Yesterday, I attended a 4-hour seminar on the G1000 presented by Charlie
Masters (Cessna/FITS & Sporty's @ Clermont County). The focus was on providing an overview of transitioning from steam gauges to glass panels as implemented in new Cessna single-engine aircraft. Charlie did a great job, and has good general knowledge of the system. Overall, I am quite impressed with the thought behind this unit, and think it will be the way of things to come. Of course, in addition to the general information, I was curious about the possible causes for NW_Pilot's experience during the ferrying of a 172, and asked a couple of questions that might have provided some insights. I believe that I have some clues, but I'm still at a loss to explain some of what he went through. There are many things to understand about the G1000 installation, perhaps foremost is that this is not a single box that is located in the panel. There are more than a half dozen modules (not including the sensors), some located in the tail of the plane, some located behind the panel. These have specific functions, for example the Attitude/Heading Reference System (AHRS) provides attitude and directional information to the virtual AI & HSI separately from the Integrated Avionics (GIA) that provides GPS/NAV & Comm functions. Other modules include the Engine/Airframe (GEA) unit, Data Link (GDL), and audio panel. The modules are on separate breakers in the panel. The significance of this kind of modularity is that the failure of any of these modules will not cause an overall system failure. I also asked Charlie about the connections between these modules and the monitor. There is a single multi-conductor cable connection to the back of the monitor panels. The entire system is fed power from a connection to the master switch (there is also a backup battery that can operate the unit separately from master power). So, the total failure is unlikely to have been caused by sensors, monitors or modules, as all of those would have to not only fail simultaneously, but would have to reinstate themselves to "come up" after a reboot, which is highly unlikely. Even a problem with the multi-conductor cable would only affect one of the two monitor panels. All of this confirms my original suspicion that for the entire system to periodically spontaneously reboot, the cause is likely to be an intermittent power connection. In such a case, all of the modules would go down, and the process would emulate the POH procedure for intentionally rebooting the system. Neil |
"Neil Gould" wrote in message et... Yesterday, I attended a 4-hour seminar on the G1000 presented by Charlie Masters (Cessna/FITS & Sporty's @ Clermont County). The focus was on providing an overview of transitioning from steam gauges to glass panels as implemented in new Cessna single-engine aircraft. Charlie did a great job, and has good general knowledge of the system. Overall, I am quite impressed with the thought behind this unit, and think it will be the way of things to come. Of course, in addition to the general information, I was curious about the possible causes for NW_Pilot's experience during the ferrying of a 172, and asked a couple of questions that might have provided some insights. I believe that I have some clues, but I'm still at a loss to explain some of what he went through. There are many things to understand about the G1000 installation, perhaps foremost is that this is not a single box that is located in the panel. There are more than a half dozen modules (not including the sensors), some located in the tail of the plane, some located behind the panel. These have specific functions, for example the Attitude/Heading Reference System (AHRS) provides attitude and directional information to the virtual AI & HSI separately from the Integrated Avionics (GIA) that provides GPS/NAV & Comm functions. Other modules include the Engine/Airframe (GEA) unit, Data Link (GDL), and audio panel. The modules are on separate breakers in the panel. The significance of this kind of modularity is that the failure of any of these modules will not cause an overall system failure. I also asked Charlie about the connections between these modules and the monitor. There is a single multi-conductor cable connection to the back of the monitor panels. The entire system is fed power from a connection to the master switch (there is also a backup battery that can operate the unit separately from master power). So, the total failure is unlikely to have been caused by sensors, monitors or modules, as all of those would have to not only fail simultaneously, but would have to reinstate themselves to "come up" after a reboot, which is highly unlikely. Even a problem with the multi-conductor cable would only affect one of the two monitor panels. All of this confirms my original suspicion that for the entire system to periodically spontaneously reboot, the cause is likely to be an intermittent power connection. In such a case, all of the modules would go down, and the process would emulate the POH procedure for intentionally rebooting the system. Neil Neil, You could be correct. A bad power connection or poorly regulated power could cause big problems. But the G1000 has an internal battery pack that is supposed to provide graceful transition with bad power inputs. Accordingly, I would not rule out a latent software problem. After reading NW_Pilot's postings, I was thinking that the original fuel quantity display problems might have caused some sort of over or under-range internal calculation error. Since my day job involves integrating hardware and software in large million-line control systems, this is one of the first things that came to mind. It is exceedingly difficult to test hardware and software in complex systems at the possible extremes to guarantee proper operation. I sure hope that Garmin reads these types of newsgroup postings and investigates. Invalid or over inputs on one or more sensors should not have radical effects on unrelated operational modes of the G1000. But it certainly looked like it was happening to NW_Pilot. Regards, John Severyn |
Recently, J. Severyn posted:
"Neil Gould" wrote in message et... Yesterday, I attended a 4-hour seminar on the G1000 presented by Charlie Masters (Cessna/FITS & Sporty's @ Clermont County). The focus was on providing an overview of transitioning from steam gauges to glass panels as implemented in new Cessna single-engine aircraft. Charlie did a great job, and has good general knowledge of the system. Overall, I am quite impressed with the thought behind this unit, and think it will be the way of things to come. Of course, in addition to the general information, I was curious about the possible causes for NW_Pilot's experience during the ferrying of a 172, and asked a couple of questions that might have provided some insights. I believe that I have some clues, but I'm still at a loss to explain some of what he went through. There are many things to understand about the G1000 installation, perhaps foremost is that this is not a single box that is located in the panel. There are more than a half dozen modules (not including the sensors), some located in the tail of the plane, some located behind the panel. These have specific functions, for example the Attitude/Heading Reference System (AHRS) provides attitude and directional information to the virtual AI & HSI separately from the Integrated Avionics (GIA) that provides GPS/NAV & Comm functions. Other modules include the Engine/Airframe (GEA) unit, Data Link (GDL), and audio panel. The modules are on separate breakers in the panel. The significance of this kind of modularity is that the failure of any of these modules will not cause an overall system failure. I also asked Charlie about the connections between these modules and the monitor. There is a single multi-conductor cable connection to the back of the monitor panels. The entire system is fed power from a connection to the master switch (there is also a backup battery that can operate the unit separately from master power). So, the total failure is unlikely to have been caused by sensors, monitors or modules, as all of those would have to not only fail simultaneously, but would have to reinstate themselves to "come up" after a reboot, which is highly unlikely. Even a problem with the multi-conductor cable would only affect one of the two monitor panels. All of this confirms my original suspicion that for the entire system to periodically spontaneously reboot, the cause is likely to be an intermittent power connection. In such a case, all of the modules would go down, and the process would emulate the POH procedure for intentionally rebooting the system. Neil Neil, You could be correct. A bad power connection or poorly regulated power could cause big problems. But the G1000 has an internal battery pack that is supposed to provide graceful transition with bad power inputs. Accordingly, I would not rule out a latent software problem. After reading NW_Pilot's postings, I was thinking that the original fuel quantity display problems might have caused some sort of over or under-range internal calculation error. Originally, I thought that this might be a possible scenario. However, the fuel information is provided by the GEA, and even if that unit fails completely, it would only result in red "X" over the fuel readout. There are a couple of scenarios that can produce failure indications in the fuel readouts, but from what I understand, nothing that can trigger a complete system failure. Since my day job involves integrating hardware and software in large million-line control systems, this is one of the first things that came to mind. It is exceedingly difficult to test hardware and software in complex systems at the possible extremes to guarantee proper operation. I understand, and it appears that this was done. On the one hand, this system isn't all that complex; rather than feed numerous inputs into a single interpreter module, which might result in the kind of event you're anticipating, each module is a physically separate piece of hardware that feeds its results to the integraged display. There is also redundancy built into some modules (multiple components doing the same job), and any ambiguities are either resolved by a "vote of the majority" or failed, but won't result in a system-wide reboot. Simply put, out of range data would just fail that particular function. For example, in the case of his fuel level reading failures, it seems reasonable that the *increasing* fuel level readings as engine overflow was fed from the aux tank to the main tanks didn't agree with the fuel consumption computer, and as a result, the G1000 "X'd" it out, in essence saying "don't depend on this info"; that is an intended behavior of the G1000. I sure hope that Garmin reads these types of newsgroup postings and investigates. Invalid or over inputs on one or more sensors should not have radical effects on unrelated operational modes of the G1000. But it certainly looked like it was happening to NW_Pilot. What I took away from the seminar is that about the only scenario that could produce the effects that NW_Pilot reported is a main power failure. All of the modules would have to fail simultaneously, and even then, the system wouldn't reboot, but would show a screen full of red Xs. In fact, the POH method of rebooting the G1000 in-flight is to shut off the main power switch. The backup battery is only good for 1/2 hour, so it seems possible that the spontaneous rebooting behavior started after the backup battery was dry. Neil |
"Neil Gould" wrote in message news ![]() Recently, J. Severyn posted: "Neil Gould" wrote in message et... Yesterday, I attended a 4-hour seminar on the G1000 presented by snip I understand, and it appears that this was done. On the one hand, this system isn't all that complex; rather than feed numerous inputs into a single interpreter module, which might result in the kind of event you're anticipating, each module is a physically separate piece of hardware that feeds its results to the integraged display. There is also redundancy built into some modules (multiple components doing the same job), and any ambiguities are either resolved by a "vote of the majority" or failed, but won't result in a system-wide reboot. I understand. But the integrated display might be the culprit. The individual LRUs might be acting properly and feeding data to the display system. If the display system (hardware or software) does not properly handle the exceptions, then lots of unintended things can happen. Software patches, compiler errors etc. only make the testing combinations all the more difficult. In any case, a pilot has got to be able to keep the dirty side down using the backup steam guages. snip Neil Regards, John Severyn |
By the way, Garmin is not unique to similar problems. It has happened to the big iron too. http://www.ntsb.gov/recs/letters/1998/A98_3_5.pdf notes intended reboots in the EFIS in an A300 back in 1997. Regards, John Severyn |
J. Severyn writes:
I sure hope that Garmin reads these types of newsgroup postings and investigates. Invalid or over inputs on one or more sensors should not have radical effects on unrelated operational modes of the G1000. But it certainly looked like it was happening to NW_Pilot. Many companies in this domain for the first time, especially those with PC backgrounds, never read anything and reinvent the wheel the hard way, sometimes only after a string of very bad things happen. -- Transpose mxsmanic and gmail to reach me by e-mail. |
J. Severyn writes:
By the way, Garmin is not unique to similar problems. It has happened to the big iron too. http://www.ntsb.gov/recs/letters/1998/A98_3_5.pdf notes intended reboots in the EFIS in an A300 back in 1997. Airbus and Garmin have some things in common. -- Transpose mxsmanic and gmail to reach me by e-mail. |
"Neil Gould" wrote: Recently, J. Severyn posted: "Neil Gould" wrote in message et... Yesterday, I attended a 4-hour seminar on the G1000 presented by snip I understand, and it appears that this was done. On the one hand, this system isn't all that complex; rather than feed numerous inputs into a single interpreter module, which might result in the kind of event you're anticipating, each module is a physically separate piece of hardware that feeds its results to the integraged display. There is also redundancy built into some modules (multiple components doing the same job), and any ambiguities are either resolved by a "vote of the majority" or failed, but won't result in a system-wide reboot. I understand. But the integrated display might be the culprit. I don't think that's possible. There is no provision for the display system to reboot the hardware; that just isn't done via software, or even by physical switches located on the display unit(s). The display unit(s) can't turn on or off the individual modules either, so a software glitch of any kind -- or even total failure of the display -- isn't able to be the cause of a system-wide reboot. The individual LRUs might be acting properly and feeding data to the display system. If the display system (hardware or software) does not properly handle the exceptions, then lots of unintended things can happen. Software patches, compiler errors etc. only make the testing combinations all the more difficult. I understand, and in a type of arrangement where sensor outputs are being interpreted by centralized CPU, what you describe might be an area of concern. But, the G1000 is not that kind of system. Each module is its own complete computing system, the integrated display merely reports the data provided by the modules. When the data from modules conflicts and can't be resolved, the centralized display can disable that module's content *on the screen*, it can't shut the module down. In any case, a pilot has got to be able to keep the dirty side down using the backup steam guages. The backup steam gauges are completely separate from the G1000, as is the autopilot and the comm (another reason that I suspect NW_Pilot's problems are related to the loss of power). In fact, the 2-axis autopilot has its own turn coordinator mounted behind(!) the panel, and will fly the plane even if the G1000 is turned off. Neil |
Neil Gould writes:
I don't think that's possible. There is no provision for the display system to reboot the hardware; that just isn't done via software, or even by physical switches located on the display unit(s). The display unit(s) can't turn on or off the individual modules either, so a software glitch of any kind -- or even total failure of the display -- isn't able to be the cause of a system-wide reboot. Virtually any bug can cause a reboot. Anything that produces a hardware exception can cause a reboot if it is unexpected, particularly if the system is doing privileged work at the time. A reboot is the typical response to any unhandled exception. The alternative is to let the system run hither and yon uncontrolled through the code, which is even worse than a reboot in most cases. Of course, in safety-of-life applications, there must not be any unexpected exceptions; if there are, it's a flaw in the design. Unfortunately, people from PC-land tend to take the system down whenever there's a spot in the code that they don't want to design or analyze in detail. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Although many of the components of the G1000 have backups, many do not. There are a lot of failures you can have that don't effect the operation, but some do. Part of the transition training (especially for IFR pilots) is to understand the failure mode of the different components. Sadly, we're finding that we are only able to sign off most of our instrument pilots for VFR in the G1000. The biggest problem is getting behind the plane and not getting the approach set up in the system soon enough. This is mostly the older guys though. I dont' think anyone under 40 has had a problem. -Robert, CFII, FITS trained TAA instructor On Jan 28, 8:23 am, "Neil Gould" wrote: Yesterday, I attended a 4-hour seminar on the G1000 presented by Charlie Masters (Cessna/FITS & Sporty's @ Clermont County). The focus was on providing an overview of transitioning from steam gauges to glass panels as implemented in new Cessna single-engine aircraft. Charlie did a great job, and has good general knowledge of the system. Overall, I am quite impressed with the thought behind this unit, and think it will be the way of things to come. Of course, in addition to the general information, I was curious about the possible causes for NW_Pilot's experience during the ferrying of a 172, and asked a couple of questions that might have provided some insights. I believe that I have some clues, but I'm still at a loss to explain some of what he went through. There are many things to understand about the G1000 installation, perhaps foremost is that this is not a single box that is located in the panel. There are more than a half dozen modules (not including the sensors), some located in the tail of the plane, some located behind the panel. These have specific functions, for example the Attitude/Heading Reference System (AHRS) provides attitude and directional information to the virtual AI & HSI separately from the Integrated Avionics (GIA) that provides GPS/NAV & Comm functions. Other modules include the Engine/Airframe (GEA) unit, Data Link (GDL), and audio panel. The modules are on separate breakers in the panel. The significance of this kind of modularity is that the failure of any of these modules will not cause an overall system failure. I also asked Charlie about the connections between these modules and the monitor. There is a single multi-conductor cable connection to the back of the monitor panels. The entire system is fed power from a connection to the master switch (there is also a backup battery that can operate the unit separately from master power). So, the total failure is unlikely to have been caused by sensors, monitors or modules, as all of those would have to not only fail simultaneously, but would have to reinstate themselves to "come up" after a reboot, which is highly unlikely. Even a problem with the multi-conductor cable would only affect one of the two monitor panels. All of this confirms my original suspicion that for the entire system to periodically spontaneously reboot, the cause is likely to be an intermittent power connection. In such a case, all of the modules would go down, and the process would emulate the POH procedure for intentionally rebooting the system. Neil |
| G1000 vs Steam guages initial thoughts... | [email protected] | Instrument Flight Rules | 48 | September 12th 06 01:33 AM |
| IPC G1000 | [email protected] | Instrument Flight Rules | 38 | September 3rd 06 01:22 AM |
| G1000 question | Robert M. Gary | Piloting | 0 | May 1st 06 11:36 PM |
| G1000 trainer simulator problems | akiley | Simulators | 2 | March 25th 06 08:54 PM |
| G1000 Check out | Michelle | Piloting | 105 | January 7th 06 05:33 AM |
