Listening to http://audio.liveatc.net:8012/kjfk_app_final , I hear a
lot of instructions from the tower to follow other traffic, but the pilots don't always know what aircraft they're following. It sounds like the tower expects them to be able to recognize an airplane (type, airline, etc.) from two miles away. Is that possible? Marc |
"Marc Adler" wrote in message oups.com... Listening to http://audio.liveatc.net:8012/kjfk_app_final , I hear a lot of instructions from the tower to follow other traffic, but the pilots don't always know what aircraft they're following. It sounds like the tower expects them to be able to recognize an airplane (type, airline, etc.) from two miles away. Is that possible? Marc There usually isn't more that one aircraft at say your 11 o'clock two miles. |
Gig 601XL Builder wrote:
There usually isn't more that one aircraft at say your 11 o'clock two miles. The pilots say things like "See traffic at 12 o'clock, but can't tell if it's a regional carrier or not. Please advise." This sounds like the pilot is expecting to be able to recognize the plane. Marc |
"Gig 601XL Builder" wrDOTgiaconaATcox.net wrote in message
... There usually isn't more that one aircraft at say your 11 o'clock two miles. In a relatively busy airspace, there may well be more than one aircraft close enough to the 11 o'clock at two miles for there to be a question. Clock directions are very low precision, due to the facts that there's 30 degrees between each direction, ATC doesn't actually know your heading, and all of the traffic is constantly in motion. |
"Marc Adler" wrote in message oups.com... Gig 601XL Builder wrote: There usually isn't more that one aircraft at say your 11 o'clock two miles. The pilots say things like "See traffic at 12 o'clock, but can't tell if it's a regional carrier or not. Please advise." This sounds like the pilot is expecting to be able to recognize the plane. Marc He probably can't tell if it is a regional jet or a corporate jet. You'd be amazed what you can see from two miles in the air. |
oups.com... The pilots say things like "See traffic at 12 o'clock, but can't tell if it's a regional carrier or not. Please advise." This sounds like the pilot is expecting to be able to recognize the plane. At two miles, it's usually the case that one can recognize the general type of aircraft. Distinguishing a twin turboprop from a single-engined piston plane, for example. But it's dependent on a variety of things, including the pilot's own vision (only required to be corrected to 20/40) and ambient conditions (whether the called traffic is viewed against the sky or ground, current visibility, position of the sun, etc.). Two miles is certainly getting toward the edge of reliable identification. Generally speaking, a clarification request from ATC such as what you've heard resolves the question. A pilot can go ahead and proceed following the traffic they believe to be the correct traffic, and with the request for clarification ATC knows to keep an eye on things and make sure the pilot is following the traffic they expected them to (if ATC has a radar display, this can be done quite easily). Pete |
On 20 Sep 2006 12:53:20 -0700, "Marc Adler"
wrote: Listening to http://audio.liveatc.net:8012/kjfk_app_final , I hear a lot of instructions from the tower to follow other traffic, but the pilots don't always know what aircraft they're following. It sounds like the tower expects them to be able to recognize an airplane (type, airline, etc.) from two miles away. Is that possible? Marc On my first cross country heading into our 1st destination I was advised by the controller to watch for a Tomahawk crossing our path. The instructor asked me if I saw it & I pointed at a plane in the right spot with a T tail. He (rather dryly) remarked that what I was pointing was actually a DC9 .H. |
In article .com,
"Marc Adler" wrote: Listening to http://audio.liveatc.net:8012/kjfk_app_final , I hear a lot of instructions from the tower to follow other traffic, but the pilots don't always know what aircraft they're following. It sounds like the tower expects them to be able to recognize an airplane (type, airline, etc.) from two miles away. Is that possible? In most cases, there is usually a lag between when the radar illuminated by the radar and when the processed image is displayed on the radar screen. Hence, when the controller calls traffic, the traffic has actually moved to a different position when you look where you were told. Depending on the speed, altitude and distance, you may or may not find it in your field of view. |
Marc Adler wrote:
Gig 601XL Builder wrote: There usually isn't more that one aircraft at say your 11 o'clock two miles. The pilots say things like "See traffic at 12 o'clock, but can't tell if it's a regional carrier or not. Please advise." This sounds like the pilot is expecting to be able to recognize the plane. Marc I can say that I've never said or heard anything like that. Like Gig pointed out, there usually aren't multiple planes in the same coordinates in the air. If I see my traffic where ATC says it is, I don't really care what kind of plane it is. Obviously, if ATC says I'm following a 737 on final and all I see in front of my is a Citation, I'm going to question ATC (where IS that 737?), but it's generally not an issue. |
"Marc Adler" wrote in news:1158781999.937045.277410
@k70g2000cwa.googlegroups.com: Listening to http://audio.liveatc.net:8012/kjfk_app_final , I hear a lot of instructions from the tower to follow other traffic, but the pilots don't always know what aircraft they're following. It sounds like the tower expects them to be able to recognize an airplane (type, airline, etc.) from two miles away. Is that possible? Marc You're listening to what seems to be a frequency for ATC on JFK Airport's Final Approach. Typically, when the weather is clear, pilots are instructed to follow other traffic on a "visual approach", meaning (without getting into too much detail) that they can visually see the traffic they are instructed to follow, until they can see the runway they are landing on. On a clear day, with only a few planes in "line" this is not a difficult problem. If tower tells you you're #2 behind an RJ on a 3 mile final, and you're 5 miles out, it's pretty easy to know where to look for the RJ, and that you are looking for a jet, even if you don't know an RJ from a Hawker. Sometimes, though, when it is really clear, and traffic is being routed in from multiple directions, a plane coming in from an "angle" may be instructed to "cut in" between two other planes for their turn. So if you are "#3 behind a hawker" you may see only one plane in front of you when you expect to see 2, and you may see #4 coming in (sometimes it's hard to judge distance up there) and wonder if you're supposed to fit in behind him or in front of him... Did you miss a little plane on short final and you are supposed to cut in? Or do you need to slow down a bit or curve around a bit to make sure to space yourself behind that guy on the left? Better to ask than to wonder... |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 11:33 AM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Reading back altimeter settings? | Paul Tomblin | Piloting | 31 | April 12th 05 05:53 PM |
| Riddle me this, pilots | Chip Jones | Instrument Flight Rules | 137 | August 30th 03 05:02 AM |
