In Mal's 2006 photos is a picture of Pawnee VH-CUR that appears to have
a Tost retractable tow rope. Does anyone have experience with contest towing with the retract rope? Is it possible to fit into the normal tug rotation with a retract rope, or is the rope left extended for contest towing. Andy |
Having run many contests in the U.S., it has been my experience that
they fit in the rotation just fine. Although most of our tugs feature the retractable rope, most contests are run with a mixture of tow rope systems. Andy wrote: In Mal's 2006 photos is a picture of Pawnee VH-CUR that appears to have a Tost retractable tow rope. Does anyone have experience with contest towing with the retract rope? Is it possible to fit into the normal tug rotation with a retract rope, or is the rope left extended for contest towing. Andy |
During the WGC in Sweden last summer we used 12 Pawnees with
tow rope winches. The rope is winched in after release and such a winch is more or less standard on Swedish tugs. /Robert CD WGC2006 Andy skrev: In Mal's 2006 photos is a picture of Pawnee VH-CUR that appears to have a Tost retractable tow rope. Does anyone have experience with contest towing with the retract rope? Is it possible to fit into the normal tug rotation with a retract rope, or is the rope left extended for contest towing. Andy |
for those that are un-intiatated..
the tow rope is retracted before landing saves wear and tear on the rope or snagging runway lights just taxi up closer to the glider, the line crew pulls the rope out and hooks up then taxi forward until the entire rope is out before take off BT "Andy" wrote in message oups.com... In Mal's 2006 photos is a picture of Pawnee VH-CUR that appears to have a Tost retractable tow rope. Does anyone have experience with contest towing with the retract rope? Is it possible to fit into the normal tug rotation with a retract rope, or is the rope left extended for contest towing. Andy |
![]() "BT" wrote in message ... for those that are un-intiatated.. the tow rope is retracted before landing saves wear and tear on the rope or snagging runway lights just taxi up closer to the glider, the line crew pulls the rope out and hooks up then taxi forward until the entire rope is out before take off BT "Andy" wrote in message oups.com... In Mal's 2006 photos is a picture of Pawnee VH-CUR that appears to have a Tost retractable tow rope. Does anyone have experience with contest towing with the retract rope? Is it possible to fit into the normal tug rotation with a retract rope, or is the rope left extended for contest towing. Andy http://www.mals.net/nswcomps2006/pages/DSC01883.htm I did have a close up of the tow hook set up but it has gone to delete land some how it was deleted it from the camera. During the state comps and cup week they used a normal tow rope the aircraft has both set ups on board. VH:CUR Experimental runs on unleaded it is a Holden commodore car engine. http://www.mals.net/nswcomps2006/pages/DSC01885.htm Did you spot the Jabiru J230 with a tow hook http://www.mals.net/ncw06/pics1/ Not this aircraft but another has done tows. |
![]() "BT" wrote in message ... for those that are un-intiatated.. the tow rope is retracted before landing saves wear and tear on the rope or snagging runway lights just taxi up closer to the glider, the line crew pulls the rope out and hooks up then taxi forward until the entire rope is out before take off Please, don't taxi up close to the glider. Be courteous and don't direct prop blast at gliders or people. I've had canopies slammed down on my fiingers and passengers heads. I've had to go to an eye doctor twice to get grit removed from my corneas. Towplane prop blast is absolutely the nastiest part of this sport. Just taxi into position 190 feet or so ahead of the glider, It's a lot better to have someone walk a few hunderd feet to get the rope than use a $140/hour Pawnee to position it. Bill Daniels |
![]() "Bill Daniels" bildan@comcast-dot-net wrote in message . .. "BT" wrote in message ... for those that are un-intiatated.. the tow rope is retracted before landing saves wear and tear on the rope or snagging runway lights just taxi up closer to the glider, the line crew pulls the rope out and hooks up then taxi forward until the entire rope is out before take off Please, don't taxi up close to the glider. Be courteous and don't direct prop blast at gliders or people. I've had canopies slammed down on my fiingers and passengers heads. I've had to go to an eye doctor twice to get grit removed from my corneas. Towplane prop blast is absolutely the nastiest part of this sport. Just taxi into position 190 feet or so ahead of the glider, It's a lot better to have someone walk a few hunderd feet to get the rope than use a $140/hour Pawnee to position it. Bill Daniels True Bill... I should have changed out that was stated.. when we "taxi close" the prop wash is always directed off to the side.. never at the glider or ground crew.. we also taxi no closer than on average about 50ft. Bill |
2006 Region 3 Soaring Contest - Glens Falls, NY | Tim Hanke | Soaring | 0 | April 7th 06 12:46 AM |
PW-5 US National Contest June 19-29, 2006 | Burt Compton - Marfa | Soaring | 0 | April 6th 06 05:13 PM |
US Region 7 Soaring Contest | Paul Remde | Soaring | 0 | May 11th 05 03:19 PM |
31st Annual CCSC Soaring Contest USA | Mario Crosina | Soaring | 0 | April 6th 05 12:47 AM |
CAD outline of Rans S6S instrument panel? | Rob Turk | Home Built | 2 | October 21st 03 09:27 PM |
