On Mon, 9 Oct 2006 22:02:04 +0100, Paul J. Adam wrote:
If the brits really expected the EF to be a fighter/bomber I doubt they would have put the canards so far forward that they obscure the ground. They prolly would have been farther back, as they are in the rafale. Not that much of an issue for high-risk jobs, surely? (After all, what was the view like out of side-by-side strikers like the F-111 and A-6? Fine to one side, but to the right you're trying to see through the other crewman's helmet) It's been a long time since I read "Flight of the Intruder" but I seem to remember something about the BN's seat being lower and maybe further back than the pilots. Anyone know for sure? [cross-posted to RAMN added for an authoritative answer] -- -Jeff B. zoomie at fastmail fm |
On Tue, 10 Oct 2006 18:12:29 GMT, Yeff wrote:
On Mon, 9 Oct 2006 22:02:04 +0100, Paul J. Adam wrote: If the brits really expected the EF to be a fighter/bomber I doubt they would have put the canards so far forward that they obscure the ground. They prolly would have been farther back, as they are in the rafale. Not that much of an issue for high-risk jobs, surely? (After all, what was the view like out of side-by-side strikers like the F-111 and A-6? Fine to one side, but to the right you're trying to see through the other crewman's helmet) It's been a long time since I read "Flight of the Intruder" but I seem to remember something about the BN's seat being lower and maybe further back than the pilots. Anyone know for sure? [cross-posted to RAMN added for an authoritative answer] The EF is showing a bit of techno-regression if they let something as simple as canards or fuselage metalwork interfere with the view. They need to talk to the F-35 folks about those skin mounted vid-cams and integrated seamless helmet display to allow the intrepid aviator to simply look through the body apparently. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
![]() Yeff wrote: On Mon, 9 Oct 2006 22:02:04 +0100, Paul J. Adam wrote: If the brits really expected the EF to be a fighter/bomber I doubt they would have put the canards so far forward that they obscure the ground. They prolly would have been farther back, as they are in the rafale. Not that much of an issue for high-risk jobs, surely? (After all, what was the view like out of side-by-side strikers like the F-111 and A-6? Fine to one side, but to the right you're trying to see through the other crewman's helmet) It's been a long time since I read "Flight of the Intruder" but I seem to remember something about the BN's seat being lower and maybe further back than the pilots. Anyone know for sure? [cross-posted to RAMN added for an authoritative answer] -- Very true. On the A-6 the B/N sat lower and further back. The same arrangement was also carried over to the EA-6B. Cheers, Ralph -Jeff B. zoomie at fastmail fm |
Ever so slightly, though. One never really noticed it - or cared worth a fig. Owl sends -- Mike Kanze "You know how they say that after a while people start to look like their pets? Well, we're starting to look like Iraq - a bunch of warring political tribes incapable of acting in common for the greater good." - Thomas L. Friedman "Ralph_S" wrote in message ups.com... Yeff wrote: On Mon, 9 Oct 2006 22:02:04 +0100, Paul J. Adam wrote: If the brits really expected the EF to be a fighter/bomber I doubt they would have put the canards so far forward that they obscure the ground. They prolly would have been farther back, as they are in the rafale. Not that much of an issue for high-risk jobs, surely? (After all, what was the view like out of side-by-side strikers like the F-111 and A-6? Fine to one side, but to the right you're trying to see through the other crewman's helmet) It's been a long time since I read "Flight of the Intruder" but I seem to remember something about the BN's seat being lower and maybe further back than the pilots. Anyone know for sure? [cross-posted to RAMN added for an authoritative answer] -- Very true. On the A-6 the B/N sat lower and further back. The same arrangement was also carried over to the EA-6B. Cheers, Ralph -Jeff B. zoomie at fastmail fm |
![]() Mike Kanze wrote: On the A-6 the B/N sat lower and further back. Ever so slightly, though. One never really noticed it - or cared worth a fig. Owl sends -- Mike Kanze Indeed, only a few inches, in order to improve the pilot's field of view to his right. I can imagine the reason for not really noticing it being that you simply were used to it. It is quite noticible in practically all pictures of the A-6. Check out this one for instance. http://uscockpits.com/Later%20Attack...20Blk%201A.jpg Since the lateral spacing between both crewmembers was quite limited, having a different arrangement would have impaired the view quite a bit. Cheers, Ralph Very true. On the A-6 the B/N sat lower and further back. The same arrangement was also carried over to the EA-6B. Cheers, Ralph -Jeff B. |
And on the 'grandaddy' of them all, the A3D/A-3 Skywarrior of 1952, the
B/N also sat about 9" to the rear of the pilot, but on the same level in a larger, 'house' cockpit. Although there was 12" between the seats and a center console with throttles and many other switches in there (entry was from the center lower hatch,) the prime reason for the offset was the removeable and substantial size ASB-1A bombing computer which filled the space to the pressure bulkhead and was connected to an optical periscope through the bottom of the a/c. The B/N's left view was also obscured as the gunner/navigator sat behind the pilot, rear facing. His panel for the rear gun radar was replaced with ECM gear in 1962, the rear 20mm guns and radome were replaced with the "duck-tail" ECM antenna fairing. I'd say we all had good visibility, and we landed with the upper hatch open. Joel McEachen VAH-5 Ralph_S wrote: Mike Kanze wrote: On the A-6 the B/N sat lower and further back. Ever so slightly, though. One never really noticed it - or cared worth a fig. Owl sends -- Mike Kanze Indeed, only a few inches, in order to improve the pilot's field of view to his right. I can imagine the reason for not really noticing it being that you simply were used to it. It is quite noticible in practically all pictures of the A-6. Check out this one for instance. http://uscockpits.com/Later%20Attack...20Blk%201A.jpg Since the lateral spacing between both crewmembers was quite limited, having a different arrangement would have impaired the view quite a bit. Cheers, Ralph Very true. On the A-6 the B/N sat lower and further back. The same arrangement was also carried over to the EA-6B. Cheers, Ralph -Jeff B. |
![]() J.McEachen wrote: And on the 'grandaddy' of them all, the A3D/A-3 Skywarrior of 1952, the B/N also sat about 9" to the rear of the pilot, but on the same level in a larger, 'house' cockpit. Although there was 12" between the seats and a center console with throttles and many other switches in there (entry was from the center lower hatch,) the prime reason for the offset was the removeable and substantial size ASB-1A bombing computer which filled the space to the pressure bulkhead and was connected to an optical periscope through the bottom of the a/c. There was a similar issue with the A-6A. It had an avionics fit in which the radar and navigation equipment were coupled to a computer. The system was called DIANE, for Digital integrated Attack/Navigation Equipment. The computer used a rotating drum memory. This was a rather bulky affair, protruding into the cockpit. It basically sat between the B/N's legs. The B/N's left view was also obscured as the gunner/navigator sat behind the pilot, rear facing. His panel for the rear gun radar was replaced with ECM gear in 1962, the rear 20mm guns and radome were replaced with the "duck-tail" ECM antenna fairing. I'd say we all had good visibility, and we landed with the upper hatch open. I can imagine the fact that the crew didn't have ejection seats would help make the cockpit seem pretty roomy ;-) Joel McEachen VAH-5 Cheers, Ralph |
"Ralph_S" wrote...
There was a similar issue with the A-6A. It had an avionics fit in which the radar and navigation equipment were coupled to a computer. The system was called DIANE, for Digital integrated Attack/Navigation Equipment. The computer used a rotating drum memory. This was a rather bulky affair, protruding into the cockpit. It basically sat between the B/N's legs. Even in the A-6E TRAM the computer pedestal extended between the B/N's legs. The rotating drum may have gone away, but the space was filled with other electronics. |
![]() "Ralph_S" wrote in message ups.com... There was a similar issue with the A-6A. It had an avionics fit in which the radar and navigation equipment were coupled to a computer. The system was called DIANE, for Digital integrated Attack/Navigation Equipment. The computer used a rotating drum memory. This was a rather bulky affair, protruding into the cockpit. It basically sat between the B/N's legs. It wasn't a coincidence that the/an engineer at Litton that designed it had a daughter named Diane. I never heard anyone use that name. To us it was always just the Q-61. Actually, between the B/N's legs was the aft ped (aft pedestal unit) that had the joystick and keypad. In front of that was the center ped and in front of that was the forward ped or drum. It weighed 86 lbs and had just short of a gazillion stationary read/write heads that had a tendency to get knocked out of alignment on cat shots and arrested landings. Changing out drums was a lot of fun. Because integrated circuits didn't exist when it was designed, each flip-flop or bit was a circuit with physical transistors, resistors, diodes and capacitors. I think a flip-flop card had only two bits on it. There were a lot of them and other cards, like logic gates. Probably about half of them were contained in another bulky box, the Left Hand Unit. It was hidden behind the Left Hand Panel. I think most of the rest of the brains were in the Center Console Unit, another bulky box to the left of the B/N's left foot. Something usually broke on every flight. Stan, former AQ (domain slightly misspelled in email address) |
