#21
Crash Lander writes:
Mxsmanic, ask these questions over there. I guarantee you'll get the answers you're looking for over there. I'm getting good answers here. -- Transpose mxsmanic and gmail to reach me by e-mail. |
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com writes:
Also, in real life there is a difference between having the CG too far forward and not using the trim properly. I had the weight far enough off that trimming didn't leave me much elevator travel for maneuvering. That's what made me realize that something was wrong. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote: If I'm alone in the aircraft, in the left seat at the front, can I put an counterbalancing weight in the rear seat on the right, or would putting weight in a diagonally opposed position make the aircraft unstable? Yes, it would be slightly better to do it that way, since it moves the CG to the center of the A/C. It would only cause instabilty at EXTREMELY high roll rates. I ran one of my tanks dry once, when I needed to change a leaky drain. The other tank was nearly full. It took a fair amount of aileron to overcome the weight difference, but not even close to the maximum. CG's off the centerline have only minimal effect on pitch, and should not have a noticable effect on elevator position. Bud |
#24
Trimming doesn't change the ability of the horizontal stabilizer to
correct for CG location, etc. It merely adds in an initial deflection of the elevator so as to make the effort needed by the pilot to move it is small. Imagine having to hold a constant twenty pounds of elevator on a cross country .Bud Mxsmanic wrote: "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com writes: Also, in real life there is a difference between having the CG too far forward and not using the trim properly. I had the weight far enough off that trimming didn't leave me much elevator travel for maneuvering. That's what made me realize that something was wrong. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#25
"Mxsmanic" wrote in message
... Steve Foley writes: If you mean do they always do this, I can only speak for myself. I have a pre-calculated one for myself with full fuel, myself with fuel to tabs (partial tanks) and myself and a 170lb person in the front right seat, both with full fuel and tabs. Anything else I need to recalculate. So if someone tosses a bag in the back, or if the person next to you weighs more or less than 170 lbs, you redo the calculations? Nobody 'tosses a bag in the back' of my plane. I take it, weight it, stow it, and re-do the weight and balance. |
#26
#27
Recently, Mxsmanic posted:
writes: Trimming doesn't change the ability of the horizontal stabilizer to correct for CG location, etc. It merely adds in an initial deflection of the elevator so as to make the effort needed by the pilot to move it is small. Imagine having to hold a constant twenty pounds of elevator on a cross country .But doesn't trim in most aircraft involve moving the elevator with a trim tab? On many aircraft, the trim tab moves independently of the elevator, and on others the elevator is adjusted. That is, if the elevator is moved up by the trim, then there's that much less travel remaining in the elevator in that direction. So if you have quite a bit of trim, your safety margin for additional elevator movement is reduced. Right? Trimming the elevator reduces the amount of effort required by the pilot to hold altitude. If one is carrying a lot of "up" trim, for example, then the aircraft is likely to be near critical AOA. The last thing you'd need is have a lot more "up" elevator movement available. In an aircraft in which the entire stabilizer moves for trim, I suppose you could set any amount of trim and still have full travel in both directions (doesn't the 737 work this way?). The overall range of a stabilizer's movement is usually the same regardelss of trim settings. IOW, you don't usually get more "up" than full "up". Neil |
#28
regardelss of trim settings. IOW, you don't usually get more "up" than full "up". Actually, in the case of an elevator with a conventional trim tab, trimming for "up" moves the trim tab =down=, which forces the back of the elevator up (a little), which pushes the tail down (a little) which pushes the nose up (a little), giving the aircraft a more nose-up "neutral yoke" attitude. You'll actually get a tad more up elevator authority (though at the expense of a lot more control =force= required) if the nose is trimmed down and you pull all the way on the yoke. That way the trim tab is positioned up, which helps push the tail down (if the control is held in position), rather than helping the pilot push the tail down. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
#29
Mxsmanic wrote: But doesn't trim in most aircraft involve moving the elevator with a trim tab? That is, if the elevator is moved up by the trim, then there's that much less travel remaining in the elevator in that direction. So if you have quite a bit of trim, your safety margin for additional elevator movement is reduced. Right? Yes, that's what I tried to say. In an aircraft in which the entire stabilizer moves for trim, I suppose you could set any amount of trim and still have full travel in both directions (doesn't the 737 work this way?). This contradicts what you said in the first paragraph. No, the 737 nor any other plane could possibly have this ability. This is like saying that the 737 can be loaded out of the allowable CG range, or the elevator (or stabilator) can be moved past the stall angle of attack (which is what limits it's travel in the first place). The elevator has only so many degrees it can rotate up and down before it stalls. Trim doesn't change this. Bud -- Transpose mxsmanic and gmail to reach me by e-mail. |
#30
Recently, Jose posted:
The overall range of a stabilizer's movement is usually the same regardelss of trim settings. IOW, you don't usually get more "up" than full "up". Actually, in the case of an elevator with a conventional trim tab, trimming for "up" moves the trim tab =down=, which forces the back of the elevator up (a little), which pushes the tail down (a little) which pushes the nose up (a little), giving the aircraft a more nose-up "neutral yoke" attitude. You'll actually get a tad more up elevator authority (though at the expense of a lot more control =force= required) if the nose is trimmed down and you pull all the way on the yoke. That way the trim tab is positioned up, which helps push the tail down (if the control is held in position), rather than helping the pilot push the tail down. Yes, however I think that relationship would only confuse Mxsmanic, who seems to be of the notion that somehow your control movement is limited or "safety margin" decreased (whatever that might be) by using trim tabs. The point I was making is that the range of elevator movement is largely unaffected by trim settings. Neil |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | December 1st 03 07:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 07:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 08:27 AM |
