I suspect success or failure says something about you, as a pilot, land
a real plane, rather than anything about the sim. Obviously my sentence should read: "I suspect success or failure says something about HOW you, as a pilot, land a real plane, rather than anything about the sim." -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
I suspect success or failure says something about you, as a pilot, land a real plane, rather than anything about the sim. In other words, if you land a real plane more by sight-picture and numbers, you'll probably have no trouble landing the Kiwi -- but if you land a plane more by "feel", you'll likely not have good luck in the sim. I honestly don't know, though. -- Jay Honeck Only tried a sim a couple times. Did not land well. I guess I land by feel. Once on short final, I don't look at the guages any more. -- Gene Seibel Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html Because we fly, we envy no one. |
On 23 Nov 2006 09:11:10 -0800, "Jay Honeck" wrote:
Interestingly, even though I personally find the sim experience to be quite realistic, some of the best sticks I know have great difficulty landing. One fellow in particular is inexplicably having no luck landing the sim, despite thousands of hours of flight experience. He might be more dependent upon peripheral vision when landing, which the sim won't provide. On many taildraggers, the nose comes up and blots out the view forward in the flare. I (probably like most pilots) don't like turning my head during the flare, so I'm left with the "feel" of where I'm at based on my peripheral vision. From your description, the Good Stick probably has lots of time in "barnstormer-like" airplanes where he can't see forward during the last phases of landing. He might be more used to using peripheral vision. Strangely enough, though, I can land the MSFS Fly Baby (you DO have it installed on the Kiwi, right, Jay? :-) without any problems. I might have the "damage threshold" values set too high. But I did design the panel to arc and provide just a little view forward on either side during the flare. http://www.bowersflybaby.com/MSFS/index.html Ron Wanttaja |
"Jay Honeck" wrote:
Interestingly, even though I personally find the sim experience to be quite realistic, some of the best sticks I know have great difficulty landing. One fellow in particular is inexplicably having no luck landing the sim, despite thousands of hours of flight experience. What specifically is he having problems with? Is it difficulty in controlling speed, approach angle, direction, or what? Are the problems encountered within ground effect distance or higher? In a real plane, is he more likely than most to judge altitude and attitude by glancing out the side windows? Okay - that's a lot of questions I'm pretty sure you don't have answers to, but I suspect answering them would help isolate where the simulator is weakest in replicating reality. |
![]() "Jay Honeck" wrote in message ups.com... Sims do a decent job simulating instrument conditions and maybe some other things, but they don't simulate landings realistically at all. Even the most sophisticated sims dont simulate landings well. So it's really irrelevant. I suspect the pilots who can land your sim well can do so because they practiced with a sim, not a real airplane. Just to add to the conversation ---- I wish I'd had access to a MS simulator when I started on my instrument rating. Whatever else, it would have helped in instrument scanning and intuitional control reaction. Would have saved me agonizing cockpit time. |
"Gene Seibel" wrote in message
ps.com... Jay Honeck wrote: I suspect success or failure says something about you, as a pilot, land a real plane, rather than anything about the sim. In other words, if you land a real plane more by sight-picture and numbers, you'll probably have no trouble landing the Kiwi -- but if you land a plane more by "feel", you'll likely not have good luck in the sim. I honestly don't know, though. -- Jay Honeck Only tried a sim a couple times. Did not land well. I guess I land by feel. Once on short final, I don't look at the guages any more. -- Gene Seibel Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html Because we fly, we envy no one. How can you tell? I mean, if you end up on the simulated runway and you don't get the simulated cracks in the simulated windshield acompanied by the simulated crashing sound, you know you didn't simulate wrecking a simulated airplane, but beyond that??? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Steve Foley writes:
I believe Microsoft logs the flights for you, so you can lose all your flight time when you need to re-install. It's an option in the sim. Some add-ons also provide some degree of logging. The Hobbs meter in the Dreamflight aircraft accurately measures time, and the only way to reset it is to reinstall or modify some configuration files. Likewise, some of the instruments have total use timers; I don't know how to reset some of them, short of reinstalling. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Jay Honeck writes:
Yet, even when I downloaded his current aircraft, and set him up at his home airport, he was not able to land on the runway. The only thing I can think of is that he apparently flies his real aircraft "by feel" more than most of us do, and the simulator obviously is lacking in "feel", since it is not a full-motion sim. Yup. Put him in a full-motion sim, and I'm sure he'll be able to land effortlessly. Turn off the motion in the full-motion sim, and you'll probably see the same problems you're seeing in your sim. Does this pilot ever fly IFR? It will be interesting to see if the new computer system I've ordered -- which will help to make the sim experience as realistic as possible -- helps the situation, or if it's strictly a motion-related problem that can't be resolved. Instrument-rated pilots apparently resolve it. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Doug writes:
Sims do a decent job simulating instrument conditions and maybe some other things, but they don't simulate landings realistically at all. Even the most sophisticated sims dont simulate landings well. In what ways are they deficient? -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() karl gruber wrote: My old instrument instructor, who flew water bombers for fun, liked to say.................Yes you can log sim time. You SUBTRACT it from your logbook. The worse the weather the better to him. No day flights and we never needed a hood. God bless his soul, he used to say, "God hates cowards," and then we'd launch. *** My old CFII Bob was pretty brave, too. We'd be bouncing along in the clouds and I'd say "Get a load of this turbulence!" "What turbulence?" or "Yeee - HAH" or "Rock-n-roll!" I really miss him - would like to show him how good I'm getting at "turbulence tolerance" - but he flew a Baron into a mountaintop a year and a half ago. Maybe it's true what they say about old pilots and bold pilots? - Jerry "Chicken pilot" Kaidor |
About Good Pilots and Bad Pilots | Dudley Henriques | Piloting | 96 | February 23rd 06 01:19 AM |
Dover short pilots since vaccine order | Roman Bystrianyk | Naval Aviation | 0 | December 29th 04 12:47 AM |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
