Except for that I'd like to see the real-time position of each glider
around (flarm, Mode-S?) including vertical speed so that you can see lift ratios accurately... Doesn't this still exist four flarm? Andreas |
"Bill Daniels" bildan@comcast-dot-net wrote:
Inertial variometry with instantaneous response and no gust sensitivity. Do you really think this is possible? How many times did you bump into a canopy in a rotor? OK this is extreme and yes, I know this isvertical. Cheers, Henryk Birecki |
Yep, it's possible. Total energy variometry can be done entirely in the
inertial domain. It's rapidly becoming affordable with MEMS Inertial Measurement Units. I-FOG gyros are better but more expensive. The enormous demand for UAV autopilots is driving the development of low cost ADAHRS units that would be suitable for the purpose. The IMU has to maintain an accurate euler angle reference but not to great precision since it's a cosine function but the accelerometer(s) on the vertical axis has to be pretty good although it can be constantly recalibrated by reference to a pressure datum. It also takes a bit of computer power. The advantages are many since this approach eliminates the TE probe with its inherent errors and gust sensitivity. An inertial vario would have no trouble differentiating a horizontal gust from a thermal. The instantaneous response should give a 1:1 butt-to-vario correlation. Oh yes, once the euler angles are available to a degree of precision, measuring L/D is simply a matter of measuring the angle between a pitch vane and the horizontal. That means that bug degradation can be accurately known in real time. Bill Daniels "Henryk Birecki" wrote in message ... "Bill Daniels" bildan@comcast-dot-net wrote: Inertial variometry with instantaneous response and no gust sensitivity. Do you really think this is possible? How many times did you bump into a canopy in a rotor? OK this is extreme and yes, I know this isvertical. Cheers, Henryk Birecki |
Then the next step is to use that data on a Heads-Up Display (HUD),
and show the velocity vector, so that you have a "bug" which shows exactly where you would get to with your current state. Having flown a Harrier simulator which has that, you'd be amazed how valuable that is. Then there's the pitch ladder, which isn't that useful to a glider, and the speed and altitude tapes. And, somewhere there's a secret government program to make almost exactly this instrument. Hey, we're dreamin' here. Ed |
An instrument panel top HUD in a glider wouldn't be too difficult with
current technology. Perhaps an even better approach for a glider would be a HEAD Mounted Display (HMD) with a head tracker. That way you could display anything that shows on a computer screen but indexed to aircraft attitude. There are currently see-through HMD's for PDA's that provide a large virtual display screen. Bill Daniels "flying_monkey" wrote in message ups.com... Then the next step is to use that data on a Heads-Up Display (HUD), and show the velocity vector, so that you have a "bug" which shows exactly where you would get to with your current state. Having flown a Harrier simulator which has that, you'd be amazed how valuable that is. Then there's the pitch ladder, which isn't that useful to a glider, and the speed and altitude tapes. And, somewhere there's a secret government program to make almost exactly this instrument. Hey, we're dreamin' here. Ed |
J. Nieuwenhuize wrote:
A videocamera at the tail sounds nice in really tight thermals; those basterds tends to hide at your six. Small video cameras are numerous, and we already have a screen in the cockpit. Does anyone know how to connect a video camera to an Ipaq? Perhaps a Bluetooth camera and software exist for Ipaqs? That would make it easy - just a little video "bump" on top of the fuselage a few inches aft of the canopy, looking aft. Tap a button on the Ipaq to switch to the video, tap to switch back to the flight computing. I've tried mirrors of various type without much success. This might work better. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Henryk Birecki wrote:
"Bill Daniels" bildan@comcast-dot-net wrote: Inertial variometry with instantaneous response and no gust sensitivity. Do you really think this is possible? How many times did you bump into a canopy in a rotor? OK this is extreme and yes, I know this isvertical. Take a look at Eagle Tree systems: http://www.eagletreesystems.com/Sail...sailplane.html These guys sell an electronic TE compensated audio vario for RC gliders, so the vario plus down-link transmitter are small and light enough to fit into a model. The vario's operating principles are not described. Its only external sensors are static and pitot inputs MEMs are not mentioned. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
"Bill Daniels" bildan@comcast-dot-net writes:
Yep, it's possible. Total energy variometry can be done entirely in the inertial domain. It's rapidly becoming affordable with MEMS Inertial Measurement Units. I-FOG gyros are better but more expensive. The enormous demand for UAV autopilots is driving the development of low cost ADAHRS units that would be suitable for the purpose. How does that compare with a full x,y,z,dx,dy,dz,t GPS solution? ------------ And now a word from our sponsor ------------------ Do your users want the best web-email gateway? Don't let your customers drift off to free webmail services install your own web gateway! -- See http://netwinsite.com/sponsor/sponsor_webmail.htm ---- |
GPS is a position finding system, an IMU is a position keeping system. The
IMU adds pitch, roll, & heading. Attitude data can also be obtained from a multi-antenna GPS carrier phase system but not with the same accuracy or data rate. GPS and inertial systems complement each other as the inertial system can continue providing data during a GPS dropout while the GPS system keeps the IMU accurate over long time periods. Inertial systems provide acurate high-rate data over shorter time spans. The IMU effectively "smooths" the GPS data. A GPS positioning plus an AHRS system makes it possible to use a less accurate MEMS IMU. It's the accurate high-rate vertical acceleration data that is useful for an inertial variometer. Accurate heading data when combined with ground track, ground speed and ture airspeed provides real time vector winds. These systems are now being used in UAV's and as performance increases and prices decreases, there is no doubt they will find their way into gliders. Bill Daniels "Paul Repacholi" wrote in message ... "Bill Daniels" bildan@comcast-dot-net writes: Yep, it's possible. Total energy variometry can be done entirely in the inertial domain. It's rapidly becoming affordable with MEMS Inertial Measurement Units. I-FOG gyros are better but more expensive. The enormous demand for UAV autopilots is driving the development of low cost ADAHRS units that would be suitable for the purpose. How does that compare with a full x,y,z,dx,dy,dz,t GPS solution? ------------ And now a word from our sponsor ------------------ Do your users want the best web-email gateway? Don't let your customers drift off to free webmail services install your own web gateway! -- See http://netwinsite.com/sponsor/sponsor_webmail.htm ---- |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| Thunderstorm - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 3rd 05 12:05 AM |
| Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 06:14 AM |
| NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 06:12 AM |
