I have a question for a DER who specializes in aircraft structural.
It's a welding question. Anyone on line? - Mike |
Hi,
Have some aviation experience, 20 years AME with structures. What is your question? If I don't know I bet I Know someone who does. Mark mhorowit wrote: I have a question for a DER who specializes in aircraft structural. It's a welding question. Anyone on line? - Mike |
mohawk wrote: Hi, Have some aviation experience, 20 years AME with structures. What is your question? If I don't know I bet I Know someone who does. Mark mhorowit wrote: I have a question for a DER who specializes in aircraft structural. It's a welding question. Anyone on line? - Mike Great - thanks for the offer. I"m looking at Figure 4-36 in 43-13-1B "Welded patch repair". I'm wondering if it would be acceptable to modify the patch so that instead of that approx. 30 degree downward slope, the edge went 90 degrees down so that the patch wrapped around like it does for a extenal splice on a strut. In this case it would wrap around 270 degrees. I'm thinking the length of the welds would be about the same. Wondering what engineering concerns would make this unacceptable. This is for the leading edge of my rudder, which has a rust hole in the 4130 steel. The reason I'm looking at a deviation from figure 4-36 is that if I follow the illustration, the edge will just cover a bolt hole, and if I redrill the hole, I'll be drilling thru a weld, thereby weakening it. - Mike Reason |
I'm repainting a fiberglass airplane.
Sanding the wings, once removed from the plane is a fairly easy chore, however sanding the underside of the fuselage and strakes is going to be a major chore. A body shop near the airport has a soda blaster that they will let me use. I've heard of folks using these to remove old paint from boats and planes. Is it possible to use a soda blaster to remove only the top coat and not remove the primer and micro beneath??? Basically use it to do the 60 grit sanding job and then follow with the relatively easier 150 and 240 grit sanding to prepare for primer? Anybody do this and actually save time and effort? Scott |
| Thread Tools | |
| Display Modes | |
