Martin X. Moleski, SJ wrote:
On Thu, 22 Jun 2006 16:08:03 -0000, Jim Logajan wrote in : So what are FARs cover R/C aircraft (is there a weight or size threshold)? The FAA accepts the Academy of Model Aeronautics definition of a recreational model as weighing 55 lbs (dry, I think) and operating under 400' altitude (a provision busted every day by all kinds of RC aircraft). In an other post you stated the 400 ft AGL rule was only when you were with in 3 miles of an airport. -- Chris W KE5GIX Gift Giving Made Easy Get the gifts you want & give the gifts they want One stop wish list for any gift, from anywhere, for any occasion! http://thewishzone.com |
On Fri, 23 Jun 2006 03:55:18 -0500, Chris W wrote in
X%Nmg.58007$9c6.31230@dukeread11: The FAA accepts the Academy of Model Aeronautics definition of a recreational model as weighing 55 lbs (dry, I think) and operating under 400' altitude (a provision busted every day by all kinds of RC aircraft). In an other post you stated the 400 ft AGL rule was only when you were with in 3 miles of an airport. I was wrong. I heard it through the grapevine at my club, which operates fairly close to Niagara Falls International Airport (IAG) and the Niagara Falls Air Reserve Base, which is on the other side of the runways. It's 4.7 miles by car from the entrance of IAG to the parking lot at our field. As the crow flies, we might be right on the three-mile boundary, depending on how the airport's air space is defined. http://local.google.com/local?saddr=IAG+-+Niagara+Falls+Intl+Airport+%4043.099339,-78.945076&daddr=3900+Witmer+Rd,+Niagara+Falls,+NY+ 14305&f=d&hl=en&ie=UTF8&sll=37.0625,-95.677068&sspn=41.411029,67.324219&om=1 The same in a shorter format: http://tinyurl.com/nudjs We've heard that the radar operators at IAG can see some of the larger models at our field on their screens. I don't know how credible that report is. We had a couple of guys from the AF Reserve in our club, and I think they knew some of the controllers. Looking at the FAA documents, it seems that the 400' altitude is a universal restriction and not just applicable to sites within three miles of airports. We see lots of aircraft flying in and out of IAG. Fortunately, we're not lined up with either runway and haven't yet had any difficulties seeing and avoiding the full-scale traffic. Some helicopters come over the field at a fairly low level from time to time and perhaps once a year we might see a low-flying GA aircraft. If we stuck to the 400' ceiling and full-scale pilots maintained 500' AGL, there would be plenty of clearance. I don't know anyone in the club who has an altimeter of any sort, let alone telemetry to transmit the information back to the ground, so I'm just guessing about how high our planes fly. Marty |
our field. As the crow flies, we might be right on the three-mile boundary, depending on how the airport's air space is defined. OT... Martin, how far is it from IAG to Lockport? I was thinking about flying up for the day to see the canal and locks. Is IAG the closest or is there another airport closer? |
On Fri, 23 Jun 2006 16:27:00 GMT, john smith wrote in
: It's 4.7 miles by car from the entrance of IAG to the parking lot at our field. As the crow flies, we might be right on the three-mile boundary, depending on how the airport's air space is defined. OT... Martin, how far is it from IAG to Lockport? About 16 miles by car: http://local.google.com/local?saddr=IAG+-+Niagara+Falls+Intl+Airport+%4043.099339,-78.945076&daddr=lockport,+ny&f=li&hl=en&cid=&ie=UT F8&ll=43.134815,-78.817635&spn=0.142556,0.262985&om=1 Shorter URL: http://tinyurl.com/le5sd I was thinking about flying up for the day to see the canal and locks. Is IAG the closest or is there another airport closer? There are closer fields. From http://www.airnav.com/airports: 0G0 Lockport, NY, USA North Buffalo Suburban Airport NK25 Lockport, NY, USA Cambria Airport Private 61NY Lockport, NY, USA Bassett Field Airport Private 59NY Lockport, NY, USA Bent-Wing Airport Private A friend of mine has a Cessna 172 hangared at North Buffalo (0G0): http://www.airnav.com/airport/0G0 That page lists other nearby airports with instrument procedures: KBUF - Buffalo Niagara International Airport (10 nm S) KIAG - Niagara Falls International Airport (11 nm W) 9G3 - Akron Airport (11 nm SE) 9G0 - Buffalo Airfield (14 nm S) 9G6 - Pine Hill Airport (19 nm E) I've got a friend with a grass airstrip in Cambria, NY, but it's not showing up on the airfield locator. It should be on sectionals, although Bill doesn't know the identifier (I just spoke to him via cell phone; he's en route to a Cub reunion in Lockhaven, PA). Bill thinks that Cambria and Bent-Wing are both long closed. Bottom line: North Buffalo (0G0) has got gas and is closest. You'll have to contact them to see about courtesy cars. IAG (KIAG?) would have Hertz and Avis and stuff like that. Marty |
: Is IAG the closest or is there another airport closer? I looked at an online sectional and couldn't find Smith field. I did see Royalton in Gasport, which is right next door to Lockport: http://www.airnav.com/airport/9G5 http://skyvector.com/perl/code?id=9g5&scale=3 Marty |
I looked at an online sectional and couldn't find Smith field. I did see Royalton in Gasport, which is right next door to Lockport: http://www.airnav.com/airport/9G5 http://skyvector.com/perl/code?id=9g5&scale=3 Thank You! |
![]() "Martin X. Moleski, SJ" wrote in message ... On Fri, 23 Jun 2006 03:55:18 -0500, Chris W wrote in X%Nmg.58007$9c6.31230@dukeread11: ..snip... Looking at the FAA documents, it seems that the 400' altitude is a universal restriction and not just applicable to sites within three miles of airports. We see lots of aircraft flying in and out of IAG. Fortunately, we're not lined up with either runway and haven't yet had any difficulties seeing and avoiding the full-scale traffic. Some helicopters come over the field at a fairly low level from time to time and perhaps once a year we might see a low-flying GA aircraft. If we stuck to the 400' ceiling and full-scale pilots maintained 500' AGL, there would be plenty of clearance. I don't know anyone in the club who has an altimeter of any sort, let alone telemetry to transmit the information back to the ground, so I'm just guessing about how high our planes fly. Marty 400' is a recommendation, not a restriction. The issue is if you (the RC pilot) become a hazard to air navigation then you are in violation of those FARs, not because you are flying over 400' high. Kite flying off the end of a runway has the same restrictions... Hold the RC plane up and look at it from 400' (the length of a football field even) and you will be surprised at how small it looks, even the 1/4 scale jobs. Indeed folks do fly higher and further than 400' but it does take some doing... |
On Fri, 23 Jun 2006 23:15:47 GMT, ".Blueskies."
wrote in : 400' is a recommendation, not a restriction. The issue is if you (the RC pilot) become a hazard to air navigation then you are in violation of those FARs, not because you are flying over 400' high. Kite flying off the end of a runway has the same restrictions... Makes sense. Hold the RC plane up and look at it from 400' (the length of a football field even) and you will be surprised at how small it looks, even the 1/4 scale jobs. Indeed folks do fly higher and further than 400' but it does take some doing... Our flight line is 800' from the I-190 on the left and about the same distance to the tree line on the right, so I routinely see my planes at least that far away as I fly the pattern (such as it is) at our field. A small version of the field survey is on this page: http://moleski.net/rc/respark4.htm For those photos and for the ones on this page, I'm sure I was well above 400': http://moleski.net/rc/respark3.htm I've never flown that high before or since. I should rig another camera one of these days and get some fresh photos of the field. The surveyor who did the sketch laid out a landing area for us and had us put fertilizer around it. It worked really well--the greener grass of the flight line is very visible. Marty |
![]() "Martin X. Moleski, SJ" wrote in message ... On Fri, 23 Jun 2006 23:15:47 GMT, ".Blueskies." wrote in : 400' is a recommendation, not a restriction. The issue is if you (the RC pilot) become a hazard to air navigation then you are in violation of those FARs, not because you are flying over 400' high. Kite flying off the end of a runway has the same restrictions... Makes sense. Hold the RC plane up and look at it from 400' (the length of a football field even) and you will be surprised at how small it looks, even the 1/4 scale jobs. Indeed folks do fly higher and further than 400' but it does take some doing... Our flight line is 800' from the I-190 on the left and about the same distance to the tree line on the right, so I routinely see my planes at least that far away as I fly the pattern (such as it is) at our field. A small version of the field survey is on this page: http://moleski.net/rc/respark4.htm For those photos and for the ones on this page, I'm sure I was well above 400': http://moleski.net/rc/respark3.htm I've never flown that high before or since. I should rig another camera one of these days and get some fresh photos of the field. The surveyor who did the sketch laid out a landing area for us and had us put fertilizer around it. It worked really well--the greener grass of the flight line is very visible. Marty Nice job, good pix. Looks like you folks are/were struggling to keep the site alive. Similar issues at every club/group I have ever visited... |
On Sat, 24 Jun 2006 11:58:14 GMT, ".Blueskies."
wrote in : ... A small version of the field survey is on this page: http://moleski.net/rc/respark4.htm For those photos and for the ones on this page, I'm sure I was well above 400': http://moleski.net/rc/respark3.htm Nice job, good pix. Looks like you folks are/were struggling to keep the site alive. Similar issues at every club/group I have ever visited... We aggravated a neighbor by doing a 6:30 AM TV show with big planes. Noise carries well on cool, quiet, morning air. ![]() Other than that, we've done OK. It's a big park and the Parks Department has been very kind to us. Marty |
Cessna Glare Shield Cover | Al Gilson | Owning | 4 | March 21st 06 03:04 AM |
Musings on SOARING cover photos | Ray Lovinggood | Soaring | 19 | March 8th 05 02:30 AM |
Minor changes to USA FAR's 2005 | Burt Compton | Soaring | 0 | December 20th 04 10:24 PM |
This week's AW&ST: apparently THAAD will have some ABM (as in anti- *ICBM*) capability. | Scott Ferrin | Military Aviation | 29 | August 31st 04 04:20 AM |
Full airplane cover? | Robert M. Gary | Piloting | 4 | May 5th 04 04:33 PM |
