that you've sustained your
position; but the reality
| is that you merely went through the motions of rational
discourse until just
| before the point where a meaningful exchange of ideas
would begin.
| --Gary
  #85
Old June 23rd 06, 03:51 PM posted to rec.aviation.piloting
"Jim Macklin" wrote in message
news:BQBmg.49424$ZW3.24753@dukeread04...
of a Democrat.
Putting aside the vacuous gibe, does that mean you now agree that your
account of stalls was incorrect? I'm genuinely concerned for the sake of
your students. If they were to believe you that an ordinary stall involves
stalling the tail, then they'd have reason to think that a tail stall isn't
a big deal. That would lead them to be less frightened than they should be
of circumstances that really can cause a tail stall (such as tail icing or a
too-forward CG).
--Gary
  #86
Old June 23rd 06, 04:44 PM posted to rec.aviation.piloting
Maybe, I'm going to take a poll and see what I should do.
As far as my students go, they've been doing well for
decades. Many are or have been USAF, USN and some even hold
degrees as aeronautical engineers.
James H. Macklin
ATP,CFI,A&P
| "Jim Macklin" wrote
in message
processes
| of a Democrat.
agree that your
for the sake of
tail stall isn't
than they should be
as tail icing or a
| too-forward CG).
| --Gary
  #87
Old June 23rd 06, 04:57 PM posted to rec.aviation.piloting
circumstances that really can cause a tail stall (such as [...] a
too-forward CG).
Ding.
Obvious once I thought about it (duh!), but it had never occured to me
before, and nobody had ever mentioned it in my training. How far
further forward would the CG need to be to cause a tail stall in normal
flight attitudes?
Jose
The monkey turns the crank and thinks he's making the music.
  #88
Old June 23rd 06, 05:37 PM posted to rec.aviation.piloting
"Jose" wrote in message
news
too-forward CG).
Ding.
before, and nobody had ever mentioned it in my training. How far further
forward would the CG need to be to cause a tail stall in normal flight
attitudes?
Although I haven't done the calculation, I'd be surprised if a typical GA
plane could tail-stall at a normal in-flight angle of attack no matter how
far forward you had the CG (unless you were to tie some cinder blocks to the
nose gear or something). The danger would come during the landing flare, or
if you tried to do slow flight or stall practice, or if turbulence were to
abruptly increase the AoA.
--Gary
  #89
Old June 23rd 06, 05:48 PM posted to rec.aviation.piloting
news:zZTmg.49464$ZW3.45524@dukeread04...
Yes, I'd expect most of your students to survive the confusion--either
because they know better than to accept your model (try asking the AEs about
it), or because they don't happen to consider the ramifications I mentioned.
Still, there's no reason to impose the small but real danger that comes from
teaching a false, confusing model of stalls when a correct model is readily
available instead.
--Gary
James H. Macklin
ATP,CFI,A&P
| "Jim Macklin" wrote
in message
processes
| of a Democrat.
agree that your
for the sake of
tail stall isn't
than they should be
as tail icing or a
| too-forward CG).
| --Gary
  #90
Old June 23rd 06, 09:20 PM posted to rec.aviation.piloting
Did I ever say that I had taught any particular theory to
any student?
If an airplane was only a wing and there was no tail, would
a high speed computer monitoring angle of attack,
differential pressure and able to use spoilers, slats,
weight-shift, boundary layer control, etc be able to fly the
wing? Would it make a difference if the wing was straight
or swept?
If dimples make a golf ball fly further and stitches make a
baseball curve, why do airplanes have neither? Why do some
people think that space aliens built the pyramids or that
all the tall buildings were built with demolition charges so
the government could bring down the buildings in a phony
terrorist attack?
Lift varies with the square of the airspeed, at the same
angle of attack, double the speed and the lift increases by
four times. Assuming a linear change in lift with changes
in angle of attack, if the aircraft is slowed by 50% and the
angle of attack is increased to compensate, how much is
that? If a train leaves Boston at midnight headed for
Chicago and a Mexican crosses the border at the same time,
when will you hub caps be stolen in St. Louis?
If a student pilot departs an airport in Class B airspace
and flies 1,000 miles in Class A airspace before landing at
an airport in Class G airspace, is the student pilot in
violation of any regulation? Has any regulation been
violated? Did the flight leave Portland, OR and go to
Alaska? Was the student pilot just a passenger on an
airline?
Is Buffy the Vampire Slayer based on fact?
| "Jim Macklin" wrote
in message
do.
hold
confusion--either
model is readily
| available instead.
| --Gary
| James H. Macklin
| ATP,CFI,A&P
message
| | "Jim Macklin"
wrote
| in message
| processes
| | of a Democrat.
| agree that your
concerned
| for the sake of
that a
| tail stall isn't
| than they should be
(such
| as tail icing or a
| | too-forward CG).
| | --Gary
Practice stalls on your own? [email protected] Piloting 34 May 30th 05 05:23 PM
Newbie Qs on stalls and spins Ramapriya Piloting 72 November 23rd 04 04:05 AM
military men "dumb, stupid animals to be used" Kissinger B2431 Military Aviation 3 April 26th 04 05:46 PM
