#31
I think the 'Verrizano Narrows Crew Saved a pilots life" bit was a bit
of 'dramatic license' added by the media- it appears (based on google earth, so I could be mistaken) that there are a number of fields in the area suitable to land a light plane. He just happen to choose one that was sitting on landfill from the bridge construction. He lost an engine within range of a suitable put-down spot, and successfully executed a power off, short field landing- textbook example of what pilot's are trained to do if we're not within gliding distance of an airport. Pilot's are trained to keep 'back doors' in case of an emergency situation- one of the first things you do during cross country training is learn to be aware of the terrain below you, and to make sure you always have a suitable landing field within gliding distance. (this is one of the things that makes mountain flying more treacherous, fwiw)... He had his back door, he needed it, he used it... Its not arrogance, its training. -Scott On Nov 16, 9:31 am, "Marc Adler" wrote: On Nov 15, 2:14 pm, "EridanMan" wrote: How is flawlessly performing the actions he's been trained to do verging on arrogance? If anything, I applaud the pilot for (correctly) playing down the situation. There is a general consensus among non-pilots that loosing an engine = airplane falling from the sky... its simply not true. We train for it... It happens, its a contingency that we're expected to deal with if the situation arises.I understand all that, and if he's secretly thanking his lucky stars but putting on a face of equanimity for the press, then I applaud him, too. But if I understand the situation correctly, if that park hadn't been there, he would've been in a lot more trouble, right? Somewhere else in the thread someone said the pilot has overdrawn his good luck account for a while. In the face of such luck, I'd expect people to be a bit humbler. Marc |
#32
#33
T o d d P a t t i s t wrote: Ron Natalie wrote: might get a 709 ride out of it Good point. If they thought it was mechanical, probably not, but if they thought it was fuel management, or pilot error contributed to it, they might well give him a ride. You don't get a 709 ride for running out of gas. What are they going to do, sit there and watch you pump gas into your plane? A 709 ride retests you on what you obviously failed to do properly that caused your wreck. |
#34
Newps wrote:
T o d d P a t t i s t wrote: Ron Natalie wrote: might get a 709 ride out of it Good point. If they thought it was mechanical, probably not, but if they thought it was fuel management, or pilot error contributed to it, they might well give him a ride. You don't get a 709 ride for running out of gas. What are they going to do, sit there and watch you pump gas into your plane? A 709 ride retests you on what you obviously failed to do properly that caused your wreck. Which would be flight planning in the case of a fuel issue. And yes you can get a 709. |
#35
Okay, I see. Thanks.
On Nov 16, 12:09 pm, "EridanMan" wrote: I think the 'Verrizano Narrows Crew Saved a pilots life" bit was a bit of 'dramatic license' added by the media- it appears (based on google earth, so I could be mistaken) that there are a number of fields in the area suitable to land a light plane. He just happen to choose one that was sitting on landfill from the bridge construction. He lost an engine within range of a suitable put-down spot, and successfully executed a power off, short field landing- textbook example of what pilot's are trained to do if we're not within gliding distance of an airport. Pilot's are trained to keep 'back doors' in case of an emergency situation- one of the first things you do during cross country training is learn to be aware of the terrain below you, and to make sure you always have a suitable landing field within gliding distance. (this is one of the things that makes mountain flying more treacherous, fwiw)... He had his back door, he needed it, he used it... Its not arrogance, its training. -Scott On Nov 16, 9:31 am, "Marc Adler" wrote: On Nov 15, 2:14 pm, "EridanMan" wrote: How is flawlessly performing the actions he's been trained to do verging on arrogance? If anything, I applaud the pilot for (correctly) playing down the situation. There is a general consensus among non-pilots that loosing an engine = airplane falling from the sky... its simply not true. We train for it... It happens, its a contingency that we're expected to deal with if the situation arises.I understand all that, and if he's secretly thanking his lucky stars but putting on a face of equanimity for the press, then I applaud him, too. But if I understand the situation correctly, if that park hadn't been there, he would've been in a lot more trouble, right? Somewhere else in the thread someone said the pilot has overdrawn his good luck account for a while. In the face of such luck, I'd expect people to be a bit humbler. Marc |
#36
Judah wrote:
Ron Natalie wrote in news:455b8968$0$26912 : 1 - Will the pilot get fined (FAA, NTSB, NYPD, parks authority, anyone)? FAA - not likely, might get a 709 ride out of it. You think the FAA would want to checkride him after he glided the plane to safety with no damage? I can't image that. What will they test him on, his emergency landing skills? He already proved that he can do it safely... You betcha. They 709 ride people who gear up planes due to mechanical failure who do perfect landings as well. |
#37
Newps wrote:
There won't be a 709 ride. Either the engine really did puke and there would never be a ride for that, or he ran out of gas. If that happened there's still no ride, just a suspension. There's a member of this group (he can speak up if he wishes) that ran out of fuel (undetermined reason) who got a 709 ride but no other action...so your observation is not universally true. |
#38
Fuel is a red herring here... Assuming the report of 8 gallons is semi
correct, it is likely the fire/rescue looked at the gauges not realizing that a Skyhawk is a double fuel system... Either way, he had an hour and possibly two hours of fuel on board... SInce the report indicates he commutes by air for some 20 years over this route and he was mere minutes away from the destination airport we need to find something else to beat to death on here... denny |
#39
Gary Drescher wrote:
"Ron Natalie" wrote in message m... Gary Drescher wrote: I think the default emergency landing site when flying low near NYC is the Hudson River. If there happens to be a clear area on the ground, as there was in this case, then that's even better (especially for the airplane). But at worst, you just having to make a water landing (with a high likelihood of prompt rescue). Only if you were over Manhattan (or perhaps parts of the Bronx). There's a lot of real estate in the other boros that would require you climbing over 1500 feet to get to the Hudson. True. Most of my flying in that vicinity has been over the water to begin with. I don't think I'd venture beyond gliding distance of the river unless I'd determined in advance that I'd be within range of a suitable landing spot at all times. --Gary His water alternative would have been the Atlantic Ocean at that location. |
#40
Marc Adler wrote:
On Nov 15, 2:14 pm, "EridanMan" wrote: How is flawlessly performing the actions he's been trained to do verging on arrogance? If anything, I applaud the pilot for (correctly) playing down the situation. There is a general consensus among non-pilots that loosing an engine = airplane falling from the sky... its simply not true. We train for it... It happens, its a contingency that we're expected to deal with if the situation arises. I understand all that, and if he's secretly thanking his lucky stars but putting on a face of equanimity for the press, then I applaud him, too. But if I understand the situation correctly, if that park hadn't been there, he would've been in a lot more trouble, right? Somewhere else in the thread someone said the pilot has overdrawn his good luck account for a while. In the face of such luck, I'd expect people to be a bit humbler. Marc How much humbler could he have been? He said he did what he was trained to do - explicitly dispelling the notion that he had accomplished anything special. His alternative was to ditch in the ocean or lower bay. Yeah - he had some luck, but where is the arrogance? I don't see it. |
| N1 lands in BED: | Bush | Piloting | 50 | February 17th 06 09:16 AM |
| C172 charter in LA | Timo | Piloting | 15 | January 30th 06 08:20 PM |
| C172 fuel cap | [email protected] | Owning | 13 | September 25th 04 06:25 AM |
| wanted C172 | Hankal | Owning | 0 | September 23rd 03 02:23 AM |
| C172 / 5th Passenger | stan | Owning | 1 | August 3rd 03 11:46 PM |
