I've read the past posts on using ~20% methanol to prevent tail ballast
from freezing. I have these questions three: 1) Is methanol in any way corrosive to rubber parts/seals? 2) Is there a reason not to use ethanol if methanol can't be found? 3) Does a glider flying in the Great Basin area in July, between 15k and 18k for 7+ hours, really need tail ballast anti-freeze? ~ted/2NO |
JS has a lot more experience than I flying the Great Basin, but in the FWIW
category, the winds aloft forecast will have the forecast temperatures aloft. I just got a forecast of the DUATS net for a VGT to RNO flight for tomorrow morning and the forecast temps at 12K MSL is +09 and at 18K MSL at -09. Freezing level forecast is: Freezing Level Idaho ... 14,000 feet to 15,500 feet. Montana ... 12,500 feet to 13,000 feet eastern. 13,000 feet to 14,500 feet remainder. Wyoming ... 13,500 feet to 15,500 feet. Nevada ... 15,000 feet to 16,000 feet. Utah ... 15,000 feet to 16,000 feet. Colorado ... 13,500 feet to 15,500 feet. Arizona ... 15,000 feet to 16,000 feet. New Mexico ... 14,000 feet to 15,500 feet. So if you plan on staying too long above 15KMSL, mmmmmm BT "JS" wrote in message ups.com... wrote: 3) Does a glider flying in the Great Basin area in July, between 15k and 18k for 7+ hours, really need tail ballast anti-freeze? ~ted/2NO It's not necessary, Ted! Just load it to MGW and your desired C/G and have fun. Jim |
"BTIZ" wrote in message news:kdlog.15261$_c1.2009@fed1read05... So if you plan on staying too long above 15KMSL, mmmmmm BT It puzzles me that so many glider pilots cannot solve basic problems without resorting to alcohol or booze!! Duh, simply use boiling water for ballast and you can safely (?) extend your stay above the freezing level by at least 10 minutes . I know, I know, you're probably asking yourself, "Why didn't I think of that?". all the best, -- bumper "Dare to be different . . . circle in sink." |
"bumper" wrote in message news ![]() "BTIZ" wrote in message news:kdlog.15261$_c1.2009@fed1read05... So if you plan on staying too long above 15KMSL, mmmmmm BT It puzzles me that so many glider pilots cannot solve basic problems without resorting to alcohol or booze!! Duh, simply use boiling water for ballast and you can safely (?) extend your stay above the freezing level by at least 10 minutes . I know, I know, you're probably asking yourself, "Why didn't I think of that?". all the best, -- bumper "Dare to be different . . . circle in sink." Of course, you could put an electric heater in the fin tank. That would give you yet another reason to install two 25AH (14V?) batteries. bildan |
I'm betting there is a really good reason, but why not use automotive
antifreeze? Is it not compatible with composites? Very bad for the environment. |
bumper
"Dare to be different . . . circle in sink." around here we call that "Nevelling" after Neville Robinson who perfected the technique BT |
I got this from our resident physicist and weather guru:
snip From NHTSA on methanol in fuels: "Methanol will attack and corrode certain metals, such as magnesium and aluminum. Additionally, the corrosion products of aluminum and methanol will precipitate out of the liquid fuel and clog filters and fuel injectors. For this reason, it is recommended that metals such as stainless steel and carbon steel be used in methanol fuel systems and fuel delivery systems. Methanol will also attack many common elastomeric materials, like rubber, polyurethane, and most plastics. Elastomers with high fluorine content and Teflon have been proven to be compatible with methanol." .... Ethanol is probably safer. /snip Thanks Mike! ~ted/2NO "Jack Daniels for my V2C!" |
| Thread Tools | |
| Display Modes | |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| AH64 tail rotor | CivetOne | Rotorcraft | 3 | October 23rd 03 08:18 PM |
| The prone postion for tail gunners versus turrets. | The Enlightenment | Military Aviation | 8 | July 23rd 03 12:01 AM |
