"Dan" wrote:
... or is it pretty much just look at the sectional and make a plan? That's a good summary of what I do. If I know my route and the terrain issues from daytime flight or examing the sectional, I can plan what altitude is required. e.g. "If I'm flying to Prescott, I know that if I'm at 8500, I won't hit anything." As others have said, if you don't know the area, you can always fly an instrument procedure. Another consideration is basic risk management. My instructor used to tell me, "Night, Terrain, or Weather - any one might be OK, but any two and you're getting risky, all three..." I don't usually venture too far north into the mountainous areas at night unless I know exactly where I'm going, and the weather is not a factor. Or plan the trip for twilight when there's still some ground visibility. Night flight around the valley is very nice - smooth air, good views of the city, and not too hard to be at an altitude where terrain just isn't a factor. Still it requires basic situational awareness - not only for terrain, but also for all the controlled airspace. Welcome to the valley! Mike |
Full moon helps. Don't do a long shallow let-down, stay at
cruise altitude and let-down over or very near the airport. If you have radar, tilt it up so the ground clutter is not displayed during a shallow descent. If you see the ground, it will be a ridge above your light path. Use the lights of the cities, as long as your view during let-down doesn't get "blacked out" by ridges and mountains, you should clear obstacles. Use oxygen above 5,000, it will improve your night vision, whether your IFR or VFR. -- James H. Macklin ATP,CFI,A&P "Dan" wrote in message ups.com... | My early years of flying were spent in the Midwest where as long as you | were over 2000 MSL, there were very few obstacles to hit and no | terrain. Now that I have moved out West (Phoenix) I am increasingly | paranoid about hitting terrain at night. | | Choosing a cruise altitude is easy (well above anything even close to | your route). However, what I worry about is my letdown to pattern | altitude at the destination airport as well as departure. Short of | filing IFR (which carries with it Oxygen requirements for some local | MEAs) what other strategies do you all use? Any "systems" or | tricks to share, or is it pretty much just look at the sectional and | make a plan? | | --Dan | |
Here's what I do
Go to Landings.com Enter your route and receive terrain avoidance altitudes Check it on your charts Plan route accordingly Fly route, double checking with your terrain avoidance GPS - highly recommend the Lowrance 2000 for $700.00 Tony C-GICE In article . com, "Dan" wrote: My early years of flying were spent in the Midwest where as long as you were over 2000 MSL, there were very few obstacles to hit and no terrain. Now that I have moved out West (Phoenix) I am increasingly paranoid about hitting terrain at night. Choosing a cruise altitude is easy (well above anything even close to your route). However, what I worry about is my letdown to pattern altitude at the destination airport as well as departure. Short of filing IFR (which carries with it Oxygen requirements for some local MEAs) what other strategies do you all use? Any "systems" or tricks to share, or is it pretty much just look at the sectional and make a plan? --Dan -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
know where you are
know where the ground is and if lights in the distance start blinking or disappearing there is either a cloud between you and the light or solid ground BT "Dan" wrote in message ups.com... My early years of flying were spent in the Midwest where as long as you were over 2000 MSL, there were very few obstacles to hit and no terrain. Now that I have moved out West (Phoenix) I am increasingly paranoid about hitting terrain at night. Choosing a cruise altitude is easy (well above anything even close to your route). However, what I worry about is my letdown to pattern altitude at the destination airport as well as departure. Short of filing IFR (which carries with it Oxygen requirements for some local MEAs) what other strategies do you all use? Any "systems" or tricks to share, or is it pretty much just look at the sectional and make a plan? --Dan |
![]() Dan wrote: My early years of flying were spent in the Midwest where as long as you were over 2000 MSL, there were very few obstacles to hit and no terrain. Now that I have moved out West (Phoenix) I am increasingly paranoid about hitting terrain at night. Choosing a cruise altitude is easy (well above anything even close to your route). However, what I worry about is my letdown to pattern altitude at the destination airport as well as departure. Short of filing IFR (which carries with it Oxygen requirements for some local MEAs) what other strategies do you all use? Any "systems" or tricks to share, or is it pretty much just look at the sectional and make a plan? --Dan Actually, it is pretty much look out the window and make a plan. I have flown in NM, AZ and CO quite a bit, and at first I used to worry about this too. Even in the most remote areas of the country, mountains stand out as dark areas. So don't fly towards a dark area unless you know what's in there. Sometimes it could be a lake or a low level cloud, but there are not too many of those in AZ. Don't descend to pattern altitude unless you have positively identified the runway. If there is an obstacle between you and the airport, it will stick out as a dark object. If the dark object is moving up your windsheld, then you better climb. If it is getting lower, then you are ok. Once in the traffic pattern, don't wander off too far. Very few airports have obstacles higher than the pattern altitude within a couple of miles of the runway, so if you keep a normal traffic pattern you should be ok. Check the sectional chart for any unusual obstacles. |
I live in California. All my night flights outside the Sacramento
valley are IFR and I carry O2. -Robert Dan wrote: My early years of flying were spent in the Midwest where as long as you were over 2000 MSL, there were very few obstacles to hit and no terrain. Now that I have moved out West (Phoenix) I am increasingly paranoid about hitting terrain at night. Choosing a cruise altitude is easy (well above anything even close to your route). However, what I worry about is my letdown to pattern altitude at the destination airport as well as departure. Short of filing IFR (which carries with it Oxygen requirements for some local MEAs) what other strategies do you all use? Any "systems" or tricks to share, or is it pretty much just look at the sectional and make a plan? --Dan |
![]() "Dan" wrote in message ups.com... My early years of flying were spent in the Midwest where as long as you were over 2000 MSL, there were very few obstacles to hit and no terrain. Now that I have moved out West (Phoenix) I am increasingly paranoid about hitting terrain at night. Choosing a cruise altitude is easy (well above anything even close to your route). However, what I worry about is my letdown to pattern altitude at the destination airport as well as departure. Short of filing IFR (which carries with it Oxygen requirements for some local MEAs) what other strategies do you all use? Any "systems" or tricks to share, or is it pretty much just look at the sectional and make a plan? It sounds like you could use one of the newer GPS's that have terrain awareness options. It would be pretty hard to hit something real hard, if your flight path was not all red! g -- Jim in NC |
"Mxsmanic" wrote in message
... In the area around Phoenix these days, anything that isn't covered with lights is likely to be a mountain, as I think that steep mountainsides are the only spots left that aren't covered with buildings and homes. The valley itself is quite flat, but it is filled with traffic around the 12th-busiest airport in the world, and the mountains rise rapidly around it. The terrain is flatter to the southeast (Mesa, et al.) and southwest (towards Gila Bend), but there are still mountains to contend with--flatter terrain is beyond. To the north, the mountains don't let up much after you leave Phoenix. South Mountain and its range to the south has large radio antennas that help to mark the highest elevations. KPHX is above 1135 feet, so 2000 MSL wouldn't give you much margin in the valley and it will place you within terrain in many of the surrounding mountains. I think 6000 MSL would clear most of the mountains surrounding the valley, but I won't swear to it. -- Transpose mxsmanic and gmail to reach me by e-mail. So now we're an expert in geography? Oh, and FWIW, Sky Harbor is 14th busiest worldwide and 8th busiest domestically. Ciao... (That's Italian for PLONK) |
![]() "Mike Adams" wrote in message news:caLNg.13772$c07.9506@fed1read04... "Dan" wrote: ... or is it pretty much just look at the sectional and make a plan? That's a good summary of what I do. If I know my route and the terrain issues from daytime flight or examing the sectional, I can plan what altitude is required. e.g. "If I'm flying to Prescott, I know that if I'm at 8500, I won't hit anything." As others have said, if you don't know the area, you can always fly an instrument procedure. Another consideration is basic risk management. My instructor used to tell me, "Night, Terrain, or Weather - any one might be OK, but any two and you're getting risky, all three..." Nice approach to RM. About a week after I'd flown my night dual XC to Prescott, I attended a safety seminar geared specifically toward flying in AZ. One particular presenter said he approached flying in AZ with these three mindsets: 1) In the daytime, some parts of Arizona can be enjoyed as true VFR 2) Even, in the daytime, a few parts of Arizona should be treated as MVFR or even IFR 3) At night, most of Arizona should be approached as HARD IFR (his emphasis...) Ok, so maybe Prescott wasn't such a good idea for a student cross country, at night, when the moon was in a late rising phase...Guess I was too ignorant to be scared. LOL!! Jay Beckman PP-ASEL Chandler, AZ |
tony roberts wrote:
Here's what I do Go to Landings.com Enter your route and receive terrain avoidance altitudes Check it on your charts Plan route accordingly Fly route, double checking with your terrain avoidance GPS - highly recommend the Lowrance 2000 for $700.00 Tony C-GICE In article . com, "Dan" wrote: My early years of flying were spent in the Midwest where as long as you were over 2000 MSL, there were very few obstacles to hit and no terrain. Now that I have moved out West (Phoenix) I am increasingly paranoid about hitting terrain at night. Choosing a cruise altitude is easy (well above anything even close to your route). However, what I worry about is my letdown to pattern altitude at the destination airport as well as departure. Short of filing IFR (which carries with it Oxygen requirements for some local MEAs) what other strategies do you all use? Any "systems" or tricks to share, or is it pretty much just look at the sectional and make a plan? --Dan Yes, as I was reading this thread I starting thinking how much I REALLY like my little box with the green triangles, the yellow triangles and the red triangles. Even flying VFR on the east coast (5 in haze is GOOD weather) the terrain avoidance as well as the traffic avoidance really helps. The XM weather will probably end up paying for itself with the savings in hotels and rental cars for those times you get up in the air and say, hmmmmm, if this gets any worse, it could be bad. I'll just go back and try again tomorrow. With the XM sometimes, if you are lucky, it comes up and shows you are in the worst of it and if you just alter your flight 20 miles east you will avoid everything. Margy Margy |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
FAA PPL night flight requirement - does it have to be DUAL? | Peter Clark | Piloting | 21 | January 6th 05 12:38 AM |
Garmin 430 Terrain Avoidance | endre | Instrument Flight Rules | 5 | July 22nd 04 03:41 AM |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
