Do sim pilots log their time?
Old November 23rd 06, 05:28 PM posted to rec.aviation.piloting
Jay Honeck
Default Do sim pilots log their time?
I suspect success or failure says something about you, as a pilot, land
a real plane, rather than anything about the sim.
Obviously my sentence should read:
"I suspect success or failure says something about HOW you, as a pilot,
land
a real plane, rather than anything about the sim."
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 23rd 06, 05:37 PM posted to rec.aviation.piloting
Gene Seibel
a real plane, rather than anything about the sim. In other words, if
you land a real plane more by sight-picture and numbers, you'll
probably have no trouble landing the Kiwi -- but if you land a plane
more by "feel", you'll likely not have good luck in the sim.
I honestly don't know, though.
Jay Honeck
Only tried a sim a couple times. Did not land well. I guess I land by
feel. Once on short final, I don't look at the guages any more.
Gene Seibel
Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html
Because we fly, we envy no one.
Old November 23rd 06, 05:51 PM posted to rec.aviation.piloting
On 23 Nov 2006 09:11:10 -0800, "Jay Honeck" wrote:
Interestingly, even though I personally find the sim experience to be
quite realistic, some of the best sticks I know have great difficulty
landing. One fellow in particular is inexplicably having no luck
landing the sim, despite thousands of hours of flight experience.
He might be more dependent upon peripheral vision when landing, which the sim
won't provide. On many taildraggers, the nose comes up and blots out the view
forward in the flare. I (probably like most pilots) don't like turning my head
during the flare, so I'm left with the "feel" of where I'm at based on my
peripheral vision.
From your description, the Good Stick probably has lots of time in
"barnstormer-like" airplanes where he can't see forward during the last phases
of landing. He might be more used to using peripheral vision.
Strangely enough, though, I can land the MSFS Fly Baby (you DO have it installed
on the Kiwi, right, Jay? :-) without any problems. I might have the "damage
threshold" values set too high. But I did design the panel to arc and provide
just a little view forward on either side during the flare.
http://www.bowersflybaby.com/MSFS/index.html
Old November 23rd 06, 06:05 PM posted to rec.aviation.piloting
Jim Logajan
What specifically is he having problems with? Is it difficulty in
controlling speed, approach angle, direction, or what? Are the problems
encountered within ground effect distance or higher? In a real plane, is he
more likely than most to judge altitude and attitude by glancing out the
side windows?
Okay - that's a lot of questions I'm pretty sure you don't have answers to,
but I suspect answering them would help isolate where the simulator is
weakest in replicating reality.
Old November 23rd 06, 06:24 PM posted to rec.aviation.piloting
birdog
"Jay Honeck" wrote in message
Sims do a decent job simulating instrument conditions and maybe some
other things, but they don't simulate landings realistically at all.
Even the most sophisticated sims dont simulate landings well. So it's
really irrelevant. I suspect the pilots who can land your sim well can
do so because they practiced with a sim, not a real airplane.
Just to add to the conversation ---- I wish I'd had access to a MS simulator
when I started on my instrument rating. Whatever else, it would have helped
in instrument scanning and intuitional control reaction. Would have saved me
agonizing cockpit time.
Old November 23rd 06, 06:50 PM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
"Gene Seibel" wrote in message
ps.com...
Jay Honeck
Gene Seibel
How can you tell? I mean, if you end up on the simulated runway and you
don't get the simulated cracks in the simulated windshield acompanied by the
simulated crashing sound, you know you didn't simulate wrecking a simulated
airplane, but beyond that???
Geoff
Old November 23rd 06, 09:51 PM posted to rec.aviation.piloting
Mxsmanic
Steve Foley writes:
I believe Microsoft logs the flights for you, so you can lose all your
flight time when you need to re-install.
It's an option in the sim. Some add-ons also provide some degree of
logging. The Hobbs meter in the Dreamflight aircraft accurately
measures time, and the only way to reset it is to reinstall or modify
some configuration files. Likewise, some of the instruments have
total use timers; I don't know how to reset some of them, short of
reinstalling.
Old November 23rd 06, 09:54 PM posted to rec.aviation.piloting
Mxsmanic
Jay Honeck writes:
Yet, even when I downloaded his current aircraft, and set him up at his
home airport, he was not able to land on the runway. The only thing I
can think of is that he apparently flies his real aircraft "by feel"
more than most of us do, and the simulator obviously is lacking in
"feel", since it is not a full-motion sim.
Yup. Put him in a full-motion sim, and I'm sure he'll be able to land
effortlessly. Turn off the motion in the full-motion sim, and you'll
probably see the same problems you're seeing in your sim.
Does this pilot ever fly IFR?
It will be interesting to see if the new computer system I've ordered
-- which will help to make the sim experience as realistic as possible
-- helps the situation, or if it's strictly a motion-related problem
that can't be resolved.
Instrument-rated pilots apparently resolve it.
Mxsmanic
Doug writes:
In what ways are they deficient?
Old November 23rd 06, 10:07 PM posted to rec.aviation.piloting
karl gruber wrote:
My old instrument instructor, who flew water bombers for fun, liked to
say.................Yes you can log sim time. You SUBTRACT it from your
logbook.
The worse the weather the better to him. No day flights and we never needed
a hood. God bless his soul, he used to say, "God hates cowards," and then
we'd launch.
*** My old CFII Bob was pretty brave, too. We'd be bouncing along in
the clouds
and I'd say
"Get a load of this turbulence!"
"What turbulence?"
or
"Yeee - HAH"
or
"Rock-n-roll!"
I really miss him - would like to show him how good I'm getting at
"turbulence tolerance" - but he flew a Baron into a mountaintop a year
and a half ago.
Maybe it's true what they say about old pilots and bold pilots?
- Jerry "Chicken pilot" Kaidor
About Good Pilots and Bad Pilots Dudley Henriques Piloting 96 February 23rd 06 01:19 AM
Dover short pilots since vaccine order Roman Bystrianyk Naval Aviation 0 December 29th 04 12:47 AM
