Dual glide slope, $95...priceless!
Old October 20th 06, 06:12 AM posted to rec.aviation.owning
Jack Allison[_1_]
Default Dual glide slope, $95...priceless!
It's funny how anything less than $100 seems cheap when it comes to
fixing something on an airplane (especially when it's your own
airplane). Hmmm, must be because after the inevitable $1000+ repairs,
anything less than $100 seems like chump change. Go figure.
When we bought the Arrow, one thought I had when looking at pictures of
the panel was "Cool, dual glide slopes!"...only to later discover that
the glide slope in the #2 nav head didn't work. I don't recall if we
were told or if we surmised that we may not have a glide slope receiver
for the #2 nav. After just now poking around a bit on the web, I've
learned that our nav radios have built in glide slope receivers.
We had the plane at the avionics shop to get the VORs tuned since it's
never good when the #1 VOR indicates six degrees left of course when the
#2 VOR indicates (correctly) that you're on course. It turns out this
was an easy fix for the avionics guys. While doing the work, they
informed us that we do indeed have a glide slope receiver on the #2 nav
and that the problem can likely be fixed for an hour of labor ($95). We
authorize the hour for diagnosis and the problem turned out to be a few
recessed pins in a connector. The end result? We now have a functional
#2 glide slope and it only cost us $95...ah, life is good. Compared to a
rough estimate of $1700 to buy/install a second glide slope receiver,
the $95 option is...well...chump change.
Of course, now we *need* to go test fly the plane. Like I said, life is
good! :-)
Jack Allison
PP-ASEL-Instrument Airplane
"To become a Jedi knight, you must master a single force. To become
a private pilot you must strive to master four of them"
- Rod Machado
(Remove the obvious from address to reply via e-mail)
Old October 20th 06, 11:52 AM posted to rec.aviation.owning
NW_Pilot
"Jack Allison" wrote in message
It's funny how anything less than $100 seems cheap when it comes to fixing
something on an airplane (especially when it's your own airplane). Hmmm,
must be because after the inevitable $1000+ repairs, anything less than
the panel was "Cool, dual glide slopes!"...only to later discover that the
glide slope in the #2 nav head didn't work. I don't recall if we were told
or if we surmised that we may not have a glide slope receiver for the #2
nav. After just now poking around a bit on the web, I've learned that our
#2 VOR indicates (correctly) that you're on course. It turns out this was
an easy fix for the avionics guys. While doing the work, they informed us
that we do indeed have a glide slope receiver on the #2 nav and that the
problem can likely be fixed for an hour of labor ($95). We authorize the
hour for diagnosis and the problem turned out to be a few recessed pins in
a connector. The end result? We now have a functional #2 glide slope and
it only cost us $95...ah, life is good. Compared to a rough estimate of
$1700 to buy/install a second glide slope receiver, the $95 option
good! :-)
Jack Allison
- Rod Machado
I like then days!!!!
Old October 20th 06, 11:55 AM posted to rec.aviation.owning
Jon Kraus
and don't forget, that is $95 divided by three! Partnerships can be a
very good thing... We are looking for a # 3 as well.. We'll see...
good! :-)
Old October 20th 06, 03:00 PM posted to rec.aviation.owning
Jim Burns[_1_]
Jack,
I've got the same problem with our #1 glideslope. Do you know if they
pulled the recessed pins and replaced them? or did they simply push the pins
back in place?
Thanks,
Old October 20th 06, 03:35 PM posted to rec.aviation.owning
Mark Hansen
Jack,
Great to hear! Also glad to hear you got that VOR problem resolved ;-)
By the way, our club now owns a brand new 172SP with the G1000!
I don't think I'm going to be flying it thought, but it sure looks nice!
I think the hourly rate is going to be something like $115 wet.
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old October 20th 06, 03:39 PM posted to rec.aviation.owning
Robert M. Gary
The older VOR heads (the ones fed by the KX-170B style, not the KX-155
style) can be relied upon to be 6 degrees off every couple of months.
Although technically an avionics shop needs to do the adjustment most
owners puchase the spline screwdriver and do the adjustment themselves.
You simply remove the OBS knob (via set screw) and there adjustment
screw is behind it. Usually I do it as MHR or SAC where you have a VOT.
-Robert
good! :-)
Jack Allison
- Rod Machado
Robert M. Gary
Mark Hansen wrote:
Jack,
That's awesome! They're charging about that same price for old 172's at
Exec.
-Robert
Old October 20th 06, 03:47 PM posted to rec.aviation.owning
Mark Hansen
On 10/20/06 07:39, Robert M. Gary wrote:
Mark Hansen wrote:
Jack,
Exec.
That's right. I did most of my training at SkyWalk, which was charging over
$100 for a 70's-era 172 with a GNS 430. I"m sure the prices are much higher
now. I tried to look at their rates online, but the site is broken ;-(
I love the club - not just the wet rate, but the insurance that is included
as well.
-Robert
Sacramento, CA
Old October 20th 06, 08:45 PM posted to rec.aviation.owning
Ben Jackson
That's awesome! Now you can fly two ILSs at once!!
Ben Jackson AD7GD
http://www.ben.com/
Old October 20th 06, 09:08 PM posted to rec.aviation.owning
Robert M. Gary
Mark Hansen wrote:
Jack,
Exec.
as well.
Too bad I"m on the wrong side of town. Davis is a long drive from
Folsom ;(
-Robert
Can a failed Glide Slope also void the Localizer approach? Jim Carter Instrument Flight Rules 17 August 24th 06 09:01 PM
Glide Slope Antenna Ground Plane JKimmel Home Built 6 August 1st 06 01:28 AM
En route glide slope? Andrew Gideon Piloting 17 November 21st 04 05:49 PM
Effect of airbrake blade height on glide slope Mike Soaring 1 January 30th 04 08:24 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
