"ET" wrote in message
... wrote in ups.com: Actually, the CAFE numbers come out a little better than what Van states as the performance figures for the RV-6. And the stall speeds that Van posts are pretty much what J. Roncz predicts in his spreadsheets, even though Van's are a bit better. But then again Van's planes may be operating at a slightly higher CL than what Roncz uses. Which leads me to believe that the spreadsheets are quite accurate. This is why I'm having a hard time believing that the Sonex aircraft meet the LSA rules as written. Even at the lightest version of their aircraft ( Jabiru 2200 power and flown solo and no fuel ) the plane would have a hard time meeting the stall requirements of LSA which require max gross wt. figures with a 51 mph stall speed. And my intention is to fully understand the LSA rules, not "down" the Sonex aircraft or the people behind it. I believe the Sonex and its people to be top notch, as do many others, evidenced by how many are flying and continue to be built. They are reasonally priced, economical to operate and good "all around" performers for their power. And from what I have seen, several of the other "popular" LSA's would have a hard time meeting the LSA specs. as I see them written. Neal Which part of my post that indicated the fuselage of the Sonex is a lifting body confused you??? Steve Wittman is said to have won a bet or two with the same issue on the Tailwind. I have not done it, but plug the same numbers in for the Tailwind and see what pops out. -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams Quite true. Lifting bodies can generate a lot of lift, and airfoils vary wildly in their maximum coeficient. Also, there is nothing in the LSA rules, or any others that I can think of, to require that an aircraft be able to maintain level flight at stall speed--so drag coefficient is not a factor. Peter |
"Kyle Boatright" wrote in message
. .. "ET" wrote in message ... wrote in ups.com: snip Which part of my post that indicated the fuselage of the Sonex is a lifting body confused you??? Steve Wittman is said to have won a bet or two with the same issue on the Tailwind. I have not done it, but plug the same numbers in for the Tailwind and see what pops out. -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams Can you find a credible test of the Tailwind's stall speed on the web? I've looked for one, but without success. The CAFE report in the "members" section of the EAA site doesn't show the stall speed, although the text discusses stall speed testing. I seem to remember that Tailwinds with the stock pitot/static system have an inaccurate ASI at low speeds, showing much lower airspeed than actual. A buddy who owned a Tailwind described it as a fast airplane, but with "mean" low speed characteristics. I don't buy into the theory that Tailwinds or Soni (?) gain much lift from the fuselage. The aspect ratio of a fuselage is too small to generate a lot of lift. KB It is also possible that your friend's plane was poorly rigged. Some years ago, I saw a BD-4 that a guy had purchased and was trying to repair sufficiently to complete. The biggest problem was that the fusalage had a substantial twist. There can also be problems with a very heavy pilot in a very small airplane--Steve Wittman was only a little bigger than Ken Rand. Peter |
wrote in
oups.com: No part confused me. I just have a hard time believing that a fuselage can accomplish 50 percent of the lifting force of the total body. Yes I know that some lift comes off of the fuselage on planes, especially the tailwind as you suggest and the hyperbipe type of designs, but I didn't think the Sonex fuselage shape was that much different than most other 2 seat SBS types, including the RV-6. I'll take this into consideration, though I'm still not convinced that the fuselage lift is what puts the Sonex into the LSA category. Neal ET wrote: wrote in ups.com: Actually, the CAFE numbers come out a little better than what Van states as the performance figures for the RV-6. And the stall speeds that Van posts are pretty much what J. Roncz predicts in his spreadsheets, even though Van's are a bit better. But then again Van's planes may be operating at a slightly higher CL than what Roncz uses. Which leads me to believe that the spreadsheets are quite accurate. This is why I'm having a hard time believing that the Sonex aircraft meet the LSA rules as written. Even at the lightest version of their aircraft ( Jabiru 2200 power and flown solo and no fuel ) the plane would have a hard time meeting the stall requirements of LSA which require max gross wt. figures with a 51 mph stall speed. And my intention is to fully understand the LSA rules, not "down" the Sonex aircraft or the people behind it. I believe the Sonex and its people to be top notch, as do many others, evidenced by how many are flying and continue to be built. They are reasonally priced, economical to operate and good "all around" performers for their power. And from what I have seen, several of the other "popular" LSA's would have a hard time meeting the LSA specs. as I see them written. Neal Which part of my post that indicated the fuselage of the Sonex is a lifting body confused you??? Steve Wittman is said to have won a bet or two with the same issue on the Tailwind. I have not done it, but plug the same numbers in for the Tailwind and see what pops out. -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams Hrm, Well, where can I get a copy of this spreadsheet?... either you've got the wrong dimensions, or the spreadsheet is flawed. The Sonex stalls clean at 46mph, and those are real verified numbers (no I cant point you to a cafe study or anything but all builders on the list who have actually flown one have verified their numbers..) Is the airfoil type taken into account?? -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
"ET" wrote in message ... wrote in oups.com: snip Well, where can I get a copy of this spreadsheet?... either you've got the wrong dimensions, or the spreadsheet is flawed. The Sonex stalls clean at 46mph, and those are real verified numbers (no I cant point you to a cafe study or anything but all builders on the list who have actually flown one have verified their numbers..) Is the airfoil type taken into account?? -- -- ET :-) The Sonex numbers are believable, but absolutely DO NOT trust performance figures provided by builders. Pitot/Static systems are notoriously inaccurate at low airspeeds and owner/builders are notoriously optimistic in their performance reports. In addition, without very expensive and sensitive test equipment, you're not going to get accurate figures. There isn't a CAFE report on the Sonex, so unless Sonex Ltd. has invested the time and money to conduct private tests, my guess is that accurate testing simply hasn't been done. KB |
The Roncz spreadsheets were published in Sport Aviation from February
1990 thru January 1991 ( I believe ). The one I am referring to ran in the March 1990 issue. I'm not at the house at the moment but I'll check when I get home and verify. Neal ET wrote: wrote in oups.com: No part confused me. I just have a hard time believing that a fuselage can accomplish 50 percent of the lifting force of the total body. Yes I know that some lift comes off of the fuselage on planes, especially the tailwind as you suggest and the hyperbipe type of designs, but I didn't think the Sonex fuselage shape was that much different than most other 2 seat SBS types, including the RV-6. I'll take this into consideration, though I'm still not convinced that the fuselage lift is what puts the Sonex into the LSA category. Neal ET wrote: wrote in ups.com: Actually, the CAFE numbers come out a little better than what Van states as the performance figures for the RV-6. And the stall speeds that Van posts are pretty much what J. Roncz predicts in his spreadsheets, even though Van's are a bit better. But then again Van's planes may be operating at a slightly higher CL than what Roncz uses. Which leads me to believe that the spreadsheets are quite accurate. This is why I'm having a hard time believing that the Sonex aircraft meet the LSA rules as written. Even at the lightest version of their aircraft ( Jabiru 2200 power and flown solo and no fuel ) the plane would have a hard time meeting the stall requirements of LSA which require max gross wt. figures with a 51 mph stall speed. And my intention is to fully understand the LSA rules, not "down" the Sonex aircraft or the people behind it. I believe the Sonex and its people to be top notch, as do many others, evidenced by how many are flying and continue to be built. They are reasonally priced, economical to operate and good "all around" performers for their power. And from what I have seen, several of the other "popular" LSA's would have a hard time meeting the LSA specs. as I see them written. Neal Which part of my post that indicated the fuselage of the Sonex is a lifting body confused you??? Steve Wittman is said to have won a bet or two with the same issue on the Tailwind. I have not done it, but plug the same numbers in for the Tailwind and see what pops out. -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams Hrm, Well, where can I get a copy of this spreadsheet?... either you've got the wrong dimensions, or the spreadsheet is flawed. The Sonex stalls clean at 46mph, and those are real verified numbers (no I cant point you to a cafe study or anything but all builders on the list who have actually flown one have verified their numbers..) Is the airfoil type taken into account?? -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
Is it possible that maybe it all could be just an interpretation of the
LSA rule? I mean does the "aircraft" have to be LSA legal or does the "flight" have to be LSA legal? Say the Sonex could indeed stall at 51 mph ( flown solo in a lightweight condition ). Technically the "flight" would have a max gross takeoff wt.and stall conditions that would satisfy the LSA rule. But then if you loaded the aircraft to it's max. designed takeoff weight and then it couldn't meet the 51 mph stall speed, then it couldn't be flown under LSA rules. In other words, flown solo, yes you're LSA legal, but flown at max design, no, you're not legal. Could this be what the Sonex guys are doing? You know.......I could just call Jeremy and ask him. Neal Richard Riley wrote: On Sat, 23 Sep 2006 19:50:36 -0400, "J.Kahn" wrote: For when you don't have software available, just a calculator, memorize the simple formula in your head and apply it to any aircraft's specs you come across to assess their accuracy: Sea Level Stall in Kts = Sq root of: [(295 x Gr Wt) Divided by (Clmax x Wing Area)] Multiply by 1.15 for mph. Assume 1.6 for the Clmax. Almost all airfoils are between 1.5 and 1.7, which gives a 1 mph or so variation up or down relative to 1.6. That is not to say that the Sonex is not a very clever design. Yeah, I ran it the other way and got a CLmax of 1.623 at 1100 gross and 52 mph. That's ambitious for the 64-415 clean. Not flatly false, just at the top end of achievable in the real world. And it's got a flat bottomed fuselage, so that will fudge stall speed down a little. (Not like the DreamWings, a few years back, that was claiming speeds that meant a CLmax of 4). I wouldn't bet it's that good, but it's plausible. The key is that it's still just legal for LASt - the min stall speed is 45 knots, or 51.8 mph. It's entirely possible that the builders are reporting accurate speeds, but aren't getting those speeds at full gross weight. They claim an empty weight of 620 lbs, useful load 480, 16 gallons of fuel. So, 96 lbs of fuel and two 192 lb occupants. Let's assume our reporting pilot is flying alone and he has 3/4 full tanks. That puts him at a gross of 884. If the 1.6 (and change) CLmax is true, he'll stall at 46 (and change) mph. Throw in a little pitot error and it's very believable. |
John,
I hear what you're saying, but with all that's been said here, and investigated via spreadsheets, etc., I still don't think the Sonex can stall near the LSA requirement at max gross wt. and no flaps which means it is not LSA qualified. And just for grins, I looked up the figures for the CT Flight Design ( which is a popular seller ) and guess what. IT doesn't meet the LSA criteria. And I also looked up the new Vans RV-12 "LSA" and you guessed it....IT doesn't meet the stall speed criteria ( at least not on paper...I don't think it has flown yet.) So I'm convinced that something is amiss. I'll keep researching. Neal J.Kahn wrote: wrote: Is it possible that maybe it all could be just an interpretation of the LSA rule? I mean does the "aircraft" have to be LSA legal or does the "flight" have to be LSA legal? Say the Sonex could indeed stall at 51 mph ( flown solo in a lightweight condition ). Technically the "flight" would have a max gross takeoff wt.and stall conditions that would satisfy the LSA rule. But then if you loaded the aircraft to it's max. designed takeoff weight and then it couldn't meet the 51 mph stall speed, then it couldn't be flown under LSA rules. In other words, flown solo, yes you're LSA legal, but flown at max design, no, you're not legal. Could this be what the Sonex guys are doing? You know.......I could just call Jeremy and ask him. Neal Richard Riley wrote: On Sat, 23 Sep 2006 19:50:36 -0400, "J.Kahn" wrote: For when you don't have software available, just a calculator, memorize the simple formula in your head and apply it to any aircraft's specs you come across to assess their accuracy: Sea Level Stall in Kts = Sq root of: [(295 x Gr Wt) Divided by (Clmax x Wing Area)] Multiply by 1.15 for mph. Assume 1.6 for the Clmax. Almost all airfoils are between 1.5 and 1.7, which gives a 1 mph or so variation up or down relative to 1.6. That is not to say that the Sonex is not a very clever design. Yeah, I ran it the other way and got a CLmax of 1.623 at 1100 gross and 52 mph. That's ambitious for the 64-415 clean. Not flatly false, just at the top end of achievable in the real world. And it's got a flat bottomed fuselage, so that will fudge stall speed down a little. (Not like the DreamWings, a few years back, that was claiming speeds that meant a CLmax of 4). I wouldn't bet it's that good, but it's plausible. The key is that it's still just legal for LASt - the min stall speed is 45 knots, or 51.8 mph. It's entirely possible that the builders are reporting accurate speeds, but aren't getting those speeds at full gross weight. They claim an empty weight of 620 lbs, useful load 480, 16 gallons of fuel. So, 96 lbs of fuel and two 192 lb occupants. Let's assume our reporting pilot is flying alone and he has 3/4 full tanks. That puts him at a gross of 884. If the 1.6 (and change) CLmax is true, he'll stall at 46 (and change) mph. Throw in a little pitot error and it's very believable. Any numbers quoted for speeds are always based on the published max gross weight (maximum certified wing loading in other words) unless otherwise stated. That fact that the Sonex may stall at 46 mph solo is not relevant for the purposes of whether it meets LSA requirements. And the speeds that builders see are generally meaningless since ASIs are very inaccurate at these speeds and usually read 5-10 mph low. I find it puzzling that Monnet uses a viable stall speed claim for the Xenos but not for the Sonex. While the Sonex does meet LSA requirements (just), the claimed stall speed of 46, which is normally assumed to be for max gross, is simply mathematically impossible. I think you may be on to something though. If someone was to question his claimed stall of 46 he will probably state that it's for solo weight but that's not stated on his site and is misleading. Does the LSA rule have anything to say about advertised stall speeds? Can they be indicated or at less than gross without notation in ads? John |
| ICOM A23 Transformer Specs | [email protected] | General Aviation | 10 | April 17th 06 02:32 AM |
| ICOM A23 Transformer Specs | [email protected] | Piloting | 5 | April 16th 06 05:23 AM |
| A380 spec's | G. Sylvester | Piloting | 30 | January 21st 05 11:12 AM |
| A36 Bonanza Specs | Anthony Acri | Simulators | 1 | December 4th 04 01:55 PM |
| Specs for a B24D Liberator | John T. Slodyczka | Military Aviation | 0 | November 21st 03 03:18 AM |
