#21
![]() "kontiki" wrote in message ... Michael Ware wrote: That will be a while, that's about what a used 296 (in good cond with accesories) brings. So be it. The 296 is too slow.. we have 'em in the 182's we use for fire patrol and my 196 is way faster. Too slow...? I've never had any trouble with mine? What do you mean? |
![]() Yes, except for the faster update, EVERYTHING ELSE could be provided to owners of a 396 via software and be put on the data card. Wanna bet they don't offer it? I'm sure they won't, but I'm also not sure that you get all that on a data card and access it at a reasonable rate. The 496 must have quite a lot more memory than the 396, and processing that data will take horsepower, too. Well, the street maps for the 396 are already available on CD for installation on the data card. The 496 just has the internal memory to store them without a data card. Garmin basically just "threw in" the auto kit. Taxiways are nothing more than "streets", so they could easily be put on a card. The AOPA Directory is mixed text and graphics that are the same as other text/graphics that the 396 already displays. Add a tab to the airport listing page and pull up the AOPA data and taxiways. A 1Gb card should do it all for a couple of major metro areas, the taxiways, and the AOPA directory. May even need less. Someone would have to do the math. The data itself for the taxiways and the AOPA directory may exist outside the Garmin walls. Not sure what the license would cost or if they gave Garmin an exclusive for the taxiway coordinates/data and the AOPA data. The cards are also available from an alternate source (or you could just buy one from Garmin). The rest is getting the data formatted for the 396 and tweaking their firmware. Not a monumental chore. You are flirting with the license prohibition against reverse engineering. If you don't sell it or give it away... well... The biggest headache would be updating your firmware patch whenever Garmin put out an update that stomped on it. The usual problem when you mess with factory code. Not sure what the "real" data card is inside those Garmin proprietary wrappers, but I'm sure the speed of today's cards should be plenty fast enough. They must be because the auto kit essentially already does this (street moving maps via the data card). How fast does it need to be to display a moving map of a taxiway when moving at 10kts? Sounds like an interesting project. I would rather Garmin did it for a reasonable price though. Good Luck, Mike |
Mike Granby wrote:
Thomas Borchert wrote: so what exactly is different from the 396? Faster update; integrated street maps; better terrain resolution; taxiway information; AOPA directory. All in all, not that much, but the faster update might tip it for me. and private airports DB - a feature I'd like. Interestingly, having flown in and out of our private grass strip a few times, we have a very nice set of tracks on the Garmin that outline the runway and taxiway. It appears that in zero-zero conditions, one could taxi from the runway to my hangar door just following the tracks. Sort of a every-man's runway/taxiway diagram. If it cools off a bit, I may just take the hood and a safety pilot and see if it works.... remember 'dither'? May it RIP. |
#24
Michael Ware wrote:
Too slow...? I've never had any trouble with mine? What do you mean? My mistake, I re-read your first post... I was referring to the 295. |
#25
![]() "ktbr" wrote in message ... Michael Ware wrote: Too slow...? I've never had any trouble with mine? What do you mean? My mistake, I re-read your first post... I was referring to the 295. No problem. My 296 is the first handheld GPS I have ever owned, so nothing to compare it to. Does what I need! |
#26
On 19 Jul 2006 15:46:07 -0700, "Mike Granby" wrote
in om:: Just got this... JA Air Center, your Garmin source, is pleased to announce the new Garmin GPSmap 496 with XM Weather, Terrain, AOPA Airport Guide, Taxiway Database, and built in StreetPilot Automotive GPS. http://www.avshop.com/prodinfo.asp?number=6957 Item Number : 6957 List Price: $2,995.00 You Save: $200.00 AvShop Price: $2,795.00 |
Garmin GpsMap 396 - Flight Test #2 | Mike Spera | Owning | 17 | July 9th 06 01:21 PM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Piloting | 10 | March 23rd 05 01:16 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Products | 10 | April 29th 04 06:57 AM |
Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 09:32 PM |
