After using a lawn tractors slightly oiled, green foam filter on my
experimental with C-85, a fellow remarked that it was much too thick (about 1") as I replaced it. Just wondering what non-certified (read cheap G) alternatives that others are using. Seems like most guys use a pleated paper-like filter... Thanks Dick |
"Dick" wrote in message news:GiKrh.2487$jG1.88@trnddc04... After using a lawn tractors slightly oiled, green foam filter on my experimental with C-85, a fellow remarked that it was much too thick (about 1") as I replaced it. Just wondering what non-certified (read cheap G) alternatives that others are using. Seems like most guys use a pleated paper-like filter... Thanks Dick A Brackett filter for a certified aircraft with C-85 would be about the same thickness. You don't want to suck anything, such as a part of the filter, up into the carburetor. Even Bracketts have had their problems with AD's because of parts of the filter migrating into the venturi. |
"Dick" wrote in message news:GiKrh.2487$jG1.88@trnddc04... After using a lawn tractors slightly oiled, green foam filter on my experimental with C-85, a fellow remarked that it was much too thick (about 1") as I replaced it. Just wondering what non-certified (read cheap G) alternatives that others are using. Seems like most guys use a pleated paper-like filter... Thanks Dick Check with the K&N filter folks. They have a lot of high performance filters to choose from. |
"Dick" wrote in message news:GiKrh.2487$jG1.88@trnddc04... After using a lawn tractors slightly oiled, green foam filter on my experimental with C-85, a fellow remarked that it was much too thick (about 1") as I replaced it. Just wondering what non-certified (read cheap G) alternatives that others are using. Seems like most guys use a pleated paper-like filter... Thanks Dick http://www.knfilters.com/ |
On Thu, 18 Jan 2007, Maxwell wrote:
Check with the K&N filter folks. They have a lot of high performance filters to choose from. Amsoil makes an oiled foam filter that flows as good as K&N, and filters a lot better. (And last I looked, they're cheaper.) They have them for most automotive applications. -Dan |
Dick wrote:
After using a lawn tractors slightly oiled, green foam filter on my experimental with C-85, a fellow remarked that it was much too thick (about 1") as I replaced it. Just wondering what non-certified (read cheap G) alternatives that others are using. Seems like most guys use a pleated paper-like filter... Thanks Dick Foam filters have a history of coming apart, getting sucked into the carburetor, and causing blockages which results in the engine stopping. Makes for interesting emergency landing explanations. |
Cripes! How cheap is cheap?! A replacement Brackett air filter is only
about 6 bucks and you replace it at each annual (unless you live in a particularly dirty and dusty area)... Scott Dick wrote: After using a lawn tractors slightly oiled, green foam filter on my experimental with C-85, a fellow remarked that it was much too thick (about 1") as I replaced it. Just wondering what non-certified (read cheap G) alternatives that others are using. Seems like most guys use a pleated paper-like filter... Thanks Dick |
ordered 2, thanks
"Scott" wrote in message .. . Cripes! How cheap is cheap?! A replacement Brackett air filter is only about 6 bucks and you replace it at each annual (unless you live in a particularly dirty and dusty area)... Scott Dick wrote: After using a lawn tractors slightly oiled, green foam filter on my experimental with C-85, a fellow remarked that it was much too thick (about 1") as I replaced it. Just wondering what non-certified (read cheap G) alternatives that others are using. Seems like most guys use a pleated paper-like filter... Thanks Dick |
john smith wrote: Dick wrote: After using a lawn tractors slightly oiled, green foam filter on my experimental with C-85, a fellow remarked that it was much too thick (about 1") as I replaced it. Just wondering what non-certified (read cheap G) alternatives that others are using. Seems like most guys use a pleated paper-like filter... Thanks Dick Foam filters have a history of coming apart, getting sucked into the carburetor, and causing blockages which results in the engine stopping. Makes for interesting emergency landing explanations. We've been using the Brackett foam filters on our training airplanes for 14 years (and 13 airplanes, five or six at any one time, hundreds of hours per year per airplane) and have had no trouble whatever. The filters work well enough that the engines reach TBO with the compression still in the high 70s, even though we do a lot of training off dirt strips, and are cheap to replace. It's not an oil in the Brackett filter, its a glycerine or silicone goop of some sort. Can't try to wash and re-oil it. It needs to be replaced yearly in any case to prevent decaying foam getting into the intake. There have been a couple of ADs against the Bracketts: one involved the rear screen (aluminum) vibrating and flexing then breaking and entering the engine; it was superceded by a steel-screened frame. The other was to do with the filter frame/airbox gasket on some models getting sucked in; another revision fixed that. Every time we get another airplane it gets a Brackett. Dan |
| Century IIIB Rate Filter Parts and Schematics | PilotMike2004 | Owning | 1 | January 10th 05 01:01 PM |
| What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Naval Aviation | 5 | August 21st 04 01:50 AM |
| What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Military Aviation | 3 | August 21st 04 01:40 AM |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| Filter element for Frantz filter | Philippe | Owning | 1 | April 20th 04 09:23 PM |
