![]() I think the statisticians would say that you are running into the "rule of small numbers"; ie. with such a small sample it's hard to make any reliable generalizations. To put it a different way, how many pilots are capable of winning a nationals at any given contest (leaving aside ships for a minute)? Realistically, maybe 1/3 of the competitors are truly national caliber; the others are there to prop up the bottom of the scoresheet. I'm sure others would argue that the number of potential champions is lower . So, let's say that there are 10 folks on average in a SC nationals who have the potential to win. So, the unadjusted probability is 10% that someone like Manfred will win under this scenario. Now, throw in the fact that certain guys seem to win contests again and again (I'll use Gary Ittner as an example in the 15M, flying his "old" Ventus C against all of the new ASW-27s and V2s as a for instance). So, the probability for the "rest of us" is really pretty small. The fact that 2 true Club Class ships have won in the last 10 years means that they are statistically over-represented and the handicaps need to be revised in favor of the more modern ships :-)))) Well, as my Mammy used to say, "Be careful what you wish for, cuz you just might git it!". I was hoping that my rabble-rousing would generate some thoughtful discussion, and apparently I'm getting my wish! ;-). Yes, I agree that my data base is woefully small. However, more than about 10 years of data kinda defeats the purpose of the argument anyway, as the gliders and the pilots will have evolved significantly over that time . Actually it was just this paucity of data that caused me to focus on HF as the poster child for SC (my apologies to Manfred), as this is the clearest case I can see where a very good pilot in an SC ship has difficulty competing against very good pilots in ASW-XXs (where X is greater than 20 or so). BTW, regarding the probabilities you mentioned, it would seem that if Manfred's per-contest probability was on the order of 0.1 and he competed in more than 5 or 6 nats, he should have (in the sense that anything over 0.5 is 'likely') won one by now. Seriously, I think a couple of other posts all alluded to the fact that there are some good reasons why the current handicap system in the US is a compromise. If you really want to get under the numbers, create a simple model in a spreadsheet. Under average Eastern conditions (say a course of 150 miles with 300fpm average lift), you can calculate the time to climb and the time to cruise using the published polars. The 7% handicap (actually more like 7.5%) the LS3 has over the ASW-27 is VERY significant. However, get the cruise speeds up with either ridges or strong thermals, and the newer gliders have an advantage. I have a basic problem with the above modeling approach, and that is that I find it difficult to believe that a 25 year old glider can still achieve its published polar (assuming it ever did), no matter how well prepared. I borrow from my power background, where aircraft performance numbers are routinely inflated by the manufacturers and are just as routinely missed by the actual aircraft. However, newer aircraft do come closer than older ones, pretty much regardless of type. Having said that, I really don't know if Manfred's LS-3 can still achieve its numbers (maybe it even exceeds them now!). I thought the South African model described earlier is interesting, as it tries to use the actual results to deterimine the day's handicap. On the other hand, some folks will find it difficult to accept that the results are adjusted so dynamically... Ah, the handicapped bowling league approach. I actually think this might be a viable approach, in that it tends to make it easier for a newcomer to do well (but, maybe this is yet another thing I should be careful about wishing for...) As far as the LS-3 swap, I'll take a different tack. I'll see what I can do to line up an LS-4 to go head-to-head with you. Loser each day buys the beer :-)) Oops! You have clearly mistaken me for someone willing to put his glider (or at least his beer) where his mouth is! ;-). However, given the fact that I will almost certainly never be able to afford anything better, and that I do plan to fly it in our SC Nats next year - bring it on! ;-)))) Frank (X3) |
![]() Frank wrote: I think the statisticians would say that you are running into the "rule of small numbers"; ie. with such a small sample it's hard to make any reliable generalizations. To put it a different way, how many pilots are capable of winning a nationals at any given contest (leaving aside ships for a minute)? Realistically, maybe 1/3 of the competitors are truly national caliber; the others are there to prop up the bottom of the scoresheet. I'm sure others would argue that the number of potential champions is lower . So, let's say that there are 10 folks on average in a SC nationals who have the potential to win. So, the unadjusted probability is 10% that someone like Manfred will win under this scenario. Now, throw in the fact that certain guys seem to win contests again and again (I'll use Gary Ittner as an example in the 15M, flying his "old" Ventus C against all of the new ASW-27s and V2s as a for instance). So, the probability for the "rest of us" is really pretty small. The fact that 2 true Club Class ships have won in the last 10 years means that they are statistically over-represented and the handicaps need to be revised in favor of the more modern ships :-)))) Well, as my Mammy used to say, "Be careful what you wish for, cuz you just might git it!". I was hoping that my rabble-rousing would generate some thoughtful discussion, and apparently I'm getting my wish! ;-). Yes, I agree that my data base is woefully small. However, more than about 10 years of data kinda defeats the purpose of the argument anyway, as the gliders and the pilots will have evolved significantly over that time . Actually it was just this paucity of data that caused me to focus on HF as the poster child for SC (my apologies to Manfred), as this is the clearest case I can see where a very good pilot in an SC ship has difficulty competing against very good pilots in ASW-XXs (where X is greater than 20 or so). BTW, regarding the probabilities you mentioned, it would seem that if Manfred's per-contest probability was on the order of 0.1 and he competed in more than 5 or 6 nats, he should have (in the sense that anything over 0.5 is 'likely') won one by now. Seriously, I think a couple of other posts all alluded to the fact that there are some good reasons why the current handicap system in the US is a compromise. If you really want to get under the numbers, create a simple model in a spreadsheet. Under average Eastern conditions (say a course of 150 miles with 300fpm average lift), you can calculate the time to climb and the time to cruise using the published polars. The 7% handicap (actually more like 7.5%) the LS3 has over the ASW-27 is VERY significant. However, get the cruise speeds up with either ridges or strong thermals, and the newer gliders have an advantage. I have a basic problem with the above modeling approach, and that is that I find it difficult to believe that a 25 year old glider can still achieve its published polar (assuming it ever did), no matter how well prepared. I borrow from my power background, where aircraft performance numbers are routinely inflated by the manufacturers and are just as routinely missed by the actual aircraft. However, newer aircraft do come closer than older ones, pretty much regardless of type. Having said that, I really don't know if Manfred's LS-3 can still achieve its numbers (maybe it even exceeds them now!). I thought the South African model described earlier is interesting, as it tries to use the actual results to deterimine the day's handicap. On the other hand, some folks will find it difficult to accept that the results are adjusted so dynamically... Ah, the handicapped bowling league approach. I actually think this might be a viable approach, in that it tends to make it easier for a newcomer to do well (but, maybe this is yet another thing I should be careful about wishing for...) As far as the LS-3 swap, I'll take a different tack. I'll see what I can do to line up an LS-4 to go head-to-head with you. Loser each day buys the beer :-)) Oops! You have clearly mistaken me for someone willing to put his glider (or at least his beer) where his mouth is! ;-). However, given the fact that I will almost certainly never be able to afford anything better, and that I do plan to fly it in our SC Nats next year - bring it on! ;-)))) Frank (X3) The LS-3 goes like stink out west. It's problem back east is that it can't jettison the wing loading of it's 180+lb panels when the lift gets wimpy. http://tinyurl.com/jmkby http://tinyurl.com/j8xth 27's do okay out west also http://tinyurl.com/z6cfm http://tinyurl.com/kvzfl as do all manner of Ventii You'll find a better sampling if you use the regionals results for the past several years, but I doubt the conclusions will stand. Region 9, 1998, Gary Osoba won in a Woodstock again a wide variety of handicaps. http://tinyurl.com/hzddc Interestingly, there's an SSA Committee concerning SC handicapping. http://tinyurl.com/fgfn4 Input and volunteers are always welcomed. Ask a member of any SSA committee. The biggest problem is getting input. Frank Whiteley Colorado |
![]() Frank wrote: Well, as my Mammy used to say, "Be careful what you wish for, cuz you just might git it!". I was hoping that my rabble-rousing would generate some thoughtful discussion, and apparently I'm getting my wish! ;-). I have a basic problem with the above modeling approach, and that is that I find it difficult to believe that a 25 year old glider can still achieve its published polar (assuming it ever did), no matter how well prepared. I borrow from my power background, where aircraft performance numbers are routinely inflated by the manufacturers and are just as routinely missed by the actual aircraft. However, newer aircraft do come closer than older ones, pretty much regardless of type. Having said that, I really don't know if Manfred's LS-3 can still achieve its numbers (maybe it even exceeds them now!). That's a difficult line of reasoning to head down! If you read Johnson flight tests over the years, you'll see that even factory fresh ships sometimes don't live up to expectations. In addition, you'll definitely find that a lot of 2-4 year old ships right now are suffering from significant airfoil "issues." My strong belief is that the variability in performance in a given model (e.g. "best" vs. "worst" LS4s) far outweighs the margin of error with handicaps. If someone is really serious about winning in SC, the first thing they ought to due is to tune the heck out of their ship by sealing and smoothing. Right off the bat, they'd probably gain 2-3% points against the competition. Anyway, a great thread with some very good ideas tossed out along the way. P3 |
So for the sake of what we do best in soaring...adding
complexity ![]() Class might include: 1.) A weather component factored to reflect how various ships perform by condition. 2.) A pilot handicap sort of like golf. Factor in weight of pilot. 3.) A sealed and smoothed component to equalize the unmaintained birds with those that have been cleaned up. 4.) Maybe even assign an instrumentation handicap? Big bonus for flying with sectionals and cameras. Probably several other items I have overlooked ![]() |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Please e-mail EAA and ask them to include gliders in Sport Pilot | Mark James Boyd | Soaring | 6 | December 1st 04 05:52 PM |
Winch Experts wanted | Ulrich Neumann | Soaring | 117 | April 5th 04 06:52 AM |
I wish I'd never got into this... | Kevin Neave | Soaring | 32 | September 19th 03 12:18 PM |
Restricting Glider Ops at Public Arpt. | rjciii | Soaring | 36 | August 25th 03 04:50 PM |
