#71
![]() Dave Kearton wrote: Jeff Crowell wrote: Jeff Saying "Guns kill people" is like saying "Spoons made Rosie O'Donnell fat." Guns don't kill people, husbands who come home early kill people. Geez, Dave - if you know something about his schedule that I don't know, just TELL me! yfG |
#72
![]() " wrote: Ed Rasimus wrote: Ever been on the wing in the weather at night in a single-seat jet? Didn't think so. "Merely capable" translates as pretty damn good in terms of most folks capabilities. You're drifting off topic, Eddy. The topic isn't about whether I (or any other poster, for that matter) has ever been a jet pilot. Oh, yes it is, punk. You just don't know it. Billy http://www.two--four.net/weblog.php |
#73
On Thu, 13 Jul 2006 23:10:07 -0600, "Jeff Crowell"
Jcrow9DOTcableone.net wrote in :: Just for the hell of it, do you know if he knew that he was entering terminal airspace? In this case, USAF Brigadier General ROBIN E. SCOTT, President of the USAF accident investigation Board (not exactly an impartial observer), found that Flight Lead Parker's decision to intentionally descend into congested Class B terminal airspace at over 400 knots without the required ATC clearance not to constitute "a deliberate disregard for the safety of others." In fact, his report intimates that the cause of Parker's misbehavior was a loss of situational awareness, which lead to the death of Jacques Olivier, was a malfunction of the navigation electronics on board Parker's southbound F-16, when in fact, the documented equipment errors actually placed Parker 10 NM farther north from the center of the Tampa Class B airspace than he believed he was at the time. That is to say, Parker would have been inside Tampa Class B airspace without the required ATC clearance for many more miles had he actually descended at the position he believed he was located instead of the position the malfunctioning/miss-operated navigational.equipment placed him. The facts presented in the Air Force accident report support my contention that Parker intentionally, willfully, deliberately and recklessly descended into a very congested terminal area in excess of 400 knots and without being in communication with the authority responsible for separating aircraft in that airspace, and without regard for the life and safety of the civilians operating there nor those residing under his flight path. Assuming the Air Force accident report is 100% factual, it indicates that Parker, Ninja Flight Lead, began his descent into Tampa Class B airspace at a point he believed at the time was ~15 miles inside its boundary. Any airman, even an illustrious Air Force pilot, knows that the dimensions of Class B areas are roughly a 30 NM radius from the central airport (KTPA in this case). Parker was aware he was above Tampa Class B airspace when he recklessly decided to descend through it, or he is a careless and incompetent pilot (or both). The errors in the systems did not cause this mishap. According to the Air Force accident report, he INS system mysteriously developed a ~10 NM southerly steering error spontaneously, subsequent to the first sortie. This had the effect of indicating that the aircraft's position was ~10 NM south of its true position. Parker failed to do the _required_ position check which would have detected this error. Parker also erroneously input a slew error, and failed to make the _required_ check when he engaged that navigation equipment. The results of that error placed him 5 NM west of his indicated position. Neither of the errors, electronic nor Parker's erroneous input, were adequate in explaining why a highly trained Air Force pilot chose to descend into Tampa Class B airspace at what Parker's navigation equipment indicated was 15 miles inside the Class B boundary at the time. The malfunctioning/misdialed navigational errors actually assisted Parker's flight in being closer to the edge of the Class B area when he chose to descend (at 140 knots in excess of his aircraft's minimum safe speed in violation of FAR 19.117(d)) without a clearance into the congested Class B terminal area. So the navigational system errors lessened the time Parker's flight posed a threat to Class B air traffic. THE NAVIGATIONAL ERRORS DO NOT IN ANY WAY EXCUSE PARKER FOR HIS RECKLESS ACTIONS. In fact the opposite is true. There is no doubt in my mind that Parker's decision to descend into the Tampa Class B area without the required ATC clearance was deliberate and intentional; He had to be aware that he wasn't clear of the class bravo airspace. I believe Parker's decision to recklessly descend without a clearance was a result of the situation created by all the careless errors he made. Due to Parker's canceling IFR and failure to contact Tampa Approach Control because he input the wrong frequency in his radio, he either had to descend without a clearance, or fly past the MTR entry point. He thought he was ~10 NM closer to the MTR entry point then he actually was at the time. Parker just chose to chance what he thought would be only a few moments of violating FARs, and indulged in unprofessional, unsafe operation, rather than pausing to safely regain control of the rapidly determining situation. Parker made more than a _few_ careless mistakes and/or reckless decisions. Some of them were indeed minor, but others were unforgivable and deadly. The Air Force accident report mentions these: 1. Lieutenant Colonel Parker did not specifically brief Class B and Class C airspace restrictions in the Tampa area during the flight briefing. Air Force directives _require_ the flight lead to brief applicable airspace restrictions. 2. Canceled IFR with Miami Center. 3. Declined flight following service. 4. Erroneously thought he was given frequency 362.35 by Miami Center and attempted to contact Tampa Approach Control there. 5. Failed to obtain ATC clearance from Tampa Approach for entry into the Tampa Class B airspace. 6. Failed to establish two-way radio communications with Tampa Approach Control prior to entering Sarasota Class C airspace. 7. Failed to adequately deconflict flight path (Air Force training manuals emphasize that flight path deconfliction is a critical task, one that can never be ignored without catastrophic consequences.) 8. Lost situational awareness. 9. Failed to recognize a significant 9 to 11 nautical mile position error in his aircraft's Inertial Navigation System. 10. Did not crosscheck the INS accuracy with other systems. 11. Parker failed to notice the degradation in INS system accuracy. The system showed a navigational system accuracy of 'medium', which eventually degraded to 'low' prior to the collision. 12. Unintentional cursor slew bias input by the pilot. A crosscheck of system indications is _required_ so that unintentional slews are recognized and zeroed out. Parker didn't bother to perform the _required_ crosscheck. 12. Failed to recognize a cursor slew bias in his ground attack steering. 14. Mis-prioritization of tasks. 15. Parker had a normal post-mishap physical examination on 24 November 2000, 8-days after his flight killed Jacques Olivier! I believe the high-speed of Parker's flight reduced the time the pilots had to detect an aircraft on a collision course, and prevented the late Cessna 172 pilot, Jacques Olivier, from maneuvering his aircraft out of the path of the F-16s in time to avoid the collision (which scattered parts of his still warm remains over 4 acres surrounding the 2nd hole of busy Rosedale Golf and Country Club) that afternoon. Olivier's aircraft was in a right turn at the time of the 480 knot (~550 mph) impact, so he had seen the rogue F-16 before it shattered his light aircraft (and virtually caused his body to explode), but because of its excessive speed, he lacked sufficient time to get out of its way. High speed leaves little time for human responses. (I direct your attention to the table in the article included below.) How long does a full windscreen traffic scan take? I believe that the FAA or NTSB standard requires/suggests 15 seconds to scan left to right (but this assumes only one person scanning the whole field of view). How long does it take you to spot an F-16 against low-level ground clutter at 12'O clock and one mile? How frequently do you fail to see traffic called by ATC? We're both pilots. You know what I'm talking about. It is estimated that the average person can detect an object on a collision course (stationary in the field of view rather than moving) when it occupies 12 minutes of arc in the field of view (1/5th of a degree) or (ISTR - badly ![]() range for each m radius of the central mass. Assuming no glare reflection, which can confound any calculation on detection range and probability, statistically, it would take 7.5 seconds to reach 12 O'clock using approved search patterns. (OTOH, if its against low level ground clutter, then its probably not on a collision course with you ![]() [This last sentence may be somewhat true in _level_ flight over _level_ terrain with meteorologically restricted visibility; it is not pertinent otherwise.] If we generously assume that the head-on frontal-area "central mass" of an F-16 is approximately 2 meters, we find that it should be humanly detectable at a distance of ~1,000 meters, or ~3,250 feet. This is roughly 1/2 of a nautical mile. The table of airspeeds equated to feet-per-second below can be used to compute the time-budget available to pilots for visually _detecting_ conflicting air traffic at that distance. It does not take into consideration lighting, contrast, the time necessary to deduce and make _appropriate_ control inputs, nor the time for the aircraft to actually maneuver out of the path of the conflicting aircraft's path. Time Until Impact Closing-speed Feet Per Second At 3,250 Foot Distance ------------- --------------- ---------------------- 250 knots 417 feet per second 7.8 seconds 300 knots 500 feet per second 6.5 seconds 350 knots 583 feet per second 5.6 seconds 400 knots 667 feet per second 4.9 seconds 480 knots 800 feet per second 4.1 seconds From this table it is evident that the pilot of a military aircraft traveling at a 400 knot closing-speed has _inadequate_ time to "see-and-avoid". Using Kerryn Offord's figures, the pilot would have the impossible task of repeatedly, spending 15 seconds, 8 to 12 times a minute, scanning the entire windscreen during that portion of the flight conducted below 18,000 feet. Clearly, there is only time for 4, not 8 to 12, full scans in a minute. So it is not possible to rely solely on visual detection of conflicting air traffic to prevent midair collisions at high-speed. Even if the scan for conflicting air traffic is divided among 4 pilots, there is no time left to do anything else such as visual navigation, tuning radios, ... These calculations only concern detecting the conflicting air traffic, not avoiding collision with it. So, it is patently evident that some other means of collision avoidance must be _required_ to insure the hazard to air-safety posed by high-speed low-level military operations is mitigated. It is also evident that the FAA IS FAILING TO PROVIDE SAFE SKIES for the public when it permits the military to indulge in this reckless high-speed low-level operation. It is my belief that there came a time when Parker had to descend to reach the MTR start point, or admit to his student that he had lost situational awareness. At that instant, he chose to descend into Class B airspace without the REQUIRED ATC clearance, rather than confess his confusion. This would have been consistent with Parker's failure to perform all the other REQUIRED items/checks he failed to accomplish on the mishap sortie. Can you explain how Parker could possibly NOT have known that Class B airspace lay just below him when he descended into it (clear & 10 miles visibility at the time)? Class B airspace is typically 30 nautical miles in radius around the central airport; that's 60 NM in diameter. This particular Class B abuts the Sarasota Class C to the south. The MTR VR1098 start point is ~1 nm outside the boundaries of these areas just west of Manatee Dam. Given VR1098 extends to the eastsoutheast, it begs the question, "how does a flight enter VR1098 WITHOUT being in contact with ATC, and remain within the governing regulations?" To have been UNAWARE that Class B airspace lay beneath the Ninja flight, Parker would have to have been incapacitated in some way. Another reason Parker may not have known his position relative to the Tampa terminal airspace is mentioned in the Air Force AIB report: "Lieutenant Colonel Parker did not specifically brief Class B and Class C airspace restrictions in the Tampa area during the flight briefing. Air Force directives require the flight lead to brief applicable airspace restrictions." The malfunctioning INS erroneously indicated Parker's position to be ~10 miles north of his true location. This resulted in his southbound flight being ~10 miles FARTHER toward the edge of Tampa International (TPA), the core airport, Class B airspace than indicated by Parker's INS. Thus, the INS error actually contributed to moving the flight toward the (presumably safer) periphery of the congested terminal airspace, just not far enough. So, while the INS error may have contributed to confusing Parker, it does not excuse his actions in any way IMNSHO. If he was disorientated, he should have remained above the terminal area until he regained situational awareness. But, Parker was the instructor on this sortie; did his ego play a part in his decisions? Without evidence to the contrary, I have to attribute his decision to descend NORDO into Tampa Class B airspace (and accelerated to 440 KIAS) to unprofessional arrogance rather than lost situational awareness. His failure to perform the required airspace briefing, and failure to perform the required navigational cross-checks is indicative of a lack of professionalism or incapacitation; the AIB report fails to substantiate the later due to the eight day delay in the medical examination of Parker. So if you were unable to contact the Class B ATC controlling authority, would you descend into 60-mile diameter congested Class B terminal airspace without the required clearance? |
#74
SNIP all
Is this personal? You've got a hard-on for this guy like a DA six months before the election. R / John |
#75
![]() "John Carrier" wrote in message . .. SNIP all Is this personal? You've got a hard-on for this guy like a DA six months before the election. R / John Shouldn't that be "erection"? No, I guess not. That would limit the election to Japan. :-) Dudley |
#76
On Fri, 14 Jul 2006 18:36:08 -0500, "John Carrier"
wrote in :: Is this personal? To whom are you referring Parker or Rosa? Parker did a lot of irresponsible things, that resulted in the death of a fellow airman. Rosa let him off with a reprimand. If I had killed someone, I would have stood trial, and if convicted, would have been sentenced. There is little question that Parker should have been subject to the same sort of judicial due process. The only conclusion one can draw is, that our military is above the law. We all share the NAS. I would prefer not to end up like Jacques Olivier splattered over four acres of golf course as a result of lax USAF discipline. I know neither men, so my issue with these events not personal, but their actions have sensitized me to the lack of responsibility apparently rampant in the military. And I'm uncomfortable seeing my tax dollars funding the death of a fellow airman, and the injustice perpetrated against us civilians. So now that I've answered your question, perhaps you'll be good enough to answer one for me. Do you feel that justice was done in this case? |
#77
![]() "Larry Dighera" wrote in message ... On Fri, 14 Jul 2006 18:36:08 -0500, "John Carrier" wrote in :: Is this personal? To whom are you referring Parker or Rosa? Parker did a lot of irresponsible things, that resulted in the death of a fellow airman. Rosa let him off with a reprimand. If I had killed someone, I would have stood trial, and if convicted, would have been sentenced. There is little question that Parker should have been subject to the same sort of judicial due process. The only conclusion one can draw is, that our military is above the law. We all share the NAS. I would prefer not to end up like Jacques Olivier splattered over four acres of golf course as a result of lax USAF discipline. I know neither men, so my issue with these events not personal, but their actions have sensitized me to the lack of responsibility apparently rampant in the military. And I'm uncomfortable seeing my tax dollars funding the death of a fellow airman, and the injustice perpetrated against us civilians. So now that I've answered your question, perhaps you'll be good enough to answer one for me. Do you feel that justice was done in this case? I haven't a clue. Without access to all the original data (as one might have in an MIR), I wouldn't formulate an opinion. I doubt you've had such access, but you've got your opinion, expressed in voluminous and vehement detail. So be it. R / John |
#78
Ed Rasimus wrote:
You might want to research the elements of "murder" before conducting much more slander. You might also want to spend some time in a single-seat, single-engine aircraft making decisions at the speed required by the job on a daily basis. Would Criminally Negligent Manslaughter be more appropriate? Had he been at the legally required speed, he would have had twice the time to make the necessary decisions. Using that term would be fine with me.. it's still a felony.. Dave |
#79
http://www.sourcewatch.org/index.php...ndy_Cunningham
Table of contents 1 Bio 1.1 Background 1.2 Congressional Career 2 Meet the Cash Constituents 2.1 Campaign Contributions from Defense Industry 3 Controversy 3.1 Del Mar Real Estate "Deal" 3.1.1 Realtor was campaign contributor 3.1.2 Subsequent Rancho Santa Fe Real Estate "Deal" 3.1.3 Tom DeLay Defended Cunningham 3.2 Boat purchases, sale and "free rent" 3.2.1 Kelly C 3.2.2 Duke Stir 3.2.3 Boat #3 and Brent Wilkes 3.3 Wilkes/ADCS Investigation 3.4 War Profiteering? 3.5 Money Laundering? 3.6 Post-conviction 3.7 Honored in Washington 3.8 Use of classified bills for personal gain 4 Committees and Affiliations 4.1 Committees 5 More Background Data 6 Resources and Articles 6.1 Resources 6.2 Articles & Commentary 6.3 SourceWatch Resources ------------------------------- http://en.wikipedia.org/wiki/Randy_Cunningham Sentencing On March 3, 2006, U.S. District Judge Larry A. Burns sentenced Cunningham to 100 months (eight years and four months) in prison.[46] Federal prosecutors had pushed for the maximum sentence of ten years, but Cunningham's defense lawyers said that at 64 years old and with prostate cancer, Cunningham would likely die in prison if he received the full sentence.[47][48]. Judge Burns cited his military service in Vietnam as the reason the full ten years was not imposed. Prosecutors announced that they were satisfied with the sentence, which is the longest jail term ever given to a former Congressman.[49] On the day of sentencing, Cunningham was 90 pounds (41 kg) lighter than when allegations first surfaced 9 months earlier. After receiving his sentence, Cunningham made a request to see his 91-year-old mother one last time before going to prison. "I made a very wrong turn. I rationalized decisions I knew were wrong. I did that, sir," Cunningham said. The request was denied, and Burns remanded him immediately upon rendering the sentence.[50] According to the Inmate Locator at the Federal Bureau of Prisons website, Cunningham is currently incarcerated at the low-security wing of the Butner Federal Correctional Complex in Butner, North Carolina with inmate register number 94405-198. His projected release date is listed as June 4, 2013. Aftermath Almost as soon as Cunningham pled guilty, Intelligence Committee chairman Pete Hoekstra of Michigan (who, ironically, represents Guy Vander Jagt's former district) announced his panel would investigate whether Cunningham used his post on that committee to steer contracts to favored companies. Hoekstra said that Cunningham "no longer gets the benefit of the doubt" due to his admission to "very, very serious" crimes. "We need to look at worst-case scenarios," he added. He also shut off Cunningham's access to classified information. While Hoekstra doesn't believe that Cunningham improperly influenced the Intelligence Committee's work, a committee spokesman said that he wanted to make sure its work stayed on the level.[51] Bill Young of Florida, chairman of the Defense Appropriations Subcommittee and former chairman of the full Appropriations Committee, said that he plans to review Cunningham's requests for defense projects. While he felt most of the requests were legitimate and supported by the Pentagon, he said that he needed to be "doubly sure that anything shaky is not going to stay in."[52] On December 14, prosecutors in former House Majority Leader Tom DeLay's money laundering trial revealed that they are looking into ties between Wilkes and DeLay. One of Wilkes' companies donated $15,000 to DeLay's PAC, Texans for a Republican Majority. Wilkes also hired a consulting firm that employed DeLay's wife, Christine.[53] On January 6, 2006, Time reported that Cunningham cooperated with law enforcement by wearing a concealed recording device (a "wire") while meeting with associates prior to his guilty plea. It is not known whom he met with while wired, but there is speculation Cunningham's misdeeds were not isolated instances and his case could reveal a larger web of corruption.[54] On February 24, 2006, Mitchell Wade pleaded guilty to paying Cunningham more than $1 million in bribes in exchange for millions more in government contracts.[55] In March, it was revealed that CIA officials have opened an investigation into the CIA's No.3 official, Kyle Foggo, and his relationship with Wilkes, "one of his closest friends," according to the article. Foggo has said that all of the contracts he oversaw were properly awarded and administered.[56] On April 17, 2006, the staffs of the The San Diego Union-Tribune and Copley News Service were awarded the 2006 Pulitzer Prize for National Reporting for their investigative work in uncovering Cunningham's crimes.[57] On May 12, 2006, FBI officials raided the Vienna, Virginia home of former CIA official Kyle "Dusty" Foggo in connection with the scandal.[58] On June 6, 2006, Republican and former congressman Brian Bilbray won the run-off election for Cunningham's seat, narrowly defeating Democrat Francine Busby. The current term ends in 2006, so Bilbray will face another election in November.[59] ----------------------------------------- http://cunningham.house.gov/Biography/ Randy "Duke" Cunningham was born December 8, 1941, in Los Angeles, California. After earning his bachelors degree in 1964 and his masters in education in 1965 from the University of Missouri, Cunningham began his career as an educator and a coach at Hinsdale (Ill.) High School. As a swimming coach, Duke trained two athletes to Olympic gold and silver medals. He later expanded his education experience as the Dean of the School of Aviation at National University in San Diego. In 1966, at the age of 25, Cunningham joined the U.S. Navy and became one of the most highly decorated pilots in the Vietnam War. As the first fighter ace of the war, Cunningham was nominated for the Medal of Honor, received the Navy Cross, two Silver Stars, fifteen Air Medals, the Purple Heart, and several other decorations. Duke's experience in Vietnam and his background as an educator prepared him well to train fighter pilots at the Navy Fighter Weapons School -- the famed "Top Gun" program at Miramar Naval Air Station. As Commanding Officer of the elite Navy Adversary Squadron, Cunningham flew Russian tactics and formations against America's best combat fighter pilots. Many of his real-life experiences as a Navy aviator and fighter pilot instructor were depicted in the popular movie "Top Gun." Upon his retirement from the Navy in 1987, Cunningham translated the Masters in Business Administration he earned at National University into a successful business in San Diego. In 2004, the people of California's 50th Congressional District elected Duke Cunningham to his eighth term in the House of Representatives. As the voters returned a Republican majority to both chambers of Congress, Congressman Cunningham retained his position on the powerful House Appropriations Committee. Cunningham serves on the Labor, Health and Human Services, and Education Appropriations subcommittee, which is instrumental in providing key funding for education and medical research, two of his priorities. He also serves on the panel's Defense subcommittee, which provides funding for our national defense and armed services. At the beginning of the 109th Congress, Cunningham was selected to serve as the Chairman of the Subcommittee on Human Intelligence Analysis and Counterintelligence on the House Select Committee on Intelligence. Cunningham was first named to the Permanent Select Committee on Intelligence by Speaker Hastert in the 107th Congress. His extensive military experience, continued service on defense and intelligence committees, and recognition as a congressional leader on national security issues make him an ideal fit for this prestigous position. Through his committee assignments and the pursuit of his legislative priorities, Congressman Cunningham continues to work for a stronger economy; quality education for our children, a strong and efficient national defense; and smart investment in medical research and innovation. He places a priority on the effective use of taxpayer resources for our children's future. Several organizations have honored Congressman Cunningham for his work in Congress. Most notably, he has been recognized for his work as a fiscal conservative by such organizations as Citizens for a Sound Economy, the National Taxpayer's Union, and the National Federation of Independent Businesses. He has also been recognized by education groups for his tireless advocacy and by several law enforcement organizations for his tough-on-crime position. Duke and his wife Nancy, the Director of Administrative Support Services for the Encinitas Union School District, have three children -Todd, April and Carrie. Contact Duke Cunningham 2350 Rayburn House Office Building Washington, DC 20515 (202) 225-5452 (202) 225-2558 fax 613 West Valley Parkway Suite 320 Escondido, CA 92025 (858) 755-8382 (760) 737-8438 (760) 737-9132 fax ------------------------------------------------------------------- On Fri, 07 Jul 2006 23:39:14 GMT, Larry Dighera wrote in : http://edition.cnn.com/TRANSCRIPTS/0603/04/cst.02.html WHITFIELD: The Democrat who delivered the address is Francine Busby, the party's candidate to replace former Republican Congressman, Randy "Duke" Cunningham of California. Cunningham is now serving a federal prison term for bribery. The San Diego Republican was sentenced yesterday to eight years and four months for taking bribes from at least three defense contractors. CNN's chief national correspondent, John King, takes a closer look at Cunningham's career and his fall from power. (BEGIN VIDEOTAPE) JOHN KING, CNN CORRESPONDENT (voice-over): Randy Cunningham and high risk have been partners a long time. UNIDENTIFIED MALE: His name is Randy "Duke" Cunningham, and he is a legend of air power. KING: The Vietnam ace whose daring exploits were an inspiration for Maverick in Hollywood's "Top Gun." VAL KILMER, ACTOR: I don't like you because you're dangerous. TOM CRUISE, ACTOR: That's right, Iceman. I am dangerous. KING: And from famous war hero, Cunningham parachuted into a seemingly less risky business: politics. RANDY "DUKE" CUNNINGHAM (R), FORMER CALIFORNIA REPRESENTATIVE: Duke Cunningham, running for U.S. Congress. UNIDENTIFIED FEMALE: Duke Cunningham will be a congressman we can be proud of. KING: Now 16 years after that first campaign, San Diego Congressman Duke Cunningham's exploits are once again the stuff of Hollywood. CUNNINGHAM: I broke the law, concealed my conduct and disgraced my office. KING: His corruption is stunning in its scope and in its sheer audacity: $2.4 million in bribes, at least. Private jets for resort getaways. A California mansion. A Rolls Royce. A lifestyle well beyond his means and a thirst for more. That appetite, longtime friends like Charles Nesby say, perhaps were some of the traits that made Duke Cunningham a successful ace. Cockiness. CAPT. CHARLES NESBY, CUNNINGHAM FRIEND: That's the nature of the beast in all of us that are fighter pilots. You're naturally aggressive. KING: Naked avarice is what prosecutors call it. And look at this. Cunningham actually scribbled this bribe menu on his congressional notepad. Want a $16 million contract? The cost is a boat, "BT" for short, worth $140,000. Add in another $50,000 for each additional million dollars in contracts. NORMAN ORNSTEIN, AMERICAN ENTERPRISE INSTITUTE: What Cunningham did is breathtaking. KING: Norman Ornstein has been studying Congress for 30 years and says there has been nothing like this before. ORNSTEIN: This is somebody who set out to live a lavish lifestyle by making sure he could shake down contractors, lobbyists and interest groups. KING: Thousands of dollars in meals, at the Capital Grille and other pricey Washington restaurants, Cunningham's tab picked up by defense contractors. Private jets, again, paid for by contractors, to whisk the congressman around the country. Then trendy Delano Hotel on Miami's South Beach was one destination two years ago: $1,254 for the room, $848 for Cunningham's meals at the hotel. Nearly $13,000 for the chartered jet. Cunningham grew to expect luxury, the prosecution memo says. His co-conspirators eagerly plied him with it. He was, after all, on the House Appropriations Committee, a leading voice on its defense subcommittee, able to enter multimillion dollar favors into the Pentagon and other budgets. His Navy days gave him standing on military matters, and stories via the big screen. CUNNINGHAM: I met my wife by singing, "You Lost That Loving Feeling" to her at the Miramar officer's club. KING (on camera): Perhaps they should have raised questions, some friends say, when a congressman with a $165,000 a year salary bought a penthouse condominium here just outside Washington, in addition to the pricey home he owned in southern California. (voice-over) The condo came courtesy of a defense contractors' $200,000 down payment. Inside, tens of thousands of dollars worth of antiques the congressman demanded in exchange for favors, all now in a warehouse awaiting government auction. This is the boat from the bribe menu, The Duke-Stir, a flashy exhibit of Cunningham's lifestyle. Real estate records like these, the more mundane evidence that would begin his fall from grace. November, 2003, Cunningham sold his home in Del Mar to a defense contractor for nearly $1.7 million. The contractor lost $700,000 when he resold it. That caught the eye of a Copley News Service reporter, and then that caught the eye of the feds. What they found is eye popping. NESBY: It's the power, and then some people handle the power correctly. Other people, the power can be misused. Duke lost his moral compass. KING: Nesby is one of 40 Cunningham friends and family members who wrote the judge, appealing for leniency. In his letter, Nesby recalled the white naval officer who took a risk, standing up for a young black pilot. NESBY: It was not popular for him to do that, but I appreciated it. What he did, he leveled the playing field and allowed me to compete and gave me what I deserved. And I'll always love him for that. KING: In his note to the judge, Cunningham wrote, "It all started very slowly and innocently," that he's sorry, worried about dying in prison. But "I will accept your sentence without complaint." UNIDENTIFIED MALE: Randy "Duke" Cunningham will be remembered as an educator, a legislator, but most of all, as a legend of air power. KING: A career that is the stuff of Hollywood. Then... CUNNINGHAM: In my life I have had great joy and great sorrow. And now I have great shame. KING: ... and now. John king, CNN, Washington. (END VIDEOTAPE) |
#80
![]() Larry Dighera wrote: snip vast amount of info readily available elsewhere on the net Any particular reason you did that? Why not post the link, instead of posting yards of text straight off another website? Gordon |
