Anything new in to combat motion sickness?
Old February 4th 07, 11:04 AM posted to rec.aviation.soaring
Martin Eiler
Default Anything new in to combat motion sickness?
As a kid, say thru the age of about 13, I was quite
susceptible to motion sickness. It was guaranteed
that if you put me in the back seat of an airplane
I would get airsick. If I was in the front seat or
in
the back seat with controls and flying I would be fine.
By about 14 I was no longer prone to airsickness
when just riding in the back seat of an aircraft.
But if I attempted to read anything in an aircraft
or a car I would get queasy in short order. It is
not
uncommon for new pilots to get queasy when
navigation requires detailed map reading.
About the age of 35 my eyesight started to
diminish and I began t need reading glasses. A
side benefit of the slightly reduced near vision was
that I found that I could now read while riding in
a
vehicle, without getting motion sickness.
At 09:00 04 February 2007, Alex wrote:
One interesting theory on the cause of motion sickness
is on the
Wikipedia and I am quoting it here, not sure if you
can prove it, but
it's an interesting idea:
'The most common theory for the cause of motion sickness
is that it
evolved as a defence mechanism against neurotoxins.
The area postrema
in the brain is responsible for inducing vomiting when
poisons are
detected, and for resolving conflicts between vision
and balance. When
feeling motion but not seeing it (for example, in a
ship with no
windows), the inner ear transmits to the brain that
it senses motion,
but the eyes tell the brain that everything is still.
The area
postrema will always believe the inner ear signal over
the eyes, as
the eyes are more susceptible to trickery (see optical
illusion). As a
result, the brain will come to the conclusion that
one is
hallucinating and further conclude that the hallucination
is due to
poison ingestion. The brain responds by inducing vomiting,
to clear
the supposed toxin.'
Old February 4th 07, 02:12 PM posted to rec.aviation.soaring
Tony Verhulst
Forest Baskett wrote:
I found that the inside of a Camelbak gets slimy very
quickly if left with water in it. I now store mine
on a hanger with the mouth down and with a cardboard
tube from an empty paper towel roll stuck inside to
hold it open. It dries quickly and is never slimy.
I've been doing this for several years and agree that it works well. I
also bought one of those tiny brushes on a long. flexible, shaft (see
http://tinyurl.com/33qcco) and clean out the delivery tube several times
per year (OK, once per year :-) ).
Tony V.
Old February 4th 07, 03:16 PM posted to rec.aviation.soaring
Jeremy Zawodny
Default water and bladders
Matt Herron Jr. wrote:
I didn't see it mentioned yet, but Peptid AC (yes, the over the
counter antacid) is a life saver for me. I take one about 1-2 hrs
before my flight, and try to avoid eating anything too greasy for
lunch. It completely cured my air sickness with no observable side
effects. Now, the question is why? I think part of my motion
sickness was due to my stress level in the air. This tended to get my
stomach churning, and perhaps that is what produced the undesired
reverse peristalsis. On the other hand, perhaps it's something
completely different.
I don't really care, as long as it works, and it hasn't failed me
yet. I was skeptical at first when someone suggested it, but won't
fly without it now. Anyone else tried this?
Yeah, that's helped me as well. In fact, I bet we both got the
suggestion from the same person. :-)
But the thing that's helped me the most is simply flying as much as
possible. The better my body gets at anticipating the sensations
involved with flying, lift, and various stick movements, the better I am.
Unfortunately, that means I end up being a bit of a stick hog on dual
flights early in the season.
Jeremy
Old February 4th 07, 04:04 PM posted to rec.aviation.soaring
bobcaldwell
On Feb 4, 12:02 am, "bumper" wrote:
"Forest Baskett" wrote in message
Forest
I changed the subject line.
I've found that not all water is created equal when it comes to "sliming".
When I lived in the North Bay area of California, we had water that was
mostly from Lake Berryessa and was "pre-treated". It was further treated
before being piped to the city folks, but we lived in the country so it was
sort of marginal, sometimes chlorine odor, sometimes not. Brown algae grew
in our pipes. I used a reverse osmosis filter, but still water left in a
Camelback would slime within a few days.
Where we live now, in the Sierra foothills just SW of Minden, Nevada, we
have well water that we could bottle and sell to Californians (g). This
water seems to stay pure and drinkable for months at a time. Never any slime
unless the container wasn't cleaned properly to begin with.
bumper
Camelback bladders can also be dealt with by simply rinsing, refilling
partially, inflating the bag with air thru the hose and freezing while
flat so the outlet and filler port don't freeze over. Cleaning about
monthly is all that is reqd. The water stays very fresh and cold.
The amount you partially fill it should be related to how hot it will
be and how long until you need the water. Then fill to capacity and
go. Another secret is to turn the bladder upside down and suck all
the air out it. That way you don't get the annoying gurgle, there is
always water available at first suck and it will more fully empty.
Adjust the frozen portion according to experience. I use a third full
for average days and half full for hot ones.
BC
Old February 4th 07, 04:06 PM posted to rec.aviation.soaring
Bullwinkle
On 2/4/07 12:02 AM, in article
, "bumper"
Forest
bumper
care of camelback bladders:
I use vinegar.
When I get a new bladder, I put a weak vinegar solution in it and let it sit
for a few hours: takes away that initial "plastic" taste. Rinse a few times
to get rid of the vinegar flavor and you're good to go.
Always drain, rinse, and dry (paper towel tube, or the official Camelback
drying doo-dad) after use. This reduces dramatically the chance of growth by
any of our teeny-weeny friends.
I repeat the vinegar thing at the beginning of the season, unless some of
the plastic parts appear about to get brittle and fail. Then I get a new
bladder and repeat.
One of the bladders I'm using now is 3 years old. I carry two: one for
hydration, one for survival.
Good flying,
Bullwinkle
Old February 4th 07, 06:02 PM posted to rec.aviation.soaring
Shawn
Bill Daniels wrote:
Very plausible. Replacement bladders for these "camelback' things only cost
about $15 - I buy a new one each Spring.
Where do you buy them Bill? I just paid $30 at the Boulder REI for a
new 100 oz bladder.
I use my camel backs (I think we have five of them) for cycling, skiing,
hiking, road trips as well as flying. The drying rack they sell is well
worth the bucks to keep them mold free. Also, after emptying any left
over water, I grab the hose near the bladder and spin vigorously to
force the last of the water to the end (that sounds bad doesn't it?).
Squeeze the bite valve to drain the last of it. No icky green tubing
for a few years now.
Shawn
Old February 4th 07, 06:43 PM posted to rec.aviation.soaring
Bill Daniels
Try WallMart or Target.
Bill
"Shawn" wrote in message
cost about $15 - I buy a new one each Spring.
Where do you buy them Bill? I just paid $30 at the Boulder REI for a new
100 oz bladder.
over water, I grab the hose near the bladder and spin vigorously to force
the last of the water to the end (that sounds bad doesn't it?). Squeeze
the bite valve to drain the last of it. No icky green tubing for a few
years now.
Shawn
  #28
Old February 4th 07, 08:33 PM posted to rec.aviation.soaring
Gary Emerson
Gary Emerson wrote:
Greetings,
I typically suffer from motion sickness early in the season and
sometimes on longer flights if the thermals are rough.
I have one of the electronic wrist devices. It's of some benefit, but
it's not an instant cure, at least for me.
Just curious if there are any new meds or other solutions that might be
in the works??
Gary
Thanks for all the great responses. Looks like there are a couple new
things for me to try.
On the cammelbak subject, I rinse mine thoroughly and hang it up to dry
after each flight and periodically put some bleach in it to kill of
anything that might be hanging around. Following the bleach I rinse it
4-5 times and then hang it up to dry out.
Gary
  #29
Old February 4th 07, 11:10 PM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
Try ebay for imitation bladders, store always in the freezer, I dont think I would bother drying the bladder before freezing, the bugs will still be there.
Anybody know of a decent, economical, NO LEAK hi flow valve for the damn things?? This part drives me berserk, they either leak or dont give you more than a sip at a time.
Back to topic, try being troubled by another condition.
I always feel crook if flying locally, and will meter myself a half pill or two as the hours go.
Cross country I seldom feel any ill health, I expect due to the higher mind load of navigating, calculating, seeing new ground etc.
The more I think about throwing up, the more chance I have of doing it.
Dont think about it!
bagger
  #30
Old February 4th 07, 11:42 PM posted to rec.aviation.soaring
Alan Meyer
Like others, I often get airsick on early season flights around the
airport. I don't get sick later in the season and have never been
sick on a cross country flight.
Obviously, there is a powerful psychological component to
airsickness. Why else would so many of us successfully
acclimate to it, and why else would we not get sick on
cross country flights, where we know we don't have the
option of landing?
I once read, can't remember where, that the Royal
Air Force did a study of counseling as a way to combat it,
and apparently it worked!
Mostly I now just fly and don't worry about it and don't get
sick, but when I experimented with drugs, I had good success
with meclizine, a cheap, over the counter remedy. It tended
to make me sleepy so I tried taking it the night before and
getting a good night's sleep. The drug is supposed to work
for 24 hours, so this seemed to work for me.
Alan
Instructors: is no combat better? ArtKramr Military Aviation 103 March 13th 04 09:07 PM
Did you ever give up on an IR? No Such User Piloting 24 November 26th 03 02:45 PM
Combat Related Special Compensation update for Sept. 8-12 Otis Willie Military Aviation 0 September 17th 03 03:38 AM
