Straight-ins at uncontrolled airports?
Old February 16th 07, 05:04 AM posted to rec.aviation.piloting
Mxsmanic
Default Straight-ins at uncontrolled airports?
Crash Lander writes:
Active and non-active. You know very well what I meant. Now you're just
being facetious.
No, I'm serious. Flying on the wrong side of the pattern is dangerous.
  #172
Old February 16th 07, 05:20 AM posted to rec.aviation.piloting
Crash Lander[_1_]
"Mxsmanic" wrote in message
This is clearly not your bridge. Please get out from under it.
Crash Lander
  #173
Old February 16th 07, 05:29 AM posted to rec.aviation.piloting
Tony
Here's a question for pilots.
You're flying a downwind to 05 at an uncontrolled airport called
Podunk that has a normal traffic pattern in the United States and you
hear and you hear on unicom "Poduck traffic, Mooney N 000 is entering
upwind for 05". Do you know where to look for that traffic?
Now, for those lurkers who know something about aviation : How about
you? Would you know where to look?
being facetious.
  #174
Old February 16th 07, 05:44 AM posted to rec.aviation.piloting
Crash Lander[_1_]
"Tony" wrote in message
Well, he should be on the opposite side of the airfield to you, heading in
the opposite direction. As a precaution, if you could not spot him, you
could/should make a position call of your own, to let him know you are
already in the pattern so he can also look out for you.
Oz/Crash Lander
  #175
Old February 17th 07, 09:40 AM posted to rec.aviation.piloting
Roger[_4_]
Every where!
being facetious.
www.rogerhalstead.com
  #176
Old February 18th 07, 12:34 AM posted to rec.aviation.piloting
Jim[_14_]
On Sat, 17 Feb 2007 03:40:43 -0500, Roger
Every where!
being facetious.
As I recall the AIM calls for entering the pattern at a 45 degree
angle to the downwind leg. That being said, If you are approaching the
down wind leg for runway 36, the downwind heading is 180, is it
acceptable to cross over the top of the field on a heading of 135 and
turn to a heading of 180? Or do you cross over the top of the airport
and do a right turn to heading of 225 setting up a right turn to the
180 down wind leg? That has always confused me. Thanks
Jim in Houston
osPAm
Nurse's creed: Fill what's empty, empty what's full,
and scratch where it itches!! RN does NOT mean Real Nerd!
  #177
Old February 18th 07, 01:21 AM posted to rec.aviation.piloting
Tony
1 cross over well above pattern altitude, descend to pattern altitude
on the 'pattern' side, using the crossing over time to see what was
going on at the airport, then enter on a 45,
or
2 circle at some distance to get to the pattern side, enter in the
normal way
or
3 enter on the upwide side as mentioned elsewhere.
If it's uncontrolled with a conventional pattern, feel free to enter
anwhere on the circuit so long as you'll then be making turns to the
left, and announce, announce, anounce!
Every where!
being facetious.
Jim in Houston
and scratch where it itches!! RN does NOT mean Real Nerd!- Hide quoted text -
- Show quoted text -
  #178
Old February 18th 07, 04:00 AM posted to rec.aviation.piloting
DaveB
On Fri, 16 Feb 2007 03:52:17 GMT, "Crash Lander"
I did find one page that
talked about an upwind entry into the crosswind, and it argued that if you
are
at pattern altitude, you aren't likely to meet other traffic, but that
seems
like an extraordinarily dangerous assumption given the variability of
climb
rates, runway lengths, departure points on the runway, and so on. It's
even
more dangerous if someone decides to go around.
Ever heard of a radio? If someone's going around, and you're close enough to
be in their way, then you're a) going to hear their calls on the radio,
and/or you're looking for traffic anyway.
Crash Lander
unless they dont have a radio
Daveb
  #179
Old February 18th 07, 08:48 AM posted to rec.aviation.piloting
Oz Lander[_2_]
that if you are
that seems
of climb
It's even
enough to be in their way, then you're a) going to hear their calls
on the radio, and/or you're looking for traffic anyway.
Crash Lander
Daveb
Then if they don't have a radio, that's an even stronger argument that
they should be joining a standard pattern, so other traffic already in
the pattern will already be looking for traffic.
Oz Lander.
I'm not always right,
But I'm never wrong.
  #180
Old February 18th 07, 08:52 AM posted to rec.aviation.piloting
Mxsmanic
Oz Lander writes:
Someone going around _is_ in the standard pattern, since the standard pattern
always includes the runway.
Southern California airports have worst runway safety records Larry Dighera Piloting 0 November 26th 05 05:48 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
Airports Rated Critical Unsatisfactory: Given Black Star Rating Michael Ravnitzky Piloting 0 February 3rd 05 04:34 AM
IFR hold short line at uncontrolled airports? Peter R. Instrument Flight Rules 30 June 9th 04 05:47 AM
fatal bird strike StellaStar Piloting 9 July 13th 03 10:41 PM
