![]() Jay Honeck wrote: Most important control Radio transmit Hey, I'm a "Use the radio, dammit!" guy from way back -- but even I wouldn't rate the transmit button as my "most important control"... Maybe number three or so... I was not thinking of the yoke or pedals as controls. I was thinking more buttons and knobs. If they count ... then it's the elevator. -The original poster |
On 27 Nov 2006 23:22:45 -0800, "Charles Talleyrand"
wrote: Jay Honeck wrote: Most important control Radio transmit Hey, I'm a "Use the radio, dammit!" guy from way back -- but even I wouldn't rate the transmit button as my "most important control"... Maybe number three or so... I was not thinking of the yoke or pedals as controls. I was thinking more buttons and knobs. If they count ... then it's the elevator. The little knob on the altimeter gets my vote. Don |
Start switch Jerry "Charles Talleyrand" wrote in message oups.com... Type of plane I have a VFR Cessna 150. Most important control Radio transmit .................................................. ........................................ |
![]() Robert M. Gary wrote: Charles Talleyrand wrote: Type of plane I have a VFR Cessna 150. M20 Most important control Radio transmit Yoke Least important control Pitot heat (if you need it, you shouldn't be flying) Why shouldn't you be flying if you need pitot heat? Because I fly a VFR Cessna 150. When would I need pitot heat assuming the weather was good enough to fly in the first place. In other words, if I need pitot heat, what I really needed was better decision making before takeoff. |
![]() -----Original Message----- From: Charles Talleyrand ] Posted At: Tuesday, November 28, 2006 6:45 PM Posted To: rec.aviation.owning Conversation: Most Important Control On My Plane Subject: Most Important Control On My Plane .... Why shouldn't you be flying if you need pitot heat? Because I fly a VFR Cessna 150. When would I need pitot heat assuming the weather was good enough to fly in the first place. In other words, if I need pitot heat, what I really needed was better decision making before takeoff. To each, his or her own limits. However, pitot heat isn't only useful in below freezing conditions. It used to be a practice to have the pitot heat on before flight into visible moisture. I realize you mentioned VFR only Charles, but it seems to me that this thread was tending to suggest that pitot heat was for use during below freezing conditions, and that's just not always the case. |
wrote: Jay Honeck wrote: Most important control Radio transmit Hey, I'm a "Use the radio, dammit!" guy from way back -- but even I wouldn't rate the transmit button as my "most important control"... Maybe number three or so... I was not thinking of the yoke or pedals as controls. I was thinking more buttons and knobs. If they count ... then it's the elevator. Nah. You should be able to fly using ailerons and trim without the elevator. I had one instructor have me land doing just that. The AOPA even put out a video on doing it. I believe certification requires that the elevator not be a single failure point. Home builts OTOH may not necessarily have that advantage. -The original poster Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() Jerry wrote: Most important control Start switch Or stop switch. When I had the Chief I once had a bad mag ground that prevented the mags from shutting off. Since the Chief has no idle cut off mixture all I could do was to shut the fuel valve off and sit and wait, and wait, and wait. -Robert |
![]() I was not thinking of the yoke or pedals as controls. I was thinking more buttons and knobs. If they count ... then it's the elevator. Nah. You should be able to fly using ailerons and trim without the elevator. I had one instructor have me land doing just that. The AOPA even put out a video on doing it. When I was getting my float rating the instructor had me take off using just trim and rudder |
Gas Cap
"Jerry" wrote in message m... Most important control Start switch Jerry "Charles Talleyrand" wrote in message oups.com... Type of plane I have a VFR Cessna 150. Most important control Radio transmit .................................................. ....................................... |
![]() Relief tube! -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO (MTJ) |
Best place for CG along roll axis | Mxsmanic | Piloting | 42 | September 28th 06 04:40 AM |
VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 6th 06 11:13 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
My first aerobatic lesson | Marco Rispoli | Piloting | 6 | April 13th 05 02:21 PM |
