As part of my work (civil engineer), I routinely use GPS equipment in
surveying. And construction specifications usually calls for this equipment to be held stationary for as much as three hours where crucial transition points are to be located, and for up to twenty minutes at less important locations. I guess since you folk use GPS to navigate all across the globe and requires to be both very precise and instantaneous, my equipment is very much inferior to what's used in aviation. Has anyone here used the type of equipment I'm mentioning? You should see the time the thing I use takes to stabilize itself to show the elevation... you'd comfortably CFIT if you had that in your airplane )Ramapriya |
No real difference. The stabilization that you refer to is getting to an
accuracy that is not needed for ground-based or aviation-based navigation. Typical near-instanstaneous accuracy for even cheap GPS receivers is a few meters. Not good enough for surveying but certainly good enough to find a 60-foot wide (or better) runway. ------------------------------- Travis Lake N3094P PWK wrote in message oups.com... As part of my work (civil engineer), I routinely use GPS equipment in surveying. And construction specifications usually calls for this equipment to be held stationary for as much as three hours where crucial transition points are to be located, and for up to twenty minutes at less important locations. I guess since you folk use GPS to navigate all across the globe and requires to be both very precise and instantaneous, my equipment is very much inferior to what's used in aviation. Has anyone here used the type of equipment I'm mentioning? You should see the time the thing I use takes to stabilize itself to show the elevation... you'd comfortably CFIT if you had that in your airplane )Ramapriya |
Bob Noel wrote:
[snip] Has anyone here used the type of equipment I'm mentioning? You should see the time the thing I use takes to stabilize itself to show the elevation... you'd comfortably CFIT if you had that in your airplane yeah, but what is the accuracy of your GPS? I suspect it is much more accurate than needed for aviation. Not really Bob. Most building, refinery and pipeline surveys accept a +/- 0.8 centimeter variation, so it isn't pinpoint like in aircraft, I think. Btw, just out of interest - does TCAS use GPS data in some ways too? Ramapriya |
Bob Noel wrote:
+/- 50+ meters is plenty accurate enough for aviation use in determining lateral position. +/- 10 meters vertically would be wonderful but not always obtained. I confess I couldn't have guessed that )Btw, just out of interest - does TCAS use GPS data in some ways too? No. ADS-B does, but not TCAS. Thanks, but how exactly does the TCAS get the coordinates of the transponder it talks to, in determining whether or not an evasive mechanism needs setting in? Anything like a +/- 50 meter accuracy there would be disastrous. Ramapriya |
ups.com... Thanks, but how exactly does the TCAS get the coordinates of the transponder it talks to, in determining whether or not an evasive mechanism needs setting in? Anything like a +/- 50 meter accuracy there would be disastrous. TCAS typically uses the transponder output to determine altitude of the other traffic, and basic radio direction and range-finding processing to determine direction and distance. For the purpose of TCAS, +/- 50 meters is perfectly sufficient. Alerts are provided at distances much greater than that, and an error of 50 meters would affect the timing of the alert by a second or less. When in a congested area, where TCAS is most typically important, airplanes are traveling on the order of 50-100 meters per second. You seem to be under the impression that flying involves a very high degree of accuracy with respect to position information. That's simply not true. Even in a differential GPS precision approach or a Cat III ILS, accuracy is only to within a meter or so, and for anything else tens, hundreds, or even thousands of meters is sufficient (depending on the exact situation). In addition, while you are relying on your GPS receiver for altitude, airplanes almost never do. They have barometric altimeters that provide a different reference (not necessarily more accurate...just different) that is more appropriate for the operation of an airplane (generally speaking). So the GPS data is used only in two dimensions, in which the instantaneous accuracy is generally much better, as compared to 3D accuracy including altitude. Your demand for accuracy in construction is FAR greater than any need aviation has. As far as the difference in the GPS receiver goes, it is likely that the basic operation of the GPS receiver you are using is identical to that of an aviation handheld. That said, I'm surprised you are using sample averaging to gain the accuracy you need. Surveyors do use differential GPS with great success, and it provides similar accuracy to what you're getting, only in a matter of seconds rather than hours. (DGPS used for surveys has better accuracy than that used for aviation because the reference point is so close to the measured location in the case of surveying, whereas it may be quite a distance away for aviation). Pete |
requires to be both very precise and instantaneous, my equipment is very much inferior to what's used in aviation. Well, several wrong assumptions here. 1. Most airline aircraft do not or not regularly use GPS to "navigate across the globe". They use inertial navigation. Some use inertial navigation with position updates from GPS. GPS is typically used in general aviation aircraft - because it is cheap. 2. For enroute navigation, GPS accuracy of the standard signal (50 meters or so) is plenty accurate, altitude is measured with barometrics, not GPS. For approaches to airports, the prevalent method of navigation is not GPS, but other means (google ILS and VOR). GPS approaches can make do with standard GPS signals, however, in the US more and more approaches using WAAS (a method of differential GPS) as an enhanced signal. However, the approaches down to an automatic landing are never done with GPS, they use ILS. 2. The key problem in aviation with GPS is immediate feedback to the airplane in case the signal goes bad, aka signal integrity monitoring. Certified aviation GPS receivers have higher standards in that regard. -- Thomas Borchert (EDDH) |
In a previous article, said:
I guess since you folk use GPS to navigate all across the globe and requires to be both very precise and instantaneous, my equipment is very much inferior to what's used in aviation. Years and years ago, I was told how to access some diagnostic modes on my Garmin GPSMAP 195. The diagnostic mode showed the state of all sorts of internal stuff, and from that it was apparent that one major difference between the aviation 195 and the marine 175 is that the 195 had temperature and pressure sensors. I suspect they put that in there so that they could correct the results from the GPS radio for those factors. The other major difference was that the 195 had WAY more flash memory to store all those aviation waypoints. But the fact of the matter is that aviation or not, GPS doesn't do altitude as precisely as position because of the basic geometry. There are numerous explanations of why on-line. So for aviation use, we either need WAAS (which might or might not be available) or use a barometric altimeter for altitude, and for surveying you let it sit so it can accumulate a lot of data and integrate it. As a former surveyor, I can tell you that the altitude requirements for surveying are a lot more precise than for aviation - if my bridge abutment is built 2 feet high, I'm getting fired. If my plane is 2 feet high, nobody is going to notice. -- Paul Tomblin http://xcski.com/blogs/pt/ "All life is transitory. A dream. We all come together in the same place at the end of time. If I don't see you again here, I will see you in a little while in the place where no shadows fall." - Delenn |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Airmens' Freedoms Threatened by Harsh Congressional Proposals | Larry Dighera | Piloting | 24 | July 29th 05 07:15 PM |
| Aviation Books&CD Roms FS | [email protected] | Home Built | 0 | April 10th 05 11:29 PM |
| General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Home Built | 3 | May 14th 04 12:55 PM |
| General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Owning | 0 | May 11th 04 11:43 PM |
