Aluminium Cowls
Old June 24th 06, 01:51 PM posted to rec.aviation.homebuilt
Default Aluminium Cowls
Hi,
Can anyone tell me what alloy is used for the manufacture of aluminium nose
bowls on aircraft such as the Luscombe or C-140 or J-3 Cub ?
Also how are they made (hand beaten, drop hammer etc ??)
I assume they are formed in the 'O' condition ? If so are the heat treated
subsequent to forming or is the strain hardening as a result of the forming
process enough to harden and strengthen the metal ?
Thanks,
Steve
Old June 25th 06, 03:55 AM posted to rec.aviation.homebuilt
On Sat, 24 Jun 2006 22:51:05 +1000, "......... :-\)\)"
Hi,
Thanks,
Steve
Not sure what alloy is used, but when working one, it is NECESSARY to
anneal it occaisionally or you will crack the metal, so definitely it
is a work hardening alloy, and is LIKELY not heat treated for
strength.
I have seen cowlings worked up from 6061 on an english
wheel/plannishing hammer.
Posted via a free Usenet account from http://www.teranews.com
Old June 25th 06, 04:37 AM posted to rec.aviation.homebuilt
Hi,
Most would have been made out of 24ST, which in today's alloy
desigination would be 2024. Forming would have been done by any of, or
combination of: hand form, stretcher press, drop hammer, or bladder
press. There would be some anealing and heat treatment depending on the
exact alloy used and the forming technique(s).
Craig C.
Old June 26th 06, 03:34 AM posted to rec.aviation.homebuilt
You may find some useful insight he
http://www.tinmantech.com/
.......... :-)) wrote:
Hi,
Thanks,
Steve
Old June 26th 06, 04:43 AM posted to rec.aviation.homebuilt
Orval Fairbairn wrote:
Usually, they are made from a weldable alloy, NOT 2024 (24ST)!. 5052,
6061, 3004 in soft (non-heat treated) form are often used. Many cowls
are formed as sections and then welded together to form the final piece.
For many of those that are multipiece assemblies, you are correct. The
cowls for most of the birds that I have worked on were one piece
sections, with just mechanical fastner assembly. My L-5 has both types
of assemblies on it and my Fairchild cowlings were riveted stampings.
Craig C.
Question about Alodine 1201 Andrew Sarangan Home Built 20 April 11th 06 01:31 PM
Blackbird v. Mig-25 Vello Kala Military Aviation 79 September 15th 04 04:05 AM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar Home Built 4 March 11th 04 11:31 PM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar Aviation Marketplace 4 March 11th 04 11:31 PM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar General Aviation 4 March 11th 04 11:31 PM
