Is it true or just an "old wives tale " ?
For several years now I've removed all the instruments with liquid crystal displays ( LCD's) from my sailplane on the advice I got from an "expert " some years ago . I was told that if you store the glider with instruments in an outside hangar where the temperature drops to below -20F at times , then that is very hard on the LCD's . I did in fact have an old Garmin start up in the Spring one year after winter storage, the screen turned brown then expired . Thanks , Ron Clarke. |
In our business, we use a wide variety of scientific and engineering
instruments and sometimes end up in extremes of temperature. We have had equipment fail to operate at temperatures below freezing, but recover when warmed up. LCDs seem to survive in all conditions we have experienced (-20 to +140 F), although they may not all be readable. It's common for consumer-grade LCDs (such as you might have on a PDA) to suffer from black screens on hot days here in Arizona. I also found an expensive oscilloscope with color LCD screen unreadable below freezing, while an older ( and cheaper) greyscale LCD was fine. Some solders also may have problems at very low temperatures - if my memory serves me right, lead has a phase change that can exacerbate dry joints in sub-zero temperatures. Connectors are also a possible source of problems, especially if exposed to vibration and temperature extremes. Mike On Nov 28, 5:18 pm, Marc Ramsey wrote: wrote: Is it true or just an "old wives tale " ? For several years now I've removed all the instruments with liquid crystal displays ( LCD's) from my sailplane on the advice I got from an "expert " some years ago . I was told that if you store the glider with instruments in an outside hangar where the temperature drops to below -20F at times , then that is very hard on the LCD's . I did in fact have an old Garmin start up in the Spring one year after winter storage, the screen turned brown then expired .The specifications on modern LCDs vary, but typically the low end of the storage temperature range is usually somewhere in the range -40C (-40F) to -20C (-4F). High end is generally 80C (176F). Marc |
It occurs to me that the individual manufacturers might
have the best comment about this. If there is nothing in the manual, asking a dealer might be the next best inquiry. At 15:54 29 November 2006, Mike The Strike wrote: In our business, we use a wide variety of scientific and engineering instruments and sometimes end up in extremes of temperature. We have had equipment fail to operate at temperatures below freezing, but recover when warmed up. LCDs seem to survive in all conditions we have experienced (-20 to +140 F), although they may not all be readable. It's common for consumer-grade LCDs (such as you might have on a PDA) to suffer from black screens on hot days here in Arizona. I also found an expensive oscilloscope with color LCD screen unreadable below freezing, while an older ( and cheaper) greyscale LCD was fine. Some solders also may have problems at very low temperatures - if my memory serves me right, lead has a phase change that can exacerbate dry joints in sub-zero temperatures. Connectors are also a possible source of problems, especially if exposed to vibration and temperature extremes. Mike On Nov 28, 5:18 pm, Marc Ramsey wrote: wrote: Is it true or just an 'old wives tale ' ? For several years now I've removed all the instruments with liquid crystal displays ( LCD's) from my sailplane on the advice I got from an 'expert ' some years ago . I was told that if you store the glider with instruments in an outside hangar where the temperature drops to below -20F at times , then that is very hard on the LCD's . I did in fact have an old Garmin start up in the Spring one year after winter storage, the screen turned brown then expired .The specifications on modern LCDs vary, but typically the low end of the storage temperature range is usually somewhere in the range -40C (-40F) to -20C (-4F). High end is generally 80C (176F). Marc |
I wondered about this, researched it to a limited extent and then
thought - why take a chance? Not only is the cold a potential problem but moisture etc. has a potential for causing problems as well. I bought a quick-connect for all the pitot/static tubes on the panel and installed a quick-connect for all the electrical wires leading to the panel. When the glider comes home for the season, the panel comes out of the glider and goes in the house. Takes about 5 minutes and the cold and moisture hasn't caused a problem yet! wrote: Is it true or just an "old wives tale " ? For several years now I've removed all the instruments with liquid crystal displays ( LCD's) from my sailplane on the advice I got from an "expert " some years ago . I was told that if you store the glider with instruments in an outside hangar where the temperature drops to below -20F at times , then that is very hard on the LCD's . I did in fact have an old Garmin start up in the Spring one year after winter storage, the screen turned brown then expired . Thanks , Ron Clarke. |
Jay wrote:
I wondered about this, researched it to a limited extent and then thought - why take a chance? Not only is the cold a potential problem but moisture etc. has a potential for causing problems as well. I bought a quick-connect for all the pitot/static tubes on the panel and installed a quick-connect for all the electrical wires leading to the panel. When the glider comes home for the season, the panel comes out of the glider and goes in the house. Takes about 5 minutes and the cold and moisture hasn't caused a problem yet! The cold and moisture may no longer cause a problem, but from my experience, the quick connect eventually will. The last time I tried one, it lasted a couple of seasons, then started to leak. These days, I put an inline connector at the end all of the tubes, then use short pieces of tubing to connect to the instruments, which get thrown away every time I disconnect them... Marc |
Marc,
Good point - I do a static drawdown each year when I do the annual (I have the equipment so what the heck). When it starts to leak I'll probably change over to your method. Marc Ramsey wrote: The cold and moisture may no longer cause a problem, but from my experience, the quick connect eventually will. The last time I tried one, it lasted a couple of seasons, then started to leak. These days, I put an inline connector at the end all of the tubes, then use short pieces of tubing to connect to the instruments, which get thrown away every time I disconnect them... Marc |
Quick connects are practical devices, who may also save a few embarrassing
(potential dangerous?) faulty connections. -But they require maintenance: Silicone for the rubber parts, and careful cleaning of the threading at every assembly will keep them going for years. I found that the ones with plastic/metal threading will accumulate dust/debris from the plastic part, eventually preventing an airtight fit. Happy soaring, Lars Peder DG-600 EE, Denmark "Jay" wrote in message oups.com... Marc, Good point - I do a static drawdown each year when I do the annual (I have the equipment so what the heck). When it starts to leak I'll probably change over to your method. Marc Ramsey wrote: The cold and moisture may no longer cause a problem, but from my experience, the quick connect eventually will. The last time I tried one, it lasted a couple of seasons, then started to leak. These days, I put an inline connector at the end all of the tubes, then use short pieces of tubing to connect to the instruments, which get thrown away every time I disconnect them... Marc |
Marc Ramsey wrote:
Jay wrote: I wondered about this, researched it to a limited extent and then thought - why take a chance? Not only is the cold a potential problem but moisture etc. has a potential for causing problems as well. I bought a quick-connect for all the pitot/static tubes on the panel and installed a quick-connect for all the electrical wires leading to the panel. When the glider comes home for the season, the panel comes out of the glider and goes in the house. Takes about 5 minutes and the cold and moisture hasn't caused a problem yet! The cold and moisture may no longer cause a problem, but from my experience, the quick connect eventually will. The last time I tried one, it lasted a couple of seasons, then started to leak. These days, I put an inline connector at the end all of the tubes, then use short pieces of tubing to connect to the instruments, which get thrown away every time I disconnect them... I've switched over to silicone tubing for the instrument connections, like the type that comes with a Cambridge 302. Cambridge will sell it to you, as well as McMaster-Carr (probably cheaper). It's easy to install, easy to remove, and retains this ease even after years of 100+ deg F summers and 10 deg F winters. The factory glider tubing from the pitot/static/etc is still the clear plastic stuff, so I use an inline connector to the silicone tubing. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Minimum Instruments Required? | John A. Landry | Home Built | 5 | October 14th 05 11:27 PM |
Gyros - Electric vs Vacuum? | Bill Denton | Piloting | 1 | April 18th 04 05:56 AM |
