![]() One of our club aircraft was recently on an IFR flight plan in VMC. The instrument student and his instructor noted that the DG was precessing excessively. They eventually canceled the flight plan and returned to their point of origin VFR. In canceling with ATC, they mentioned something about the DG having a problem. Later that day, the club received a call from the FSDO about the "vacuum failure" experienced by one of our aircraft. I've since chatted with the [nice] fellow from the FSDO myself (as one of the people involved in aircraft maintenance in the club). He explained that this was a part of a long-standing policy. Equipment failures that are reported to ATC are reported by ATC to the local FSDO. The FSDO checks into this, confirming that the problem was "resolved" by a mechanic before the aircraft flies again. The example he used was that of an RG with a flickering gear light. Assume the pilot reports the light to the tower. Further assume that the landing is uneventful (ie. the gear holds) and the flickering stops after landing. In this case, the FSDO is going to check that the aircraft received maintenance before it was flown again. I asked about the case where the above landing occurred at a field w/o services. He said that a mechanic should be brought in before the plane is flown to confirm that the gear is down and locked. There was a significant level of ambiguity in what I was told. He mentioned several times in the explanation that part of the trigger in the case of our aircraft was cancellation of the flight plan. I pointed out that I'd canceled IFR flight plans plenty of times. He then said that the difference was that my cancellations were typically when starting a visual approach to my intended airport, and the event under discussion involved an airplane not reaching its original destination. I pointed out that, once I was VFR, nobody knows where I land. He agreed with a little confusion. I know that the FAA has an interest in assuring that aircraft with problems are repaired. So do pilots. But I have never heard of this before. I wonder how well this long-standing policy handles subtleties like a VFR flight in an aircraft with a too-quickly precessing DG. And what are the possible sanctions? I was a little afraid to ask about that last point laugh. Is anyone familiar with this policy? I'd love to see some of the gaps filled in. Thanks... Andrew http://flyingclub.org/ |
I've never heard of that policy either.
I would have asked the FSDO inspector which section of the inspector's handbook covers that policy. It would seem it should be covered by FAR too. http://www.faa.gov/library/manuals/e...spectors/8300/ Airworthiness Inspector's Handbook, Order 8300.10 http://www.faa.gov/library/manuals/e...spectors/8700/ General Aviation Operations Inspector's Handbook, Order 8700.1 http://www.faa.gov/about/office_org/...e/fsdo_pilots/ More FAA information |
FAR 91 under IFR requires reports on many things, unforecast
weather and equipment failure are two. ATC is part of the FAA and the FSDO is the investigator. -- James H. Macklin ATP,CFI,A&P "Larry Dighera" wrote in message ... | I've never heard of that policy either. | | I would have asked the FSDO inspector which section of the inspector's | handbook covers that policy. It would seem it should be covered by | FAR too. | | http://www.faa.gov/library/manuals/e...spectors/8300/ | Airworthiness Inspector's Handbook, Order 8300.10 | | http://www.faa.gov/library/manuals/e...spectors/8700/ | General Aviation Operations Inspector's Handbook, Order 8700.1 | | http://www.faa.gov/about/office_org/...e/fsdo_pilots/ | More FAA information |
Andrew Gideon wrote: Is anyone familiar with this policy? I'd love to see some of the gaps filled in. Back about '93 I had the oil pressure flucuate on my 182. I was pretty sure it wasn't a big deal but as I came into Merril Field (pretty much in the middle of Anchorage) I explained the problem to the tower and asked to stay high until I was over the field. He asked if I wanted to declare an emergency or if I wanted equipment standing by both of which I refused. Landed without incident. A week or so later a guy from FSDO called up and wanted to know about "my landing due to no oil pressure". I explained that my destination was MRI and that it had only flucuated. He requested that I stop by the FSDO with the aircraft logs and my logs. I called AOPA and was told that there was a "crack down" in Alaska at the time due to "unauthorized owner maintenance". I took my logs in and the only thing he looked for was my BFR and the a/c annual. The tower had obviously reported the incident to FSDO. Early in 2001 I cancelled an IFR flight and flightplan due to the attitude indicator failing just after takeoff. I was talking to approach at the time and told them the reason for the cancellation. I never heard anything further about it. |
ATC is required to call the regional office and log the event whenever a
for hire aircraft does something unusual, such as aborting a takeoff. Reporting that their DG is busted and then cancelling does not meet that requirement. At the facilities I've worked at we would never call FSDO or the regional office because of what you said. Andrew Gideon wrote: One of our club aircraft was recently on an IFR flight plan in VMC. The instrument student and his instructor noted that the DG was precessing excessively. They eventually canceled the flight plan and returned to their point of origin VFR. In canceling with ATC, they mentioned something about the DG having a problem. Later that day, the club received a call from the FSDO about the "vacuum failure" experienced by one of our aircraft. I've since chatted with the [nice] fellow from the FSDO myself (as one of the people involved in aircraft maintenance in the club). He explained that this was a part of a long-standing policy. Equipment failures that are reported to ATC are reported by ATC to the local FSDO. The FSDO checks into this, confirming that the problem was "resolved" by a mechanic before the aircraft flies again. The example he used was that of an RG with a flickering gear light. Assume the pilot reports the light to the tower. Further assume that the landing is uneventful (ie. the gear holds) and the flickering stops after landing. In this case, the FSDO is going to check that the aircraft received maintenance before it was flown again. I asked about the case where the above landing occurred at a field w/o services. He said that a mechanic should be brought in before the plane is flown to confirm that the gear is down and locked. There was a significant level of ambiguity in what I was told. He mentioned several times in the explanation that part of the trigger in the case of our aircraft was cancellation of the flight plan. I pointed out that I'd canceled IFR flight plans plenty of times. He then said that the difference was that my cancellations were typically when starting a visual approach to my intended airport, and the event under discussion involved an airplane not reaching its original destination. I pointed out that, once I was VFR, nobody knows where I land. He agreed with a little confusion. I know that the FAA has an interest in assuring that aircraft with problems are repaired. So do pilots. But I have never heard of this before. I wonder how well this long-standing policy handles subtleties like a VFR flight in an aircraft with a too-quickly precessing DG. And what are the possible sanctions? I was a little afraid to ask about that last point laugh. Is anyone familiar with this policy? I'd love to see some of the gaps filled in. Thanks... Andrew http://flyingclub.org/ |
On Wed, 26 Jul 2006 16:20:38 -0500, Jim Macklin wrote:
FAR 91 under IFR requires reports on many things, unforecast weather and equipment failure are two. ATC is part of the FAA and the FSDO is the investigator. Yes, we pilots are required to report. I'm not quite sure that one cannot cancel (assuming VMC) as an alternative to reporting an equipment failure, but that's not really my question. My question is more what occurs after we report. I've never heard of this process whereby the FSDO must confirm that maintenance has been done. - Andrew |
On Wed, 26 Jul 2006 15:37:51 -0600, Newps wrote:
for hire aircraft The situation that brought this to my attention involved a club aircraft, but there was an instructor on board instructing. I cannot imagine how TRACON would know about that, but - had they - would that cross the "for hire" threshold such that you'd have to report an equipment problem? Or do you mean something like a 135 or 121 flight? - Andrew |
On Wed, 26 Jul 2006 16:20:38 -0500, "Jim Macklin"
wrote in r2Rxg.84249$ZW3.23051@dukeread04:: FAR 91 under IFR requires reports on many things, unforecast weather and equipment failure are two. I found this: § 91.187 Operation under IFR in controlled airspace: Malfunction reports. (a) The pilot in command of each aircraft operated in controlled airspace under IFR shall report as soon as practical to ATC any malfunctions of navigational, approach, or communication equipment occurring in flight. I suppose an inoperative/malfunctioning directional gyro would qualify. However, I don't see any mention of having the FSDO inspector signoff before return to service. There is some mention of reporting inoperative equipment in this appendix: Appendix A to Part 91—Category II Operations: Manual, Instruments, Equipment, and Maintenance But I wouldn't think that applicable in this case. Perhaps you'd be good enough to locate the citation that mandates FSDO contacting the pilot when he mentions a DG malfunction: http://ecfr.gpoaccess.gov/cgi/t/text...1.3.10&idno=14 Thanks. |
It may just be a regional office and an inspector with an
itch he can't scratch in public. -- James H. Macklin ATP,CFI,A&P "Larry Dighera" wrote in message ... | On Wed, 26 Jul 2006 16:20:38 -0500, "Jim Macklin" | wrote in | r2Rxg.84249$ZW3.23051@dukeread04:: | | FAR 91 under IFR requires reports on many things, unforecast | weather and equipment failure are two. | | I found this: | | § 91.187 Operation under IFR in controlled airspace: Malfunction | reports. | (a) The pilot in command of each aircraft operated in controlled | airspace under IFR shall report as soon as practical to ATC any | malfunctions of navigational, approach, or communication equipment | occurring in flight. | | I suppose an inoperative/malfunctioning directional gyro would | qualify. | | However, I don't see any mention of having the FSDO inspector signoff | before return to service. | | There is some mention of reporting inoperative equipment in this | appendix: | | Appendix A to Part 91-Category II Operations: Manual, Instruments, | Equipment, and Maintenance | | But I wouldn't think that applicable in this case. | | Perhaps you'd be good enough to locate the citation that mandates FSDO | contacting the pilot when he mentions a DG malfunction: | http://ecfr.gpoaccess.gov/cgi/t/text...1.3.10&idno=14 | | Thanks. | |
![]() Andrew Gideon wrote: On Wed, 26 Jul 2006 15:37:51 -0600, Newps wrote: for hire aircraft The situation that brought this to my attention involved a club aircraft, but there was an instructor on board instructing. I cannot imagine how TRACON would know about that, but - had they - would that cross the "for hire" threshold such that you'd have to report an equipment problem? Or do you mean something like a 135 or 121 flight? Yes, part 121 or 135. |
IFR use of handheld GPS | [email protected] | Instrument Flight Rules | 251 | May 19th 06 02:04 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
